Question about Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I have a 5 hp troybilt pony tiller. The axle seals need replacing can you describe the best way to replace them. This tiller was built in Feb. of 1990.
  • 26 Answers
Http://www.mtdparts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10101&catalogId=19502&langId=-1
Go to this website and type in PONY for your model number and find your operator manual by your serial number. The operator manual should have detailed instructions on how to replace your seals.
On the Horse model you remove the wheels and then carefully use a couple of screw drivers to pry out the old seals being careful not to scratch the wheel shaft sealing area. Then polish the wheel shaft with fine emery cloth to remove any sharp edges. Then grease the wheel shafts and carefully slide the new wheel seals on and use a piece of plastic PVC pipe cut square that will slide over the shaft and gently drive the seal to the depth the old seals were installed at. You dont even have to drain the gear oil. Getting the wheels off the wheel shaft is sometimes a problem if they are rusted on. if you can get the wheels off its not to hard to change the seals.
Frank
Posted on Oct 07, 2010
NEED A MANUALC FOR TROY BUILT PONY TILLER THE ONLY NUMBER.I CAN FIND IS 20512CT
You can get this manual directly from the troybilt.com website. A lot of manufacturers have their manuals available and just out of curiosity I checked there and in they do have tillers like the one pictured here. Enter pony tiller in the search box and you'll get a page of their different models. Click the one you have and it opens into another window showing the tiller, and beneath it is a bar with "overview" Specs" "Accessories" and "Parts & Manual" You can download the manual and - "yippee!!" - it's even free.
May 18, 2014 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I am currently looking at buying a troybilt horse with serial # 340455. Can someone let me know what year this is?
That tiller was made sometime between 7/1/78 and 1/1/79. This is the Horse II model and is a four speed one belt tiller. The Horse I was a two speed two belt tiller. These are very good tillers if they have been reasonably taken care of.
Frank
Sep 30, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Need a manual th1003 serial number 83233 troybilt horse
Ebay has manuals that they say are for all troy bilt tillers on cd for $6.99 free shipping.
May 24, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Where is the model number on my troybilt rear tine tiller?
If it's as old as mine (circa 1976), it's stamped on the casting right below the T-handle that allows the handle bars to pivot (also the gear case fill cap)
Mar 28, 2010 | Troy-Bilt Pony Garden Tiller
I need to replace the seals on my Troy-Built Pony tiller. 6 hp, ser.# 121811201149. I can not seem to remove the tine shafts. I have pulled the bolt thru the shaft but cannot budge it. Does anyone know...
I presume you opened the port and removed the grade 8 placement bolt? If you have then you need to polish the shafts with 400 then 800 sandpaper, clean then lube them before trying to slide thru the support bearings. If your tine shaft is bent? your screwed, or just remove the shaft seals with a screwdriver and replacing them without removing the shaft. REmember to put a thin coat od RTV arround the outer lip to help make a better seal
Nov 15, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Need free repair manual down load on Troy Bilt Junior 500 30 82
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
Free manuals for Troybilt here
May 17, 2009 | Troy-Bilt Pony Garden Tiller
Wheel shaft seals on troy bilt pony 7 hp.
If the seal fits over the axle shaft it should be ok. be sure your axles are very clean as not to ruin the new seals when applying them. probably a good idea to replace them as a pair (right and left side) to save you time down the road.
Oct 20, 2008 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy Bilt Pony 6.5 Hp Rear Tine Tiller Logo
1,588 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
