Question about Samsung YP-T10 Digital Media Player
It wont play anything
I turn on the mp3 but then it turns off even though its charged.
  • 8,596 Answers
Reset, upgrade the firmware - if the problem persists then this is a hardware issue and will require replacing. Sry.
Reset and then do a firmware upgrade if the problem persists.
http://www.samsung.com/us/support/download/supportDown.do?group=&type=&subtype=&model_nm=YP-T10JAB&language=&cate_type=all&dType=D&mType=FM&vType=R&prd_ia_cd=03040200&disp_nm=YP-T10JAB
Posted on May 30, 2008
After I downloaded songs onto my mp3, when i turn it on it says "GPX" and wont let me do anything else. It wont even turn off. what do i do?
db:: 4.22::why wont my songs play on my mp3 player ax
www.hivmr.com/db/axxs1akj89ss7zs8zmf11d9kmzzj33fa
I download my music, extract the .rar files then take the new folder that has the.mp3s and ... Is there anything i can do to convert the songs to play with the MP3 player? .... LIST ONTO A CD AS AN MP3, BUT I TUNES WONT LET ME AND SAYS ALLSONGS ..... DB:3.37:Nomad Muvu Cannot Format And Mp3 Wont Turn On 37.
db:: 4.31::mp3 player wont play f7 - Hivmr
www.hivmr.com/db/spxap11fkpmm9jss18kz9skc8c8mj977
I have an mp3 player which is usually good but for some reason wont let me ... Howdo I download Itune songs in a format that will play on my mp3 player? ... on Windows 8 after it has been copied to your new computer, or the MP3 can't play the music. .... my stereo will play the songs from Itunes if i burn them onto a CD-R..
MP3 write protect removal - Forums - CNET
Dec 28, 2015 | GPX Audio Players & Recorders
Icoustic mp3 player wont turn on even though it is fully charged
Try to check power cord or else try to check your power switch.
Oct 09, 2017 | Audio Players & Recorders
MY COBY MP3 WONT TURN ON EVEN AFTER CHARGING AND
The most common cause is a flat battery. There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Mar 27, 2010 | Audio Players & Recorders
Fully Charged Sony NWZ-E436F Doesn't Turn On
did anyone ever get back to you on this? I'm having the same problems.
Jun 28, 2009 | Sony NWZ-E436F MP3 Player
How can I reset my zodiac mp3 player?
I once had a similar issue and found that the switch had to be on. If yours has a switch as well as a button to power on you should check it. If it won't even turn on to play stuff or anything you might try checking the battery. Lithium ion batteries have several built in safety features that disable the battery if it gets too hot or gets overcharged, or even if it runs completely dead. It has a built in power monitor that can run the last bit of power out and that can also disable the battery. Ideally li-ion batteries should be stored with 40 to 60 percent charge and kept refrigerated to maximize their life span. At room temperature they lose about 20 percent capacity per year. If all else fails you could try running a virus scan, unlikely though.
Feb 15, 2009 | Mach Speed Zodiac MP3 Player
My samsung mp3 went though the washing machine and wont turn on.
Might be a lost cause, but you could try putting it in a bag of dried rice. Maybe for a day or two. You should have done this right after it came out of the washer so I'm not sure it will do anything. It's worth a try though.
Jan 17, 2009 | Samsung Yepp YP-T9 Digital Media Player
Mp3 player wont play songs or anything
Only 2 suggestions here: 1) Make sure your HOLD switch is not enabled. 2) Try to update the firmware If neither of these work, time to send the unit back to Sandisk
Aug 09, 2007 | SanDisk Sansa e250 MP3 Player
Samsung YP-T10 Digital Media Player Logo
75 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
