Question about Zodiac BARRACUDA G3 IN-GRND CLEANER
We found out tpday that we have 19 leaks in our inground pool liner which is not quite 2 years old!! The only thing we've changes this year is we purchased a Barracuda Robotic pool cleaner. Have you ever heard of these robotic cleaners causing damage to a liner??? Thanks. Connie
  • 990 Answers
It will have a strong suction to the pool floor and could grind bits of sand into the liner. You might want to try a Arneson Pool Vac.
Be sure they put cork feet on it though so it goes easy on the liner.
If and when you replace the liner be sure to put an under-liner down first. This will help with problems that run along these lines.
Posted on Sep 14, 2010
How do you detect a pool leak
put on a mask and go look for bubbles coming from the liner. sometimes there will be a small dip under the liner where theres a leak
Aug 26, 2017 | Pool & Spa
Tip
////////////Detecting The Hole In A Leaking Pool Liner////////////
Pool liner has a hole in it....you keep adding water far too many times a week running up your water bills far to high....you call a pool guy and he recommends a "Diver" to call, when you call the diver you fall through the floor when he tells you the initial cost no matter whether he finds the leak or not.
This is what i have learned from the experts....had a pool diver come over and all he did was 'Nothing"...he charged me $400.00 took out and resealed my lights...broke my brick stones around the pool in various places due to his removal of the air tanks, talked a good line of balogna, took my check and left....left me $400.00 lighter in my wallet and no better off then I was before concerning my pool liner leak, he even told me after he came back to find it three times again that the leak was all in my mind and that the dropping of the water level was due to evaporation... this is all good fior someone who is new to a pool...but I have had this inground pool for 10 years prior to him telling me he usually always finds the leaks....he did not and tried to cover his inadequecies with a ration of bull stories...I was adding at least 2-3 hundred gallons of water everyday whether it was hot out or cold out, and this only started happening after about 10 years of owning the pool, in this case it didnot pay to have someone dive the pool because when you can see a real strong discoloration in your liner and the water level starts to drop all of a sudden every other day to at least 1/2-1.0 inches it is time to replace the liner.
If you have a newer then 8-10 year old liner by all means have it tested before you replace it, a cheap and inexpensive way to do this is to start at some point... I would first buy a $4.00 rubber plug to plug up the bottom drain....see if the water level drops...if it does problem is someplace else if it stops dropping the prblem is in the drain lines and that can be an expensive fix for an inground pool short of just leaving it plugged and never using the bottom drain feature again.
If the drain plugging doesn't fix the problem try blocking off the lines with plugs one at a time until you find the level stops dropping indicating which line is culprit, including the skimmers and please be sure you leave the filter off while doing these tests.
If none of the above finds the leaks get in the pool and being very still discharge a small puff of red food coloring under water around the light lense frames...trying to see if it gets sucked into a leaking area, also around the stair case if so equipped doing the same thing with the dye around the seams etc.
You may even find the filter is leaking at a joint causing the leak, or like i once found.... little under ground critters ate my skimmer lines... they punched pin holes into the rubber buried lines with there teeth...they were small moles, nocturnal like rodents that burrow under ground causing havoc on anything that is buried beneath the surface....I found this problem easily...the ground all of a sudden became wet and damp and eventually started to pool up with water for no apparnt reason...when I dug into the water pool I found a little gusher of water coming from the lines, these critters ate into the lines...had to cut them and couple them with a sleeve for the fix.
on Sep 17, 2010 | Plumbing
Tip
How to Last Minute Rush an Inground Pool Vaumning
Did you ever want to just get the pool vac'd., without getting out the robot if you even have one, or pulling out the vacumn and hooking up the hoses, having to purge all the air out of the system just to get it ready.....you know the drill....and to make matters worse its real hot out!!
her's what i have found in my years of pool cleanup blunders, Put the pool selector valve to pool drain, get a long adjustable handled pole with a leaf type pool brush attachment, very slowly push the grit on the liner towrds the pool drain, do it gently and stop, wait until the smokey looking water clears(this means it went into the drain port and is being filtered out in the cannister).
Do this to the entire pool but dont rush it, after you are done check the PH and Chlorine etc. adjust, backwash the filter if your filter has a backwash system, and off you go onto another home project, this one just saved you a ton of precious time!!!
If you have the inground pool cartridge filter system you should remove the filter/filters and hose them out twice a year to keep them clear, when they start to look and act dirty and they cant get clean by hose take them to a pool pro and ask him to chemical bath them, thisfilter problem will be noticable when you see the pressure rising too high on your filter tank, it means the filter/filters are getting clooged and need attention.
Happy Homeowning!!
on Jun 14, 2010 | Pool & Spa
I have a Hayward Super Pool pump for my inground pool. Was running the pump, heard a noise, by the time I got over to the pump to check it it shut off. It has been off for over 2 hours. It is not hot....
Get another brand. Hayward is junk. I had the same exact thing happen. Of course warranty is only one year. I paid out of pocket to replace the motor. Guess what happened 2 years later?
May 08, 2014 | Hayward Pool Products Hayward Northstar...
My Ray Vac is 2 years old. What is their average
You should be able to get your pool shop to rebuild this for you, usually just for the cost of parts. Then you should take it in to them once a year to be checked as prevention is worth more than cure. Good luck.
Dec 19, 2009 | Jandy Ray Vac Pool Cleaner for Inground...
Inground pool liner
need to drain the pool pull up the trim see if you can stretch the liner back into position (works best on hot sunny day doesnt work at all in cold weather). Alot of pools have a u shaped groove the liner goes into then plastic tubing is hammered into the groove (a similar application is screens for windows and the spline that holds the screen in place). I also use a shopvac to "pull a vacuum" on the liner to help pull into sides of pool before filling. If your liner is more than a few years old or was trimmed too short you are probably out of luck
Aug 04, 2009 | Jacuzzi Cyget In Ground Pool Pumps
Lossing Prime
It's pulling in air very slowly from somewhere:
priming pot lid,
valve body tops,
valve handles,
pipe unions, --
check gaskets/o-rings-- replace defective ones, lubricate
tighten everything possible
Apr 10, 2009 | Hayward 1HP Super Pump II Inground Pool...
Pinnacle 1.5 hp inground pool pump making a lot of noise- it's only 2 years old and at the end of last season was much louder than it should be
Is pump moving water at a normal rate and pressure? If so, then you are in need of a bearing replacement. There is no specific lifetime for bearings or shaft seals, however two years would be at the lower end of scale. Have front and rear bearings replaced along with shaft seal.
Apr 09, 2009 | Pentair 1.5HP Pinnacle High Performance...
Zodiac BARRACUDA G3 IN-GRND CLEANER Logo
216 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
