Question about Cycling
I just needed to know what the recommended air pressure is for an avalon 7 speed men's bike from Walmart?
    Genius:
  • 1,788 Answers
Look at your tire,on the side wall it will tell you what amount to put in. Do not fill at a gas station, it is made for a car tire, and will blow the tire off the rim. Buy a tire gauge and a decent pump, and watch the bead on the tire to seat evenly as you add air.
Posted on Sep 13, 2010
What kind of tool can be used to remove the kick stand (assembled by walmart) from Roadmaster Granite Peak men's 26"?
any open hand wrench will be able to assist you in this. you may need to use an 8 or 10 mm maybe even a 14.
Jul 28, 2014 | Roadmaster Granite Peak 26" Mens Mountain...
Inner tube tire
Non-standard tube sizes drive me crazy. I did find that WalMart sells the tube on its website:
Walmart 32 Bicycle Inner Tube
This is probably your best bet, as your local bike shop may not stock this tube size because LBS bikes typically stop at 29 inch.
Feb 01, 2014 | Genesis 32" Mens Beach Cruiser Bike, Blue
Schwinnn men's 26 " jaguar
The tires will say on the side-wall, it's likely around 45-50psi.
May 05, 2011 | Schwinn Men's 26" Jaguar Cruiser Bike
Chain Broke on a Huffy Tundra 18 speed 26" bike. I need to know the size chain to replace or the master link/chain connector to fix the chain.
if the bike has gears it does not have a master link, that is for single speed bikes only.
You will need an 8spd chain for your bike (1/2" x 3/32), these will fit any 6,7 or 8 spd bike. This requires a special tool to install ($8-$25), I would recommend taking into a bike shop and have them do it if you have no experience with this type of chain.
Side note: if you do own the tool, you can repair a broken chain for a temporary fix in the future, so may be worth buying. Check around, many bike shops offer basic repair classes and cover this.
Nov 14, 2010 | Huffy Men Mountain Bike (26")
I have a early 1980's honda 750 need to know how much air pressure the fork's hold, or need to put in them.
You do not have to put any air in the forks. There was a sticker telling you maximum pressure on the bike. It may still be there. Maximum pressure is not more than 14 pounds. You will never need more than 7 or 8 pounds. First set the rear shocks for a hard or soft ride. Then holding a bicycle foot pump with a pressure gauge on it in your hands , give it one pump (do not go over 10 or 12 pounds pressure). Now bounce on the seat and bleed pressure out of the forks until the front and rear shocks drop at the same time. Your bike suspension is now set up correctly for riding.
Sep 26, 2010 | 1987 Honda VF 750 C Super magna
Making the bike from a 18-speed to a 1 speed bike
single speed bikes have a single ratchet or fixed sprocket with no offset of the spokes, so you would probable need another rear wheel.
Another derailleur is probably simpler, try ebay
Apr 04, 2010 | Huffy Alpine Men's 26-Inch Mountain Bike
New Mongoose 700c Men's Paver bike: Mongoose 700
Local bike shop determined that both wheels were defective. I took the junk back to Walmart and got a refund... PROBLEM SOLVED!!
Dec 28, 2009 | Mongoose Cycling
I have a schwinn avenue bike purchaced at walmart last fall. i have had to replace spokes on the rear 3 different times.
Either you are riding over some really rough terrain or the air pressure in the tires is too low. Not getting them tight enough will also cause alignment problems and bend spokes. Eric
Aug 15, 2009 | Schwinn Midmoor Men's Hybrid Bike
Gears will not shift to first gear
It sounds like the limit screws on the derailleur are out of adjustment.  If the derailleur cant pobbible move any farther towards the 3rd gear and the cable has slack in it then we know for a fact that the limit screws are to blame.
If you can move the derailleur with your hand past the 3rd gear then we know the cable needs to be adjusted.  I would recommend taking it to a bike shop as those index shifters do take a bit of work to adjust correctly.
Jan 17, 2009 | Schwinn Midmoor Men's Hybrid Bike
Cycling Logo
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
