Question about Nintendo Wii Console
WHEN I MOVED I LEFT THE WII IN TACT AND ONLY UNPLUGGED THE CABLES FROM TV. NOW WHEN I HAVE HOOKED IT UP AGAIN IT IS IN BLACK AND WHITE? WHAT DID I DO?
  • 26 Answers
You did nothing wrong, i had a similar problem, but then i realized that i plugged the cables into the TV in to the HD Ports.... you need the Wii's HD connector cables for HD. sounds like you had a HD TV and just plugged it into the wrong ports.
try the other ports till you get what you want, or try buying the wii's hd cable, does not cost much if you buy from like k-mart or walmart.
Posted on Sep 14, 2010
I previously had my wii on an older tv and it worked fine. I recently purchased a new tv (Sharp Quatron Aquos) and when I hooked up my wii and same cables to the tv, my screen is now a hazy black and white...
You are using composite cables(red,white,yellow) mine did the same thing. The aquos is all digital, wont read analog, which is what composite cables are.
They now make a component cable for the wii. I paid $28 at b.b.
Mar 12, 2011 | Nintendo Wii Console
Wii game hooked up to new Sharp LED tv. TV is color and the wii is in black and white.
Usually this is either a cable or a mode issue. First make sure that you have the correct cable connections. (Composite video cable to a component video jack is one possible cause of the problem.) Component video cables are not included with the set but will give better results. However, composite video in from the wii's composite video out should give good results.
If you are using HDMI or component video cables, then go into the Wii video menus to select the correct mode for your tv. Check your TV manual and the Wii setup guide for details on the mode (resolution, etc) you should be using.
If the problem persists, try new video cables and make sure that they are fully seated on both sides. Try switching inputs if you have several available.
I hope this helps.
Jan 22, 2011 | Nintendo Wii Console
The picture appear black&white. I have HDTV.
I had this problem with a 'universal' console component video cable. Had a B&W Wii screen, and couldn't set the Wii to HDTV.
Spent most of an afternoon switching the Wii between LCD televisions, annoying Samsung tech support (who are a very, very good tech support system, by the way) and so on.
Took back the cable and the guy said, "Did you remember to turn the little TV/HDTV switch here?"
There IS a tiny little switch on these combo cables, right on the common point of the various console connector plugs. I switched it. It worked. All is good again. Hope so for you too.
Dec 28, 2010 | Nintendo Wii Console
I just got a brand new Wii for Christmas and when I hook it up to my tv it just comes in black and white or very fuzzy colors any suggestions on what to do?
You might want to check the cables connected in to the back of the tv mainly the yellow a.v cable. If you absolutely have it hooked up right its either your a/v cables are something wrong with the wii console itself and since its brand new I would take it back. I would make sure its hooked up properly first maybe even try it on a diffrent tv.
Dec 27, 2010 | Nintendo Wii Console
New Wii is in black and white on my Samsung tv...any suggested fix?
    What to do will depend on how you're connecting your Wii console to your TV.
    • With the yellow, white, and red AV cables that came with your system:
      • Did you have to use the red/green/blue inputs on your TV because it doesn't have the standard (yellow) AV inputs.
      • If this is your first time hooking up the Wii console or have you moved it to another TV, Our experience shows that many times this issue can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
    • With the blue, green, white, and red component cables (sold separately):
      • Review our step-by-step Wii Component Cable to make sure the cables are properly inserted and that your TV is set to the proper input.
    If you have verified the connection is correct, and are still receiving a blank or black and white screen when powering on your Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700
Dec 26, 2010 | Nintendo Wii Console
I plugged our wii into new tv. the screen shows a black and white picture. how do i fix it?
      • Did you have to use the red/green/blue inputs on your TV because it doesn't have the standard (yellow) AV inputs... if this is your first time hooking up the Wii console or have you moved it to another TV, . Our experience shows that many times this issue can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
Having just installed a new Wii console I have good sound but everything is in fuzzy black and white - no colour at all. What should I do to get colour?
      • Review our step-by-step Wii Component Cable connection guide to make sure the cables are properly inserted and that your TV is set to the proper input.
TV went to black and white when hooking up the wii
You probably don't have something hooked up right or connected all the way. If you are using component video cables, make sure that all of the different plugs are plugged into the matching socket on your TV. Also, make sure you have your TV on the right channel (3 or 4) if that's how you have it setup.
Otherwise, you will want to look at the input settings on your TV and make sure you are receiving the correct input, and if you have your Wii plugged into a VCR instead of directly to your TV, try hooking it up directly to see if it works.
If that doesn't work, try using a different TV - especially if it's a TV you know works in color with a Wii. If it is still in black and white, you might need to take it back to the store and exchange it for a new one.
Nov 23, 2009 | Nintendo Wii Console
Hi, I just purchased a Samsung series 3 330 model#LN40A330 I'am having problems with the AV inputs on back of television. I hooked up a DVD player to Component 1 it works fine Then I hooked up Nintendo...
I figured it out,
The solution to my problem was to update my video cables for my new HDTV.
I found out through trial and error that I can only have one Anolog device hooked up to the TV because with two Anolog devices hooked up the same way it must confuse the TV somehow making one of the inputs showing up in Black and White, So I purchased the color coded AV jacks and everthing works like a charm now.
Jun 21, 2008 | Samsung Televison & Video
Color picture for my wii
maybe the component cables are not working, try buying a new component cable.
Dec 26, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
116 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
