Question about Cameras
Problems using camera
Recently I came across a Nikon N 2000 camera with a self focusing 35mm Macro lense. I was told all I had to do was put the f stop at f 22 point and shoot. This is confusing to me as I did not get a manual for the camera, so I can not look up any information as how to use the camera. I do not have the confidence in myself just to point and shoot as i have always had a camera that i had to focuse first. I do not wish to waste film, it is a nice heavy camera and would like to use it for Macro picrure taking. Can you please help me?
Thank you
Tom
  • PopPop1 May 15, 2008
    Thank you Alllen, I will give it a try, I am 71 Y/O and getting very forgetfull, cant seem to remember things any more.
    Tom
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey PopPop1,
The N2000/F301 should be a manual focus only camera. The autofocus version of this camera was called the N2020/F501. The lens you have should still work on the camera, but you should have to focus the camera manually. I have an autofocus camera and whenever I shoot macro images I would much prefer manually focusing anyway.
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 15, 2008
Macro focus
That is correct. None of Nikon's 70-300mm lenses are designed as macro lenses. They won't focus closer than about 1.5 meters or 5 feet.
May 20, 2012 | Nikon D7000 Digital Camera
What type of film would I use for a dakota rz 2000 35mm ? And do you think that its worth 80 dollars?
The camera itself uses standard 35mm film. You choose the "film speed" according to what you intend to use the camera for, but ISO200 is easy to obtain and good for most things.
The Dakota RZ-2000 is simply awful. It's a very cheaply made design and suffers from really poor build quality and has dreadful, image-blurring and very noisy mirror slap. Th lenses it was originally supplied with were also of inferior quality. I personally wouldn't buy it at any price, but it's certainly not worth $80 when better quality, major name (but older) 35mm models are now effectively often worthless and can be obtained for nothing on FreeCycle and Freegle. I get all of my 35mm equipment from there. Recently I've even had perfect, boxed and near-unused Nikon and Canon Autofocus models, but I personally prefer the older manual focus SLR's such as the excellent Olympus OM1n.
Sep 22, 2010 | Quantaray Dakota RZ-2000 35mm SLR Camera
Camera will not focus in auto focus mode and when it is focused manually it will not recognize that it is in focus. The instruction manual doesn't cover this case and I was wondering what was wrong with...
You need to have a compatible lens to be able to autofocus. Some older Nikkor lenses and even more so 'generic' lenses (ie. Tamron, Sigma, Opteka etc.) do not autofocus or can be used with Nikon bodies.
Check that the lens is compatible with your camera.
Jun 19, 2010 | Nikon N55 35mm SLR Camera
I need a manual for AF 35-70mm f2.8 D zoom nikkor - no idea how to use this lens.
i was not able to find a manual - this review may help http://www.kenrockwell.com/nikon/3570.htm
The lens consists of
  1. Zoom
  2. Focus
  3. Aperture
  4. Macro
1) Zoom - this is by push pull - so you push the lens out to wide angle 2) To switch to manual focus - will need to be done on the camera and then you can use the front control ring to focus - 4) also you can use the button to switch to macro mode - BUT only with the Zoom at 35mm - lens fully extended 3) You have an aperture range of 2.8 - 22 this varies the amount of light allowed into the lens - 2.8 is the most light - F4 to F5.6 to F8 - each change halfs the light allowed in - so changing from F4 to F5.6 half the light
Mar 29, 2010 | Nikon 35-70mm f/2.8D AF Zoom-Nikkor Lens
What type of lens works with this Nikon N8008s AF 35mm SLR? Thank you, Larry
Any of the Nikon Auto Focus(AF) lenses should work fine with it. There are also a number of fine aftermarket lenses made for your 8008, by Sigma, Tamron, Tokina, Quantaray and others. Be sure you get the Nikon AF lenses, as they make the same lenses for Sony and Canon. You cannot use the Lenses made for another brand, as they will not fit, work right, and can damage your Nikon.
Jan 25, 2010 | Nikon N8008 AF 35mm SLR Camera
I'd like to purchase a micro lens for my Nikon camera. My question is: Does the Phoenix AF 100mm f/3 5 Macro Telephoto Lens used with Nikon D 90''
If the Phoenix lens is autofocus (AF) in Nikon mount, it will work with the D90. You may find that you want to switch to manual focus when you are using it for macro shots for better control of focus. It will still set exposure properly when set to manual focus.
Apr 03, 2009 | Cameras
Lens for Nikon D60
I will try to help you, but please understand that my experience is with Nikon film cameras. Assuming that the D60 works in a manner similar to a Nikon 35 mm body and that Sigma macro lens work like Nikon macro lens, you should be able to determine the usable subject to lens distance by experimentation. First, make sure the lens is in the macro mode. To do this you must set the auto-focus mode control to the manual focus mode (see your manual). On Nikon lenses, you must first set the focus ring to infinity, then move slider switch, which has two positions marked; "normal" and "macro., to the macro position. You should now be able to rotate the focus ring to the macro range. Use the zoom ring to zoom in and out and focus with the focus ring. The the range over which the lens to subject to lens distance will yield an in focus image will be rather limited and in the range of an inch or so to 6 or 8 inches.
Dec 09, 2008 | Cameras
Digital camera
There are non Madhu
No Diagrams No Parts in the main
These items are made as disposable in the main
The components are too fine for mere humans to fiddle with.
Jan 25, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
135-400mm lens on nikon d40
Unfortunately, this lens is not supported by the D40 due to Nikon's unfortunate decision to leave out the autofocus motor from this camera.  This is why I tell folks not to waste their money on the D40 - access to the many, many, many lenses that Nikon has made over the years, many of which are available used for a substantial savings, is lost on this camera.  The only Nikon lenses that work are AF-S lenses, and some third party lenses that have their own internal motors.  I got a list of Sigma lenses that are compatible with the D40 for you:
The list of compatible Sigma lenses for the Nikon D40 as of the current date is as follows:
  • 10-20mm F4-5.6 EX DC
  • 12-24mm F4.5-5.6
  • 17-35mm F2.8-4 DG
  • 50-500mm F4-6.3 DG
  • APO 50-150mm F2.8 EX DC HSM
  • 70-200mm F2.8 DG MACRO
  • 80-400mm F4.5-5.6
  • 100-300mm F4 DG
  • 120-300mm F2.8 DG
  • 300-800mm F5.6 DG
  • 14mm F2.8 EX
  • 30mm F1.4 EX DC HSM
  • 150mm F2.8 EX DG
  • 180mm F3.5 EX DG
  • 300mm EX DG
  • 500mm EX DG
  • 800mm f5.6 EX DG
from here:  http://www.imaging-resource.com/NEWS/1177682545.html
Sorry for the bad news.  The cheaper thing at this point may be to sell the D40 and get a D80.  I personally have a D70S, but that is no longer made.
Dec 06, 2007 | Sigma Zoom Tele 135-400mm f/4.5-5.6 APO...
Cameras Logo
99 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
