Question about Singer Sewing Machines
Singer 507 sewing machine is not sewing correctly on top of fabric, fine underneath, any ideas
    Genius:
  • 1,788 Answers
Check your bobbin threading, it is usually the opposite of what you think.
Posted on Sep 13, 2010
Hi there. I have a singer 507 machine which was sewing fine until I changed thread in bobbin and now the feeder teeth are not moving to feed thE fabric thru, not sure what I may have done - Help!
the bobbin has nothing to do with the feed teeth
however it is possible that at some point you moved the forward /reverse knob lever to middle where the teeth will not move
Jan 03, 2017 | Singer Sewing Machines
My Singer Curvy sewing machine tension is not working. No matter what setting I set the dial to the tension never changes. There is none. My machines stitches look ok on top of the fabric, but bunch up...
try a new needle
make sure the bobbin is turned the right way in the bobbin case
rethread the machine top and bobbin
if these suggestions don't help, then the machine needs to be checked
Oct 20, 2013 | Singer Curvy 8770 Electronic Sewing...
The bobbin housing in singer model 9410 keeps moving out of position
After you put the bobbin case in, release it, and then pull on it to make sure it is in correctly.
The gathering is called a "bird's nest", and is caused by the machine not being threaded correctly.
Rethread the machine top and bobbin.
Then, sew a test stitch on a scrap of like material.
Apr 08, 2013 | Singer Sewing Machines
Singer 507 sewing machine - material wont feed through
if the fabric won't feed thru then there is something wrong with the feed dogs
May 25, 2012 | Singer Sewing Machines
I own a Singer 258, the needle does not pick up the bobbin thread
is the needle the right one for the machine?
is the needle & thread correct for the fabric?
it's possible that the machine is out of time & would have to be retimed by a sewing machine shop
Apr 02, 2012 | Singer Sewing Machines
The top stitch is fine but underneath the thread is all balled up what might be the problem
When the thread is bunched up underneath, the problem is often in the top tension. The top thread is pulled through to the bottom but because there is no tension, it isn't pulled back up correctly, creating large loops underneath.
Try making sure that the thread is lying correctly between the tension disks (you can just see them inside the machine on the downward thread path). Lifting the presser foot lever (behind the machine) opens up the disks and lets the thread slide between them more easily. They will close again when you put the presser foot down to sew. Make sure you always thread the machine with the presser foot lever up and tension disks open to avoid this problem in future.
If the thread is running correctly between the tension disks, just check that you that there's no fluff caught in there, holding them open. Give it a blow, or run a folded pice of fabric through there.
Nov 26, 2010 | Singer 2259 Sewing Machine
When making a straight stitch or Zigzag stitch, makes loops underneath the fabric This is for a Singer sewing machine model 5817c
Your top tensioner is too loose.make sure the thread runs through all the relevant eyes and then tighten the top tension little by little as you do a sample few stitches.
Feb 21, 2009 | Singer 5050 Mechanical Sewing Machine
Singer CE-100 Embroidery thread bunches up underneath fabric
I had this problem and it all came down to using the wrong backing. I kep trying to use tearaway on everything but WRONG. Using the proper backing corrects most problems. Good Luck!
Oct 30, 2007 | Singer CE-100 Futura Computerized Sewing...
Sewing Machines Logo
202 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
