Question about Royal VF1700MX Shredder
Loud noise plastic gear stripped - Royal VF1700MX Shredder
    Genius:
  • 1,218 Answers
For replacement parts and prices give Royal a call at 1-800-524-0799 , they will help.
Posted on Sep 29, 2010
  • Anonymous Sep 29, 2010
    For replacement parts call Royal at 1-800-524-0799.
Maytag top-loading washer sometimes loud griding noise mvwc300xwo
The nut that holds the main biggest pulley under machine has worked loose. Depending on how long it's been grinding, pulley and splutch that gears on pulley seat against may need replacing. Use lock tite when putting pulley nut back on.
Sep 08, 2017 | Maytag Washing Machines
Have a clicking noise in the right rear panel of my 2006 Envoy xl. Have had a new battery installed and a new alternator. The noise stays on all the time when the key is turned on . HELP!
That is a electrically controlled actuator for the rear HVAC - heating ventillation an air conditioning system . Mode door or temp. door actuator . They are plastic an the gears wear an strip .
Loud clicking sound from rear of 2003 Trailblazer EXT
2004 Chevy Suburban Rear Air Temperature Actuator Blend Door HVAC You would have to do the same thing to replace yours .
Jun 06, 2017 | Cars & Trucks
Where is the fuser located on MXC 311
The fuser unit is located in the right hand side of the machine. If you open the right door, inside the upperpart of the machine you will see 2 grey handles, 1 towards the front of the machine, the other towards the rear. If you pull these handles out you can then remove the fuser unit. There are 3 known faults for loud fuser noises,1 is the fuser drive gear inside the machine strips the teeth on it, second, the main drive gear in the rear of the machine strips the teeth(usually caused by the 1st problem getting broken teeth stuck in the remaining teeth causing the drive motor to strip the main drive gear) & thirdly, the pressure release mechanism breaks on the fuser unit itself. If it is any or these then unfortunately you will need the assistance of a dealer to replace the damaged parts.
Hope this helps.
Dave.
Oct 13, 2014 | Sharp Office Equipment & Supplies
Printer making a loud clicking noise when printing.
the feed roller gear is stripping; remove the cover and, adjust the gear retainer before it completely fails. (it should be easy to see the gear once the printer cover is removed.
Mar 30, 2010 | Dell 1700n Laser Printer
Loud clicking noise from dash whenever heat
I have and 2002 with rear air and had the same noise and problem in the back. There is motor in the back that moves a flapper door open and closed to blend the hot and cold. The motor has plastic gears in it and they strip out making a clicking noise when the motor cannot hit the point that the heat control dial is being set too. Probably the same set under the front dash. You will more than likely need to by a new motor assy.
Mar 27, 2010 | 2003 Ford Explorer
Loud noise from JD-21 ice maker
Usually a stripped gear or a bad icemaker motor. Remove the icemaker front cover by using a flat screwdriver to pry it off between the bottom of the icemaker and the cover. Inspect the icemaker to see if the large white plastic gear has any broken teeth or is cracked in the middle. The motor is in the 10:00 position of the white gear. If the gear is ok, and the noise is coming from the motor, replace the motor.
After unplugging the refrigerator you can remove the motor assembly by removing three screws in the mounting plate, and then two screws holding the motor on. The parts house also sells the complete icemaker, however your refrigerator is already 29 years old if I am reading your model number correctly. Good Luck, Appliance Specialists
Jan 01, 2010 | Kenmore Refrigerators
Loud ticking noise, dash, passenger side very annoying
That ticking noise you hear is an HVAC actuator that has failed. It is a small motor with a plastic gear and the gear has stripped causing it not to open/close as it should.
Aug 30, 2009 | 2008 Chevrolet Silverado 1500 2WD
Rear heater making a clicking noise
You are not going to be happy. There is a servo motor that moves the door. The clicking noise is the little plastic gear stripped. Yes....plastic. And I belive that servo motor is expensive, especially for a plastic gear.
Jul 25, 2009 | 2003 Ford Expedition
2000 dodge durango locks
the electric door lock actuators are failing replace the ones that are making the noise.
Mar 08, 2009 | 2000 Dodge Durango
Royal VF1700MX  Shredder Logo
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
