Question about Ubi Soft Capitalism 2 for Windows
I bought Capitalism II about 3 or 4 years ago (Can't Remember). Initially I had a different version of Windows back then. I quit playing the game for quite a while and recently wanted to play it on my new PC which is running on Vista. It just gives me an error saying "Cap2 has stopped working". I even downloaded the patch 1.01 and when I run it, it saying Cap2 not installed. I browsed the game via. Comrade and it said that the game was running a up-to-date version. Kindly advice.
5 Suggested Answers
issken
  • 1472 Answers
SOURCE: crashes to windows after playing about 5 minutes
Most likely the issue you are having is your computer is under powered to run both Vista Home Premium and the game. Vista is heavy on the resources and since you are running Vista Home Premium you will need more then some running the Basic version.
So the easy fix would be to up you memory upto 2 gigs. Note best practice for Vista is to have atlest 2 gigs of ram in the system.
If you still have trouble I would test the game on another Vista computer with a 2.0 or higher CPU to see if it still has trouble. If it does not then most likely it will not work on your computer.
Also if you did an upgrade from XP to Vista you might have so Windows issue. So if the test on the other computer worked you might try a fresh install of Vista to resolve any possible Windows issues.
Hope this helps
Issken
Posted on Sep 18, 2009
  • 55 Answers
SOURCE: Capitalism works so slow
Check your computer configuration against the recommended hardware requirements for the game.
Posted on Mar 10, 2010
SOURCE: i have an older hp laptop(dv7-3079wm) and i play
sounds like you went from xp to vista...try installing a second partition with xp or win 7....vista has a known problem of doubling video memory in the system memory....so if your running vista on a laptop, you are straining the system from the get go
vista seems fast, for a little while
GOOD LUCK AND PLS RATE THIS POST!!!
Posted on Apr 07, 2011
TKahill
  • 89 Answers
SOURCE: How do i make heroes of might and magic v work on
Try running it in compatibility mode, and if that doesn't work you could also try messing around with some other settings near compatibility mode. I had to do this for an old game called Diablo 2, but it's easy enough to do.
Find the game's launcher, either the desktop icon or the .exe file. Once you find this file, right click on it and in the menu that comes up, select the tab that says compatibility. Here, check the "run in compatibility mode for" and select Windows XP, since that is the OS that you are sure it works on. If that doesn't work, try messing with some of the options too, like the resolution and display scaling. For some odd reason, those make a difference sometimes. I remember Diablo 2 having a strange combination required to work on Windows 7 for me.
I purchased gutterball 3D YEARS AGO HAVE NEW Computer AND DIFFERENT INTERNET SERVER. i HAVE RECEIPT AND REGISTRATION KEY NUMBER. I PAID $19.95 WITH CREDIT CARD.PLEASE HELP TO REINSTALL THIS FUN GAME.
So you have a newer version of Windows. You need to choose Compatibility mode when you install it. The internet server is irrelevant to loading and playing the game.
you can play online here and also download a newer version.
http://www.addictinggames.com/sports-games/gutterball3d.jsp
Apr 19, 2016 | Computers & Internet
Geme set:: se id ()
I had the same issue.
Find the "My Games" in "My Documents" and then enter the folder called "Capitalism 2" in that folder you will see a file called "Config.dat"
Delete that file and then restart Capitalism 2 and you should no longer get the error and should be able to play normally, without having to reinstall or lose any save games.
The path to the correct folder is:
C:\Users\yourprofilename\Documents\My Games\Capitalism 2
Though it may be different depending on your version of windows.
Apr 04, 2010 | Ubi Soft Capitalism 2 for Windows
Crashes to windows after playing about 5 minutes
Hope this helps
Issken
Sep 18, 2009 | Ubi Soft Capitalism 2 for Windows
Ps 3 problems with game play madden 08 franchise mode
This sounds like you might have a dirty lens. clean your ps3's lens with any CD/DVD cleaner kit and then try to play the game again.
Feb 13, 2009 | Sony Playstation 3 (PS3) Console
When I bank right or left with joystick the screen Freezes
To check the joystick isn't the problem, go into control panel game controls, then check that the joystick appears and you can move the cross-hair around on screen, most modern joysticks are
auto-calibrating, but you could try running the calibration.
To check the game isn't a problem, unplug the joystick, then use the arrow keys to fly the plane, if it doesn't crash when you bank then it isn't the game.
I assume the game is Combat Flight Simulator 3, as very old games that were written for Windows 95,98,ME series often won't run on Windows NT,2000,XP,Vista as they are completely different versions of Windows. If this is actually Flight Simulator 3, you may need to consider buying a later version of Flight Simulator (FSX is the latest version, but may not run on your laptop).
Other things to try are updating the graphics card driver.
Norton shouldn't need deactivating, although it could cause problems if you're playing online.
Also remember that laptop graphics cards are never as powerful as desktop graphics, and games very rarely specifically support laptop graphics.
Hope this helps.
Jan 21, 2009 | Logitech Extreme 3D Pro Joystick
Hot shots golf out of bounds troubles
This happened to me as well. The first time, my PS3 seemed to hang during the second update. The next time, I quit the update because I thought the system was stuck in an infinite loop. Turns out that it isn't.
Start from the beginning by deleting the game data file from the PS3 hard drive. Boot up HSG:OOB and wait for it to install. This takes a while, as I think it is something like a 5GB install. When it is finished, go into the game and select the Online option.
You'll see the "Checking version" message followed by a couple of status bars. Depending upon your connection, the update can take anywhere from 30 minutes to over an hour. Just walk away and come back to it. When it is finished, you'll be told to press the PS button to quit and then restart the game.
Once back on the main screen, you should see a version # that wasn't there before, on the right side of the screen. You might want to write this number down.
Go back into the Online option. Once again, you'll see a "Checking version" message followed by a couple of status bars. It looks the same as the last update, so you might think this is an error. It isn't. Apparently, rather than updating once to the latest version, the game is going through a series of updates (2 or 3 of them). It's like taking Windows 95, updating it to Windows 98, then updating it to Windows ME, and finally updating it to Windows XP.
Wait for the update process another time or two. For me, each subsequent update took less time. Something like 20-30 minutes for the last one. When you are asked to quit and restart the game, check the version on the main screen. It should be different than what you wrote down after the first update. For me, my updates ended with ver. 090311201. Finally, I was able to select online and it didn't check the version but asked for my login info.
Whenever they update the game, I'm sure we'll have to download the update once again...but hopefully each new update will be minor. But those people who purchase the game brand new will end up going through even more updates with each passing year.
Dec 28, 2008 | Sony Hot Shots Golf: Out of Bounds
Laptop crashes every time I play a video game
Have you made 100% certain that you have the right driver. The laptop versions of nVidia cards are different to their desktop counterparts.
They use the suffix of "go" and the drivers normally have to be obtained from the laptops website.
Apr 12, 2008 | Quicksilver , Mac ATI RADEON 7000 64MB...
Ubi Soft Capitalism 2 for Windows Logo
197 people viewed this question
Top Ubi Soft Video Game Consoles & Games Experts
dante
Tom Chichester
MegaByteMe
MegaByteMe
Are you an Ubi Soft Video Game Console and Game Expert? Answer questions, earn points and help others
