Question about Kenmore 75085 Air Conditioner
Kenmore rac m# 580.75281500 what is the size capacitor that is needed for that unit?
Trying to determine what size capacitor my unit C1048BBD1VF uses for my AC unit. Is it larger then a 45 amp? Replace it with a 45 and you can hear it try to turn on but it won't.
capacitors are rated in microfarads or picofarads and not amps
capacitors are used to provide a boost voltage to start motors and then to keep them running
Amps is current flow so what ever you replaced was the wrong unit.
on the side of a capacitor will be voltage rating (110-115-220-240 etc and a number 45 -55 60 uf etc
it will have either 2 terminals or 4 terminals connected as pairs
from what you describe it is a capacitor problem
May 26, 2016 | Airwell Fedders Fedders C1048bbd3vf 3...
Common size capacitor for 2 ton units
if you are looking to buy capacitors to make money,the only way to make money is by repairing the units,if you are doing that,then you dont need to ask what size,you would know
May 17, 2015 | Heating & Cooling
What size capacitor do i need for a 2.5 ton compressor
Each brand of unit uses different sized capacitors I need a model and serial number of your unit to actually cross reference that part. You could also call the manufacturer of you unit and find out.
Aug 26, 2014 | Heating & Cooling
Toyota Corolla wiper linkage.R.A.C. man replaced a
Get one or more off a car at the salvage yard
Aug 28, 2013 | Toyota Corolla Cars & Trucks
Unit needs a new capacitor and it does not the value printed on it and its not on the label
Short of going direct to the manufacturer and getting the genuine part off them using the model number, it would be very difficult. Compressor size and machine size very often have no bearing on what capacitance the capacitor has... Have a very close look at the capacitor for a uf rating.. this is the value you need. sometimes, it is listed on the wiring diagram which is usually behind the panel which covers the main wiring terminal box on the outdoor unit.
Aug 04, 2011 | Ruud UAKA060 Air Conditioner
I need a manual for an rac2000 satnav
Hi
All updates are done via the Route66 Home Sync. The dedicated RAC page is at www.66.com/rac
http://www.66.com/rac
http://www.66.com/static_media/manuals/Rac/ROUTE%2066%20RAC%20Mobile%208%20User%20Manual_en.pdf
Regards.
Jul 28, 2011 | GPS
Hi, I have Hitachi model: RAS 63CHA4/RAC 63CHA4 The indoor unit looks working for the fan function, but not for the other function. The fan on the outdoor unit looks not working. What is the problem?
Is your compressor is working? If so, check motor to rotate manually. If hard to remove, replace bearings or motor. If easy to rotate, replace capacitor.
If your total out door is not working, check for power in out door unit. If not communication error between indoor and out door, provided you keep in right setting. If so, replace your indoor PCB.Helpful?
Jan 15, 2011 | Hitachi Heating & Cooling
I just bought a new compressor for my a/c but the store sold me the wrong capacitor. I need a dual capacitor but don't know how to read microferets to get the correct capacitor. Can you help me?
Do you still have the original capacitor for the unit. They probably gave you the size you need for the compressor. It should have the microfarads printed on the capacitor. The symbol resembles a strange looking u. Then look at the capacitor that came with the unit and get the microfarad rating for the fan. Now you will have the too readings you need to get a capacitor. The fan motor may also have the size capacitor you need printed on the data plate. Let me know if you need more help.
Jul 03, 2010 | Heating & Cooling
Need Capacitor Size
try calling technical support of the company
Jun 04, 2009 | Intertherm P3RA-030K Air Conditioner
Kenmore 75085 Air Conditioner Logo
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
