Question about Bulova Watch
How to set calendar to correct date - Bulova Watch
  • 831 Answers
Thank you for contacting FixYa.
You can get Bulova instructions here:
http://www.bulovaspecialmarkets.com/service/servicecenter.aspx
Best regards. Jewel
Posted on Sep 13, 2010
Has no leap yr. went from 2/28 to 3/1 cannot coordinate time
  • Auto Calendar (pre-programmed until the year 2039)
that means, you need to set up correct year in order to show leap years.... and then it will show you also correct day, after you will set it up correctly..... http://support.casio.com/storage/en/manual/pdf/EN/009/qw1545.pdf
check page 2
Mar 02, 2016 | Casio DW-5600E-1VCT Wrist Watch
Tip
How To Set The Time/Calendar For Your Seiko Watch
<span style="font-weight: bold;">Time Setting for Models Without Calendar</span><br /><span style="font-style: italic;">Note: When setting the minute hand of a quartz watch, advance it a few minutes ahead of the time and then turn it back to the exact time.</span><br /> <ol> <li>Pull out the crown all the way. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Time/Calendar Setting for Models With Calendar</span><br /><span style="font-style: italic;">Note: The date will change gradually between 9:00 PM and 4:00 AM. For some models, however, it will change instantly when the hands pass the 12 o'clock marker at midnight.</span><br /> <ul style="font-weight: bold;"> <li>For models with date calendar</li></ul> <ol> <li>Pull out the crown to the first click.</li> <li>Turn the crown until the previous day's date appears in the calendar frame.</li> <li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol> <ul style="font-weight: bold;"> <li>For models with day and date calendar</li></ul> <ol> <li>Pull out the crown to the first click.</li> <li>Turn the crown until the previous day's date appears in the calendar frame.</li> <li>Turn the crown in the opposite direction until the desired language (bilingual) for the day before the desired day appears in the calendar frame. <span style="font-style: italic;">Note: For Cal. 7009 and 7019, push the crown back in to the normal position and then push it repeatedly to set the day.</span><br /></li> <li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date and day appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Note:</span> Do not change the calendar between 9:00 PM and 4:00 AM as it may not change properly. If it is necessary to set the calendar during that time period, first change the time to any time outside those hours, set the calendar and then reset the correct time. When the day shifts automatically to the next day, the other language will temporarily appear.<br /><br /><span style="font-weight: bold;">Note:</span> When setting the hour hand, check that AM/PM is correctly set. The watch is designed so that the calendar changes once in 24 hours.<br /><span style="font-style: italic;">Turn the hands past the 12 o'clock marker to determine whether the time is set for the AM or PM period. If the calendar changes, the time is set for the AM period. If it does not change, the time is set for the PM period.</span><br />
on Feb 15, 2011 | Watches
Is there any way that I can set my Seiko perpetual calendar watch at home?
What a great watch! It has a super-fine piezo-electronic motor to move the date wheel! Very cool. Its quite a show to go through the date/leap-year check, and then observe the watch catch back up to the correct time afterwards. Battery lasts ~five years.
I downloaded the manual (your model number on watch back) after a short search online (beware of trojans/viruses).
Setting after a battery replacement requires shorting certain pins inside the watch to set the leap-year, and date. The back unscrews, and may require the special watch-wrench, available online. I unscrewed mine VERY CAREFULLY with fine pliers, confirming that I was doing this in a clean, dust-free location. The instructions are quite specific, must be followed carefully to set up correctly. Have a fine wire jumper to set the leap-year. I learned this because I did not want to pay an inexperienced jeweler $100 to replace the battery.
Oct 13, 2014 | Seiko Watches
The calendar skipped ahead a day and I can't get it back to where it reads the correct date. Can you help?
Pull the stem out to the time set level. Turn the hand around until the date change. Now push the stem back in, pull to date set level and change to current date. Now the watch is at midnight for that current date. Note you can set to current time of day. The Watch will automatically change to correct date for next day at midnight as it should.
Oct 17, 2013 | Michael Kors Watches
I replaced the battery. The watch started time from Jan. 1
You have to set the year, the month and the date. Then you set the time zone. After that you can set the local time. You may also have to set the Daylight Savings Time.
The watch has a built in calendar that may run from let's say January first 2000 to the year 2070 (just a guess). If you set the calendar correctly you do not have to adjust the date when a month has 30 days, or when it is a leap year.
Sep 27, 2013 | Casio GW330A G Shock Solar Atomic Watch
I cannot set the calendar for this watch...can anyone help me?
mcdevito75 here, Your watch (Timex) may have a 2 position stem. Push the stem (winder) all the way in, NOW just lift the stem a little to it:s first position, this should allow the date, (number ) to change, change that number to the date before the date you want, NOW pull the stem out to set the hands, rotate the hands to set proper date and time.
Jun 28, 2010 | Timex T Series Perpetual Calendar #T2M458...
I just bought a new watch and am having with the calendar
Check that you have set the time at the correct AM or PM setting. If this setting is wrong it may appear that the date is changing in 12 hours because it sees 12 midday as 12 midnight.
If this resolves the issue please do take a moment to rate my answer. If not please use 'Add comment' or 'Continue with this Expert' to post up the details. I will be happy to respond.
Thanks for using FixYa.
Jan 05, 2010 | Citizen Watches
Changing the date on a timex perpetual calendar watch
You can download the Perpetual Calendar instructions from Timex's website here.
If you don't like clicking on a link, here's the URL:
http://assets.timex.com/instructions/perpetualCal.pdf
Hope this helps. If this solution has been what you needed, please take a moment to rate it a fixya, and thanks for asking here!
Mar 11, 2009 | Timex Watches
Indiglo WR 30M
i wind the clock hands forward until the calendar date and week day changes and then i re-wind the hands until it comes to the correct time. when i re-wind the hands, the week day goes back to the correct date and the calendar date does not go back by one day. i don't know if this is the "correct" way to do it, but it works.
Sep 12, 2008 | Timex 27191 Wristwatch
Bulova Watch Logo
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
