Question about Savin Office Equipment & Supplies
How do you get rid of lines that are coming through on copies Savin 2518
  • 23 Answers
U PROBABLY NEED A NE DRUM. OR HAVE DFIRT ON LENSES AND MIRRORS
Posted on Sep 13, 2010
Savin c3224
This typically happens when trying to copy currency & certain other sensitive docs on all color Ricoh devices. This includes Savin, Lanier & Gestetner. It may work if you reduce the image enough.
Feb 20, 2014 | Ricoh Office Equipment & Supplies
Savin 9935DPE is printing one thick vertical balck line down the copy or print pages. About 2 of every 3 pages printed. What's wrong?
are you printing from Doc feeder or glas?? if from feeder then try to make a copy from the glass, does it still do it? yes problem is with drum.
No? problem is with the small scanning glass to the left, look carefully see if any spots or lines on the 1inch glas --- clean it
Sep 05, 2012 | Savin 9945dpe 9935dpe 2035dpe 2045dpe...
I have a savin 2518 copier It's printing very light do you have any idears
first take the toner cart out and shake it, if that doesn't cure the problem, you may need to replace the toner cartridge with a new one
Mar 18, 2011 | Computers & Internet
I have a savin 2522 and it has a few lines running down my copies
few fine lines is due dirty optics mirrors and lamp, and it may also came from dirty charge rollers due to dirty/worn out charge roller cleaner, worn out cleaning blade and seal blade. to check this, clean/wipe off toner or dirt from charge roller with cloth wet from alcohol or water. then run some test copy.
Mar 03, 2010 | Savin Office Equipment & Supplies
Can MAC OSX 10.5.x use Ricoh Aficio 1018D? Do you now alternativ drivers for ricoh aficio 1018D. HP LaserJet 5-Gutenprint v5.1.3 is o.k. for A4 but not for A3
this is an older model copier, however try going to www.savin.com and click downloads then drivers. there will be a tab for drivers, this is 10.5 though not snow leopard. Ricoh/Savin/gestetner and Lanier are all the same copier, but savin site has more mac info than Ricoh site. Usually I have better luck using already installed Mac drivers than Gutenprint, if you type in the ip it should give you a list of preinstalled Mac drivers. I believe the Ricoh 1018 corresponds to a Savin 2518 if that helps. Also use print daemon, not ipp. hope this helps somewhat as Macs are difficult with options and such on most printers. also must use PS3 for best results.
Jan 09, 2010 | Ricoh Aficio 1018D Copier
Savin 9940DP ''Set Key Counter''
Key counters are used when a copy machine is set up for public use where copies are charged on a per copy basis. Key counters look like small boxes that plug into the side of the machine and they have a counter on them that looks like a cars odometer. A user plugs in the key counter, makes copies and then takes the counter to a register to pay for the copies they made. Sounds like that is what you have going on.
Nov 02, 2009 | Savin Office Equipment & Supplies
COPIES COME OUT DARK
Have you cleaned the optics, if there is a build up uf dust and grime on the glass and mirrors, the machice will get progressivly darker.
Remove the glass and lens cover, and gently clean the mirrors and scanner reflector, then clean both sides of the glass.
Hope this is of some help.
Ed
May 08, 2009 | Savin Office Equipment & Supplies
Modem fail errors between hp 4345 and savin mfp device
On fax settings set ECM to ON, JBIG to OFF, MAX BAUD RATE to 14.4, V34 to OFF then upgrade to latest firmware and make sure phone line is a 2-line phone line (look plug end of line and there should only be 2 metal strips on connector)
Mar 26, 2009 | HP LaserJet 4345mfp Printer
89 people viewed this question
Top Savin Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
