Question about Microsoft HP Pavilion DV6276US Notebook PC
No picture on laptop there is power but picture
  • Microsoft Expert
  • 393 Answers
U need to repair vga card contact with any repair shope.. or if u have any idea about reworks sation u can repair at home thanks
Posted on Sep 14, 2010
Will not turn on
IF you get a picture of a battery that means that power is getting through to the laptop. So the charger is ok. Try starting the laptop without the battery but with the power connected.
Take the RAM out and refit checking it is secure if not it is possibly the motherboard - expensive job!
Feb 28, 2014 | Computers & Internet
My click botton to take the picture doesnt work, idk how to actually take the picture, am i doing something wrong??
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Aug 14, 2012 | ASUS Computers & Internet
What could be causing my Toshiba satellite laptop not to have picture after it was dropped
Does it display no picture at all or no picture after a certain point? If something dropped on it too hard it may a number of different issues. Here are some things to try.
pull out the battery, plug in the power adapter then try to turn it on. If the same thing happens, unplug the power adapter and remove the RAM. Plug the power adapter back in and power it up. If you do not hear beeps, unplug the power adapter again, remove the hard drive from the laptop. Plug the power adapter back in and try to power it again. If you still are not getting an image and no beeps it may be a motherboard issue.
May 29, 2012 | Toshiba Satellite Computers & Internet
Nothing comes on picture blank
Ok
A few things to try
1.) Check the laptop on an external monitor, do you get a picture
2.) Is there power to the laptop from the battery and the charger? Try to see if the charger indicator lamp is blinking green rather than steady green
3.) Can you hear hard drive / fan noises and are there any lights on the laptop?
If the charger is blinking, indicates that power is not making the circuit, check tightness of charging port, if tight, assume fault on motherboard / blown main fuse
If picture on external monitor and not on laptop, assume backlight on screen dead or possibly the inverter
If no noises from HDD or Fan and No lights on laptop, then fault with motherboard
If you do get fan noises etc, but get BLINKING lights on laptop, assume possible fault with graphics chip, repost with details of blinking lights / colour and specific model of laptop
Jan 12, 2011 | Samsung Computers & Internet
My laptop screen is bright. Brightness control works but no picture. The picture is ok on external monitor. Sometimes a faint and incomplete picture appears on startup but disappears after a few seconds....
This might be a sign of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Aug 25, 2010 | Compaq Presario 700 470024-192 Notebook
No picture
Hit F2 to brighten the screen. No picture could be any one of these things you need to buy.
1. New inverter board
2. New LCD backlight
3. New power board/sound board
4. New Logic board
If the parts and repair labor becomes cost prohibitive, then look into a new laptop, unless your handy and can replace the parts yourself.
Mar 23, 2010 | Apple MacBook Mac Notebook
Picture not responding ,computer freeze
when does this happen? what size picture file, what program? what operating system?
Try more ram, bigger hard drive, or clean out junk on old one, don't try processing big pictures on under powered laptops.
Aug 02, 2009 | Compaq Presario 700 470024-192 Notebook
My Acer Aspire 5610z laptop picture is breaking up + going blank
Replace the screen, you can download the pixel tester softwar to figure out if the screen is going bad. I'm pretty sure it is.
If you change the inverter its either the onboard video card on your laptop (usually not replaceable easily) or the screen.
Feb 18, 2009 | Acer Computers & Internet
Microsoft HP Pavilion DV6276US Notebook PC Logo
54 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
