Question about Yahoo Messenger
When instal then messanger then messege on window, yahoo messenger unable 2 download file, need 4 installation plz creak firewall setting?
    President:
  • 2,291 Answers
  1. Reboot your computer.
  2. Press Ctrl Alt Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab.
  3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation.
  4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list.
  5. Click the "End Task" button. This will temporarily close all background applications on your system.
  6. Click the "X" in the upper right corner to close the Task Manager window.
  7. Install Yahoo! Messenger. You should not experience the same issue that you had before.
  8. After Yahoo! Messenger is installed, reboot your system. All other background applications will return to their original configurations.
download registry cleaner reg in out if the problem is not solved
Posted on Sep 15, 2010
I deleted my old yahoo messenger from the computer and now i am trying to install a new one but its not working, every time i try to install it, it says(yahoo messenger is unable to download files needed...
the error message is clear, for some reason your computer is set to block the Yahoo messenger link.
here is what you can do: (for windows XP)
1. open Control panel
2. click on Security Center
3. click on Widows Firewall
4. click on the Exception tab
5. check if you have Yahoo Messenger there:
a. if not: click on Add and paste the follow: C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe
b. if it's there- make sure it is the same as C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe
if it is the same- click on Delete to remove it and try to install again.
Oct 17, 2010 | Yahoo Messenger
Firewall stops me using yahoo messenger
Uninstall or disable any security software running on your computer. Try restarting your computer in safe mode with networking and then installing. If all of the above doesn't works and still you were getting message for firewall then either disable your Router's firewall by opening Router's page or Bypass router for a while and connect directly to Modem and then Install.
May 23, 2010 | Yahoo Messenger
Yahoo! Messenger is unable to download files needed for install
yahoo!7 messenger is unable to download files needed for installation. Please
check firewall settings and retry installation.
I found the answer its so simple, The problem has nothing to do with firewalls.
Yahoo instant messenger (yim) needs internet explorer 7 or above version to
enable yim to operate properly with the current yim versions. If you have an
earlier version of IE (I was using IE 6 coz I always use firefox and did not
have windows update enabled coz I did not want my windows operating system to be
revealed as it was copied and theredore not legit) So I disabled windows update
and kept using firefox, but even if you never use internet explorer, yim still
needs internet explorer 7 to operate without these errors shown above. I tried
to fix it for weeks thinking it was fiewall or such, but it just needed IE 7 so
I downloaded it here:
http://www.microsoft.com/en-au/download/internet-explorer-7-details.aspx
and even tho it says its for a windows server it still worked on my windows
XP pro 64bit and now yim is working properly, allowing multiple copies of
contacts etc, no problems at all now. I also downloaded firefox version 35,
which helps yim too coz its yahoo preferred.
https://www.mozilla.org/en-US/firefox/35.0/system-requirements/
Apr 02, 2010 | Yahoo Messenger
I try to open yahoo messenger but this comes out "yahoo messenger.exe failed to initialize."
1. Uninstall your Yahoo Messenger
2. After uninstall completed go to My Computer - Program Files and delete Yahoo folder.
3. Install again Yahoo Messenger from www.yahoo.com
4. Install latest adobe Flash player from www.adobe.com
5. Install latest JRE version from http://java.sun.com/javase/downloads/index.jsp
6. In a command prompt window type command: del %temp%\*.* /f /s /q
7. Restart your computer.
After all of this if your problem continues check for operating system errors.
Mar 05, 2010 | Computers & Internet
Unable to download files needed 4 installation
Go to Start>Control Panel > Add or remove programs remove all the things related yahoo ( Yahoo toolbar, Yahoo mail advisor, Yahoo installer, Yahoo browser plus etc.) Try download and install then....If still same try download offline installer http://download.yimg.com/ycs/msg/dl/msgr10/us/b4/msgr10us.exe
if still you are having difficulty download old version like Yahoo messenger 8 or Yahoo messenger 7
I think it will help you..Further result please let us know... Thanks for being with Fixya...Good Luck
Nov 10, 2009 | Yahoo Messenger
My computer tells me that a firewall is blocking yahoo messenger
**** the firwall dude download yahoo messanger with standlon offline setup its very easy installation and no need internet . type yahoo messenger 9.0 offline installation setup k its free and you can install yahoo with in 10-20 sec k without any error if you like my ans plz reply with thx it will improve my rank
Nov 03, 2009 | Yahoo Messenger
Yahoo messenger is unable to download files needed for installation. please check your firewall settings and retry installation ?
Simply close the Firewall for little moment till installing the YM files.Go here Control Panel> Windows Firewall>click Off(not recommended)
Try now. Good Luck
Oct 13, 2009 | Yahoo Messenger
Unable to Install Yahoo! Messenger Firewall Issue or What?
The problem is with the Yahoo uninstall software which fails to clear the old Messenger folder out and creates conflicts with the incoming new software - Your firewall doesn't know whats happening and hoists a red flag. If you had not started to uninstall I would have recommend you download revo and uninstall with that.
http://www.revouninstaller.com/revo_uninstaller_free_download.html
bear this in mind if you manage to install messenger but still have problems
You have to go into your C drive and delete the left behind software
Click ( > ) Start > Computer >> Local disk (C) >> Program files >>Yahoo >> Messenger - if you have Vista the folder should be empty - if you have pre- Vista the only sub-folder remaining should be 'Profile' ( The message Archive file) manually delete everything except 'Profile' by right clicking and deleting. When finished restart your computer and finish the install
Aug 07, 2009 | Yahoo Messenger
Yahoo messanger installation
Problem:
"Yahoo messenger is unable to download files needed for installation. Please check firewall settings and retry installation"
Solution:
I tried to solve this. I went through alot of forums. I uninstalled Yahoo messenger and tried installing new one. I downloaded and pressed "Run as an administrator" when i got this response
"Yahoo messenger is unable to download files needed for installation Please check firewall settings and retry installation."
I did the following:
Turned of Windows Firewall( Search )
Uninstalled Yahoo messenger
Downloaded New One
Used CCLEANER to clean the computer. Download CCLEANER from www.filehippo.com
Then I checked INTERNET EXPLORER:
Tools->Internet Options->Connections->LAN Settings -> Click on Automatically Detect Settings (Unclick everything else except this option) ->Apply -Ok
Check if www.yahoo.com opens in Internet Explorer.
Now Install Yahoo Messenger.
It should work.
Thanks
Oct 04, 2008 | Yahoo Messenger
Yahoo Messenger Logo
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
