Question about Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune washer mod.mah5500bww will not dispense bleach and softener. I recently installed flood proof hoses and would like to know if it is possible that there is reduced water pressure and it is affecting the function of the dispenser?
The letters ''od'' show up after it shuts off
Posted on Sep 13, 2010
Bleach and fabric softener dispenser will not empty out. Have rinsed the container but problem persists
hello, so you cleaned out the dispenser and cleared the holes under the dispenser cap. low water pressure or blocked fill valve screens can cause this problem also. remove the hoses from the back and make sure the screens are not blocked. hope this helps..ken
Jun 07, 2011 | Maytag Neptune MAH7500WH Front Load Washer
We have a Maytag front load washer Model MAH 4000 AWW
tHE PROBLEM IS YOU NEED TO CLEAN YOUR SOAP, SOFTENER AND BLEACH DISPENSER, REMOVE THE BLEACH AND SOFTENER DISPENSER TRAY, AND YOU WILL FIND THAT IF YOU HAVE BEEN USING LIQUID SOFTENER, THAT IT HAS GUMMED UP AND CLOG THAT AREA AND IS CAUSING SPILL OVER. WHEN THE WATER IS POURED INTO THE TRAYS TO DISPENSE THE BLEACH AND OR SOFTENER.
Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
Bleach wont drain during washing
You may have a clog on that side where the water comes into it, or the dispenser valve is not opening that side.
There is a service sheet inside the bottom of that front lower access panel on the right side wall, you can go through the diagnostics to test the water flow to that side of the tray.
Feb 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Neptune Washer dispensers
Replace the wax motors for both the bleech and softener
Sep 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Bleach/softener dispenser
Try to push a plastic straw through the hole in the dispenser. This hole could be blocked with lint.
Oct 21, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH8700AWW Front load
I have a maytag neptune front loader (MAH8700AWW) unless I turn the water off @ the faucet the water continues to run into the washer after the load is done .How can I fix this.
Oct 20, 2007 | Maytag Neptune MAH5500B Front Load Washer
Bleach and Fabric softener not dispencing
One thing that I did was to clean out the filters on the inlet hoses.  This increased the water pressure to the machine and improved the situation.  I am still having trouble with the bleach dispenser.
Oct 08, 2007 | Maytag Neptune MAH6500A Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
234 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
