Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Fisher & paykel top drawer stuck again
Feels like the top drawer came off a runner... Really hard to open and close. Happened once before and resolved on its own. Also noticed coffee ground appearing material on dishes (maybe rubber).
  • andrewandtra Sep 06, 2008
    I have a similar problem, this affects the top drawer and very hard to close , sounds like I am pushing rubber instead of the drawer sliding on its runners.
    What do you suggest ?
  • 145 Answers
Sounds like the lid is not opening all the way. Rubber may be coming off lid seal during opening and closing. Check you lid actuators replace both right and left if needed.
Posted on May 15, 2008
With 2 drawers, when you close the door tightly, it pushes open the top drawer, so the printer feeds from the incorrect drawer
take both drawers out and find the bit of rubbish blocking it up
a bit of paper or a clip or a staple is stuck in a seem ,,, or runner
Mar 05, 2015 | OKI B4600 Laser Printer
Coffee pot not brewing
do you get any display?
Aug 09, 2008 | Cuisinart Coffeemakers
Top drawer won't close
After completing a cycle the top drawer feels like it will not open or the top of the drawer has fallen down. I've since forced it open but, now it feels like it will not close. I did not force it to close. How do I remedy this problem?
Mar 02, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Milk drawer won't close
its the switches there is 2 one on top and one at the back the milk container is not making contact properly because the container needs realigning
Mar 12, 2012 | Saeco Primea Cappuccino Touch Plus Coffee...
My top drawer of my Fisher and Paykel dish washer wont close tight. It seemed to be jammed and not closing unless it was pushed closed hard and then it jumped a bit now wont close tight and has no...
Make sure the unit is level. Remove drawer. On the inside of the cabnet there are the drawer runners on iether side. Behind these there are a pair catches. If one or both of these are latched back when they shouldn't be, ie. when the drawer is open, they will obstruct the drawer from closing fully and fail to hold it closed.
Hope this helps
Dec 13, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Coffee in Cuisinart grind and brew ends up all over counter
once and a while the filter door will come ajar and make the coffee leak all over. (allways try to jigle it open after closing, because fine grounds will make the door not close right) Also if the carafe is not in all the way you'll geta mess too!
Jun 29, 2009 | Cuisinart Thermal DGB-600 Grinder
OPEN TAP message is displayed and the machine will not work
Instructions from Capresso:
-pull out the drawer
-look inside the unit where the drawer has been removed and look for a flap (it's really the first thing you see on the left side)
-without moving the flap, reach your hand under it and up until you feel a flat surface
-this surface will have grounds on it
-feel for screw in middle
-take paper towel and wipe off grounds
-repeat until paper towel is clean
-replace drawer and done!
-do this about once a week to prevent this
Jun 25, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
Gaggia syncrony compact digital - DREGDRAWER MISSING
the thing that dropped out was part of the micro switch for the dregs draw. Yes you can use the machine with the piece that you put in there, at some time you might consider just replacing the micro switch.
Sep 24, 2008 | Gaggia Titanium Espresso Machine
Problems with LG WM-2277HW Front Load Washer
It is a rare problem but I've seen it happen.  The only way to resolve this issue immediately is to remove the top of the washer to gain access to the dispenser.  The dispenser can be disassembled by unsnapping the top section where the hoses are connected.  Once the top section is lifted, you can safely pull the drawer out.  Not sure what happened but more than likely the water dispenser has warped downward causing it to jam the drawer.  Recommend replacing the dispenser to resolve this problem.
Jul 23, 2008 | LG WM-2277HW Front Load Washer
Saeco royal coffe machine
Clean the central unit whenever the coffee bean container is filled, or at least once a week. If the water hose seems dirty it is probably due to hard water and needs to be descaled.
Descaling is done with a special citric acid you can buy in any grocery store or dealer of such machines. follow the directions and run clean water through afterwards.
To clean the filter:
Switch off the machine and open service door
Remove grounds coffee container .
Remove central unit, by holding the handle and shortly pressing the PRESS key. Wash the central unit with hot water; do not use any solvent.
Make sure there are no coffee residues on the two steel filters: the upper filter can be removed by unloosening and turning the plastic pin anticlockwise using the tool supplied with your device. Dry thoroughly each central unit component, fit the filter again and tighten it properly with the screw .
Remove coffee rest drawer and clean it, using a non-abrasive solvent. Clean the service area thoroughly and fit the coffee rest drawer again. By holding the central unit by its handle, slide it back into its original position, making sure it is correctly engaged. Then close the door. Fit the coffee grounds container again.
good luck, stephen
Jul 04, 2008 | Saeco Royal Professional Espresso Machine
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
454 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
