Question about ESA E4000 DVD Player/VCR
Need an instruction manual for ESA E4000 DVD/Video CD
Can I record on vcr mode from a DVR recording?
Robert, give it a try and see if machine is capable.
Mar 01, 2016 | ESA E4000 DVD Player/VCR
I have an esa tv model EF420E. What channel does it need to go on in order to watch DVD's and play on the Xbox?
I assume you have the DVD or XBox connected to the composite video or S-video ports on the EF420E. These can only be accessed with a remote control that has an Input button. The original remote had the Input button near the middle of the remote on the right side of the remote. Pressing it allowed you to toggle between TV, Video 1, and Video 2. If you do not have the original remote or the remote's Input button doesn't work, you need a replacement remote or an universal remote with an Input button. (Many of the cheapest universal remotes don't have this feature button included.) A replacement remote is available from http://remotes.com/store/esa/ef420e.html . They have the original remote and a guaranteed to work alternative. If you choose to get another universal remote, you may need to try multiple codes until the Input button works for your TV. (Try Funai codes, if ESA isn't a listed manufacturer.)
The ESA EF420E was built by Funai. The manual is available from Funai Service: http://www.funai-corp.com/support/manuals.aspx . The direct link to the manual is http://www.funai-corp.com/support/om/EF420E.pdf .
I hope this helps.
Oct 30, 2014 | Televison & Video
Esa owners manual
good luck. I can't find one either.
Jan 05, 2012 | ESA E4000 DVD Player/VCR
DVD drawer won't open after playing a film. Film plays fine, but now we can't get the darn DVD out!
Disc have something sticky attached on top (label ,specially rental discs') so when you try to eject disc get stuck on tray of spindle motor.Top cover need to be opened in that case in order to remove disc
Aug 23, 2011 | ESA E4000 DVD Player/VCR
I had a stroke while I was in hopital for a month, Family helped move and downsize things. The operating maual was missed placed, would it be possible to geta new manual.
Go to product website, support section and search manuals for your model. This downloads are usually free. Hope that helps..
Jul 15, 2011 | ESA E4000 DVD Player/VCR
Burned digital videos from my computer on cd-r disk.when i try playing i get bad disk displayed. Retried on another disk got same result.
CD-R is mostly for data/MP3/audio and is not ideal for videos unless its a Video CD burned with the right software and the player accepts that format for playback.
Try using a single layer 4.7GB/120 minute/4-16X DVD-R instead for video. Your player probably does not allow CD-R as video but may allow it as MP3 data. Unless you have the original source video, or the discs contain raw data which can be read/used on a PC, throw them out.
Apr 16, 2011 | ESA E4000 DVD Player/VCR
How can I change my esa 400 player to work from channel 4 from channel 3?
Check on the back of the unit for a small switch. The switch should be in position 4. Move the switch to 3. Good to go.
Read Ya,
Z
Dec 31, 2009 | ESA E4000 DVD Player/VCR
Double image playing DVD's
check your picture in picture, sounds like your dvd imput is set for split screen, dvd on both sides
Apr 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
ESA E4000 DVD Player/VCR Logo
331 people viewed this question
Top ESA Televison & Video Experts
Brandon Murphy
Are you an ESA Televison and Video Expert? Answer questions, earn points and help others
