Question about Panasonic Panafax UF-595 Plain Paper Laser Fax
Panafax UF-4000 Recently this fax machine has started printing multiple copies of the same document received. How do I stop this?
  • SMadmin Jun 05, 2008
    and some customers cannot send a fax to us at all, their machine reports an error.
    The phone co. does not see trouble on the line (checked the line remotely)
  • SMadmin Jun 06, 2008
    This is a UF-4000. One particular customer is in our speed dial, and is still not able to fax to us. I do not see an option for "selective reception mode". I have fax parameter IN MODE set at "Tel" and the OUT MODE set as "Fax".
    I have unplugged the electric and phone line several times. hooked another fax to the phone line and received faxes slower, but successful.
  • 319 Answers
Which model do you have...Panafax UF-4000, or Panafax UF-595?
Thanks
Brian
Posted on Jun 05, 2008
  • Brian Berndt
    Brian Berndt Jun 05, 2008
    It sounds like your second problem (and some customers cannot send a fax to us at all) is related to the "SELECTIVE RECEPTION MODE" In this mode you are trying to stop junk mail from being received. So if the fax transmitter is not on your speed dial list, then you may not be able to receive the fax.
    I am working on your double print problem, but I am sure that it must have to do with a setting for receiving faxes. (Print 2 pages instead of 1)
    Sergeant:
    Champion:
  • 310 Answers
Restart the fax and check it out
  • khader ibrahim Jun 05, 2008
    restart the fax and check it out, let me know or if you have any other questions, just ask have a nice day
Lost the Copy and Fax Receive Function
Hi Vic,
I'm sorry to say your fax machine has a bad LASER unit. A laser error code will stop all print functions. The laser units are no longer available.
Sep 15, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Copy Function not working
You need to reset the machine back to factory defaults
Turn machine off
lift up doc feeder and hold down the pointed switch by the scanner glass while turning the machine back on until it beeps.
Close doc feeder
scroll down to SHIPMENT SET
press SET
SET
wait for the machine to reboot.
Aug 04, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Can i re-print the document form the memory of the fax machine?
no, you can only print out a journal to show what fax number it came from.
Aug 03, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
Jun 05, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
Incoming faxes do not show time or date
function-7-4-start-9-start-2-start-stop
this should print the time and date on the paper
Jan 22, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Panasonic Panafax UF-885 - Heavy lined marks down side of paper
First print a report to see if the lines appear without using the scanner. If this is the case clean the charge wire. If you pin it down to the scanner, it is probably a poor solder joint on the cis unit. Take it out and run a hot soldering iron over all the joints on the reverse side of the cis.
Apr 15, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Fax Error
If this is a uf8000 please follow these instructions.
fuction-7-4-start-1-2-start-2"always"-start stop.
the journal will print every time you fax out now
have a good day and good luck
Feb 15, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Rcv to memory password
No 2 manufacturers use the same method. However it is unlikely that you need a password. To print the contents of the SAF memory, it requires a simple procedure. Either there is a resume button, or sometimes use the copy button or the start/copy button. Let me know which machine it is.
Feb 06, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Panasonic Panafax UF-595 Plain Paper Laser Fax Logo
253 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Electro Med Services...
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
