Question about Crafts & Hobbies
The glue won't flow out of my glue gun, any advice?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 67 Answers
If it's getting hot, you press the trigger but you get no glue, your tube is stuck. something ( dirt or smthng) blocks the exit. Heat it up, turn it upside down (nose up) and without inserting a new stick, let the heated glue flow iut of the gun. Hopefully any dirt will be forced to fall down. If you need more drastic results, you must open the tool, fasten it on a bench wrench, but make it so that no caurrent will be passing through the wrench, by using two pieces of wood as intermediate holders, plug it to power, nose up. and when it has reached a very hot temperature, use a high pressurized air pistol, to blow out anything that blocks the tube.
Anothe option, is to remove the nose if there is an option to twist it. See if there is a hexagon head. If yes, you cab turn it and eventually clean it up.
Posted on Sep 13, 2010
Bought a glue gun to re cover my lamp. Unfortunatley there was no Instructions
Pretty basic to use. Insert glue stick from the rear, push it as far as it will go without forcing it, if there is room put another one behind it. turn on gun and wait til it gets hot. stand it on something that will not get damaged from the glue, a piece of cardboard for example, you should see glue start to drip through the tip. now press trigger (gently at first until glue is really hot) and glue will flow, the longer the gun is on the glue will be easier to get flowing. release trigger and glue will stop, (although a little will still come out) When there is room always place a glue stick behind one already in to help the continuous flow of glue. That's pretty much it really.
Jan 17, 2014 | Master Appliance Crafts & Hobbies
How to use sterling mini glue gun
you get what you pay for, i hope you can learn to use it well!
Dec 26, 2011 | Crafts & Hobbies
I have a glue gun (brand = POWER CRAFT a german product stated) I forced the glue stick into the gun to use up what was left of it and now I cant get it out. Its completly stuck inside the gun. Is the...
i actually did this to one of my workshop guns i found the best way to fix it was to heat the gun up using a hair dryer and then pushing the old glue back up the tube and out and now when im not using the guns i take the glue stick completely out
best of luck
merry christmas
Dec 07, 2010 | Crafts & Hobbies
How do i insert glue stick in to my emhardt electric glue gun
Insert the glue stick into the back of the gun. After doing this plug in the gun and allow it to heat up. When the gun reaches the correct heat level you will be able to pull the trigger of the gun which will pull the stick into the gun. This will only happen if the gun is hot enough.
Aug 16, 2010 | 3M Polygun AE II Hot Melt Glue Gun
Reattaching a rearview mirror on a BMW
Small little trick, Clean everything well and wipe it with acetone.  Use your hot glue gun to glue it back on.
Works actually pretty well.
I hope this helps
Feb 19, 2009 | 1996 BMW 318
Glue Gun Support
Plug the glue gun into an electrical outlet. Make sure it is placed in a secure place, away from flammable items. As the glue gun heats up, a little bit of glue might drip from the end so you won’t want to leave it on a wood table or on carpet. Insert a glue stick into the back of the glue gun. If the glue gun already has a glue stick in the chamber, keep a second one in reserve nearby. Gather the materials you want to glue together. Hot glue works exceptionally well on thick fabrics, dried flowers, Styrofoam, wood and plastics. Since it leaves a thicker residue, it is not the best choice for thin papers, fabrics and ceramics. Check to see if the glue in the gun has melted by squeezing the trigger slightly and touching the tip to a test piece of paper. If the glue comes out easily, the glue gun has heated up fully. If the trigger is hard to pull, wait a minute more for the gun to heat more completely. Pick up the glue gun and squeeze the trigger slightly while you draw a thin line on one side of the item to be glued. Immediately place the other object to be glued on the glue line, pressing firmly. Hold the two pieces together for about 15 seconds. Test to see if the item still holds when you remove one hand. Let the item set for a few minutes in order to “cure.” Once the glue has dried fully, use a fingernail to scrape away any of the excess glue.
Aug 27, 2008 | Dremel 1550:30 Versatip Tool Kit
Crafts & Hobbies Logo
1,770 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
