Question about Amana Refrigerators
My icemaker is not making ice. This has happened 3 times in the past 3 years but this is the longest it has gone without making ice. The other 2 times it lasted 2 days. It has now been 4 daysince the ice maker is not working.
  • Anonymous Mar 20, 2014
    removed icemaker ,and reinstalled unitbut now it will not fill after one hour
  • melvin solis
    melvin solis Dec 08, 2016
    i fix that
    Genius:
  • 1,224 Answers
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
Posted on May 15, 2008
U Line Ice Maker not working at all
if your drain pump is the one you plug your ice maker into and then the pump into the wall plug the pump is full and will not let the ice maker run. must be something wrong with pump
Nov 14, 2013 | U-Line Icemaker
I moved my GE TFX277PFSB (new in 1994) side by side to my enclosed sun porch 2 years ago when i got a new fridge for the kitchen. Today, I decided to run a water line to it to allow it to make ice again. ...
Make sure the arm on the icemaker is in the down position,if it is up and locked in place the icemaker is off. If it is down and the icemaker is turned on,each time it got cold enough the to cycle the icemaker(usually about a hour) the icemaker started and for 7 years power was sent to the water inlet valve to fill the icemaker and the icemaker side of the water valve is burnt up. The water valve has 1 inlet teh house water supply attaches to and 2 outlets 1 for icemaker and 1 for door dispenser
Gene
Aug 07, 2011 | Kitchen Ranges
The ice maker just stopped making ice today. It's made ice great for the past 3 years. Everything else works.
If the water pressure for water through the door is low I would check your saddle valve that taps into the line. I would next check your icemaker fill tube to make sure it is not frozen. If it is then you will need to replace the saddle valve because it is due to low water pressure.
You can try to manually harvest the icemaker by turning the power switch off-on-off-on and then pushing the lever in three times in a row. This will harvest the icemaker. If the icemaker harvests and the rake moves then its most likely still good. (if theres a batch of cubes frozen in the ice maker then its def bad.) If you get it to harvest and no water comes in then you will know its a water supply issue.
Replacing the inlet valve and saddle valve will most likely correct the issue. You may only need a new saddle valve and they only cost about 10 bucks.
Let me know if this helps _MJ_
Feb 07, 2010 | GE GTS22WCP Top Freezer Refrigerator
ICEMAKER WILL NOT DUMP ICE
I'm not making any promises. But after years of selling refrigerators, without having to call a tech...Make sure your freezer is at zero degrees, as the icemaker is activated by temp. not only time. Ice cream should be hard as a rock. Try setting your freezer colder; and don't do the human nature thing by checking every 30mins to see if it make ice. You'll just dump the cold air out. The bucket stays full of ice until the next cycle. That may be why it stalled.
Good Luck,
Jeff
May 31, 2009 | Samsung Refrigerators
Whirlpool Gold Refrigerator (GS5SHAXNLOO) Ice maker not running, some ice in maker melted together
I have the same model. This has happened to me several times (usually when the door was kept ajar without notice).
Simply open the door, take a common hairdryer and blow at high speed (hottest also) all around the area of where you can feel the ice in the tray, but hasn't dumped yet. It will usually take about 5-8 minutes of consistently moving back and forth around that area. What has happened is the lines bringing water to the trays have frozen over. When you "thaw" them out, the ice made will dump in about 45 minutes. When you hear the ice fall, you will know it's in working order again. I have NOT heard this is a "flawed" icemaker, only that it is hypersensitive to freezing lines when a door is left ajar. In your case, to prevent this from happening again. If you shut the icemaker off again, make SURE you turn off the source of the water feed BEFORE you turn off the ice maker. By doing this, the lines will empty as it makes it's last tray of water. Try that - very confident it will fix your problem!
May 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Ice Maker Won't release ice
Jetguy77,
I have a 1993 year (16 years old now) Whirlpool side-by-side with icemaker, Model ED22PW. I have had similar problems with the icemaker - water goes in, freezes, but ice does not eject from tray. It has happened to this unit 2 times since 1993. It turns out the problem is not the thermostat. It is the icemaker motor module. The icemaker has a small synchronous (clock) motor that rotates the ice ejector. When it goes bad, the ejector does not rotate, either because the module timer had failed or the motor itself has failed. The solution is to go to your nearest applinace parts dealer and by a new "icemaker motor module" for Whirlpool Model (your model here). Mine cost $58.85 the last time I replaced it in 2006. To install the new module, you will need to remove the icemaker from the refrigerator. Mine has 3 screws that attach it to the side. Also unplug the power & control cable. The water tube slides out when you pull the unit forward. When you get it out, it is then easy to remove the motor module and insert the new one. You may have to reset the timer on the module to get the tray to fill completely.
Jan 18, 2009 | Whirlpool GS6NBEXR Side by Side...
Icemaker quit working
Hello.
First of all you need make sure that your freezer is freezing enough. Sometimes everything will seem to be freezing ok, but it won’t be cold enough to make the icemaker work. The best way is to squeeze your ice cream, if you have any that is.
Then you need to make sure that the ice level sensing arm is in the down/on position.
If all of this checks out ok, then you need to make sure that nobody turned off the water supply that is sometimes located under the kitchen sink. Also make sure that the ice bucket is positioned properly so as to trigger the ice bucket sensing switch.
If all of this checks out ok, let me know and I can guide you through an icemaker diagnosis by forcing it into a harvest mode.
Nov 20, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerator is making a loid noise
** the y do sound directly related. water is dripping down your ice maker falling on to bucket? well a small amount of water is also falling onto the evaporator fan assy, freezing and the **ise you hear is that fan blade "cutting" through the ice.you can lift the arm turning the Ice maker to the off position, itll stop calling for water,and your **ise should stop as well
Mar 10, 2008 | Refrigerators
Refrigerators Logo
2,382 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
