Question about Optimus Audio Players & Recorders
Optimus 710 stereo system wont function. get error code 0.
How to solve the error of canon iR2016 photocopy system error E003?
How to reset E000, E001, E003, and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" then Press "Stop" or "Additional Function key" to end service mode or restart the machine.
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
Canon IC-MF6530/6550/6560/6580
No reset procedure is required, replacing the fuser is the only repair.
Canon D860 series
Press Additional Function key and the "#" key in that order. Go to Printer (number 7), select "Set", Select "Printer reset" and press "set".
Canon Printer Support Phone Number
Dec 06, 2017 | Canon Office Equipment & Supplies
Optimus stereo receiver universal remote codes
go to link below and click the green "Notify Me" button when this item is stocked. We will inform you when we put one in stock. You must purchase a new OEM remote, universals will not work. OPTIMUS STA3750 3760 Remote Control
Apr 17, 2014 | Optimus Sta-3750 Sta-3760 Stereo Receiver...
Both mini speakers are playing, but not getting any sound from the base box.... what might be happening?
The mini sub woofer's amplifier is not working but the other amps powering the left and right channels are ok.
Nov 28, 2013 | Klip Xtreme KSS-710 2.1 Stereo Speaker...
Error code 0x80004005
Dear Expert Team, I want to connect my Bluetooth Wireless Head Phone to System the error code is mentioned below
ERROR CODE 0*80004005 (Model No BH-503)
so,How can i connect please give me a solution.Please email me tirumalasettymouli@gmail.com
Aug 05, 2012 | Nokia BH-214 Bluetooth Stereo Headset
I need a user manual for an optimus system 738 micro stereo component system 130-1286
i have one call if you need it!! 2076919126http://www.fixya.com/imageupload.aspx?f=images
Sep 03, 2011 | Optimus 738 Shelf System
How do I know if I have a CD player in my Volvo 850? There is a CD button but when I press the CD button it says "EEEE" my audio system is the SC-710. Any help would be greatly appreciated.
Apparently you do not have a CD changer connected to your radio and that is why you get an error when you press the CD button. However sometimes it's an error code and means that you need to reenter the code for the radio. Is there a place to put in a CD? If so, here's a link to some info on your radio and entering your code.
http://www.volvo-forums.com/t16110-cd-changer-error-code.htm
Mar 10, 2010 | 1997 Volvo 850
Olymus 710 will not focus error code 5e02
as your powering up slap the camera in the palm of your hand, the lens is out of adjustment
Feb 20, 2010 | Olympus Stylus 710 Digital Camera
Has system error E808, not listed in error codes in manual. What's this & how do I fix?
Hello sir; That's fuser error, try to reset hopfully can help you;
press "additioal function" "2" "8" "additional function" keys in that order,enter sssw 1, bit 3, press print change value from 0 to 1 , or from 1 to 0 then press print, should be take care of it.
Dec 05, 2009 | Canon imageCLASS MF6590 Copier
Olympus Stylus 710 Problem with lens
Turn on camera. Blurry pic. Wirly grinding noises. Blue screen.
Codes on blue screen:
5 f 0 8
5 e 0 2
5 f 0 8
5 e 0 2
Sometimes smacking the **** out of it fixes it. Today it doesn't seem to do the trick any more.
Suggestions?
Sep 07, 2007 | Olympus Stylus 710 Digital Camera
100 people viewed this question
Top Optimus Audio Players & Recorders Experts
Larry Stiles
Larry Stiles
Craig Butler
Craig Butler
Are you an Optimus Audio Player and Recorder Expert? Answer questions, earn points and help others
