Question about Vacuums
Our Rowenta iron model # Dx 8800 comes on then shuts off in the vertical position after a minute or so. It seems the auto shut off is bad?????
  • 1,711 Answers
Yes the so called auto shut off is only a small thermostat cost 8-10$ and need to be replaced
Posted on Sep 13, 2010
I have a Windsor Sensor s12 and power shuts off after 5 min. of vacuuming. I'm wondering if it's overheating of if there is some other sensor that causes it to shut off.
Your Sensor most likely has an internal heat sensor that is shutting off the motor. Some vacuums install an external heat sensor with a reset button that you must push to re-start the vacuum. If your model does not have an external reset button it is most likely a sensor inside the motor. If it is defective the motor must be replaced to solve the problem. But first make sure the overheating is not being caused by a blockage somewhere or the bag is too full. Air must pass completely through a vacuum starting at the floor where it picks up the dirt through all the canisters, filters, bags, etc. and then is exhausted from the vacuum. Any restrictions or blockage can cause the motor to over heat.
That Vac Guy
Jan 04, 2013 | Windsor SR12 Sensor Bagged Upright Vacuum
I need to replace the plug in cord on my rowenta iron. I would replace but I paid $130 for iron and my cats have chewed on the cord so I thought it "might" be a simple replacement.
This is the second cat-chewed-a-wire question tonight.
The only thing to do is to replace the entire cord. You could cut out the chewed section and splice it with **** connectors and electrical tape, but you have a nice iron with a 12' cord. I believe Rowenta uses Torx screws on their irons.
Rowenta has customer support and a list of service centers online:
If you are in the U.S., go to:
http://www.rowentausa.com
and then click on the 'CUSTOMER SERVICE' link on the gray bar below center of the page.
In the 'After Sales Services' column, click on 'Service Centres' and look for one close to you. Perhaps you can order a new cord and use the old cord as a chew-toy decoy.
Good luck from Detroit, MI.
Jul 11, 2011 | Vacuums
Iron shuts off intermittently during use, therefore it won't steam. Before we go any further does this site charge for this service?
No charge for my answer, but you can contact an Expert on this type of appliances and discuss it further.
Jun 20, 2011 | Rowenta Vacuums
I have a white powdery substance coming out of the steam vents of my Rowenta iron. How do I get rid of this stuff?
The iron has white flakes coming from the steam vents.
The white flakes can be caused by calcium or other minerals in the tap water. To solve this problem, switch to bottled spring water. Once the water is changed it may take several uses before your iron adjusts to the new mixture and the issue is corrected.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | Rowenta Vacuums
Rowenta Effective DX 1700 model---won't spray water?!
Mine was getting slow to steam, downloaded a manual (could only find model #1900, but close enough), and found out how to clean- fill with water, heat to the highest temp, hold over the sink horizontally and hold the steam lever over to the "self clean" position for one minute. That's supposed to purge the system of junk. Manual site: http://dl.owneriq.net/2/28c59722-2a7e-45ae-b333-c20240d7e9f5.pdf It's a free download.
Dec 29, 2010 | Vacuums
My steam iron is spitting out brown liquid and I've ruined several tops. I have a Rowenta Air GLide Stainless Steel Model #DZ 1700. I have misplaced the instruction booklet. It has a...
Run white vinegar through the iron over the sink with iron on high & steam button pressed down. This should dissolve any minerals that build up in it. Then run water through it over the sink to rinse the vinegar out.
Dec 07, 2010 | Rowenta Vacuums
I need a customer service manuel. i lost the one that came with the iron when i bought it. it is probably called an instruction book.the model # is 273 .i hope you can hep me get one. thank you for any...
Can't quite track that down by the model number you show, but if you go to this URL:
http://www.rowentausa.com/rowenta/frame.aspx
there is information on an Effective iron that looks pretty close. There are downloadable files in the lower left hand corner. You might have better luck than I did tracking the model number you have at this site as well.
If this solution was helpful to you, I would appreciate a Thumbs Up from you.
Be well, Paul
Oct 05, 2010 | Rowenta Vacuums
Vacuums Logo
19 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
