Question about Weather King Heating & Cooling
How many tons is a 10AJB60A01. What size house is this unit made for?
  • 3,361 Answers
5 tons.
60,000btu.
5,000 square feet of cooling space.
Posted on Sep 13, 2010
Comfortmaker 10 HVAC output size?
Comfortmaker 10 means simply it is a 10 SEER system. Unable to determine the OUTPUT size without the Model Number. Go to the Outdoor Unit Nameplate and locate the Model No. Here is an easy way to determine the "SIZE" of the "Comfortmaker 10 HVAC" Systems:
Model No.: OUTPUT Size (Nominal Tons of A/C):
NAC015 1.5 Ton Unit
NAC024 2.0 Ton Unit
NAC030 2,5 Ton Unit
NAC036 3.0 Ton Unit
NAC042 3.5 Ton Unit
NAC048 4.0 Ton Unit
Aug 30, 2014 | Heating & Cooling
The unit is not cooling the room. It is only comforting when you are in direct line of it.
you need to find out the size of the unit.
Rule of thumb - for every 600 sq ft of cooling area (in a well insulated house) you will need 1 ton of air conditioning. 1 ton = 12000 btu.
So, if your cooling area is 600 sq ft you would need an AC which was rated at 12000 btu, assuming your house is well insulated.
If it is not insulated well - you might need a bigger unit, i.e. 15000 btu.
Jun 06, 2011 | Samsung AW0603B Air Conditioner
Air condition unit of sufficient size??
You currently own a 2.5 ton AC Unit
500 square feet equals a ton of cooling/ you need a 3.5 ton unit.
If your home is well insulated, good windows and doors and pretty good
shade that covers your house, then I can see a 3ton unit cooling your
house.
Thats another 6,000 btus you do not have and that is a best case for a
energy effcient home.
Jul 07, 2010 | Carrier 38CKC030 Air Conditioner
Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
hope this has helped
Jun 20, 2010 | Carrier 38CKC036 Air Conditioner
I have an '06 model combination cooling and heatin
For every 500 sq. ft. house or a 1-bedroom size new house you need 1-ton of cool . An old house you need a ton worth of cooling for every 400 sq. ft. house or a 1-ton per 1 bedroom size house.
Dec 22, 2009 | Whirlpool Heating & Cooling
We have an Amana SRCF30W01D unit and are planning a house extension. What is the sqft coverage for this unit?
Here in Florida the old Standard was around 700 S.Foot per ton.
Now days we size them 400-500 S.Foot per ton.
Appears by your Model number you have a 2-1/2 Ton system.
So id give you Max around 1700 SF.
Min 1200 SF depending on the conditions at the home.
Just a thought for you, Most AC companies will give you a free estimate for a new Ac unit, and can tell you what you may need Unit size wise.
Good Luck!
Nov 05, 2009 | Heating & Cooling
Compressor size
Square footage is how you determine what size of an AC you need, say two bedroom house with 1500 square feet would require a 3 ton unit but I would go to a 4 or 5 ton depending on brand and what you may do in the future, Like adding a bedroom or bathroom and how many people will be living in the house, a heat pump normally last longer the bigger it is and is more efficient than a smaller size. Just think like this, a 3 ton will run 30 minutes to an hour longer to cool the same space as a 5 ton so if the five ton does it 30 minutes faster it will not run as long. And when it has to pull down the temperature again it will do it much faster. So less run time means faster heat or cooling and less energy is used. I have found that the bigger units are made better and last longer as a general rule. And to understand the 3-ton and 5 ton let me say that it means how long it takes 3 tons of ice to bring the temperature down 10 degrees, the old BTU’s British thermal units. However the bigger the unit the more well built it is normally and the less maintenance required. 5 tons of ice would get it cooler faster. But one thing to keep in mind a heat pump is only good for 20 degrees temperature range, for instance if the high range is 80 then the low side would be 60 in order for it to be efficient so if you have it set in the house at 72 degrees on the high side and low side would be 52 degrees. But the larger the unit the less time it would take it to recover from the heat differential.
Jul 22, 2009 | Ruud UAKA042 Air Conditioner
Air conditioner replacement--new size required?
567C024RCU In this model number is the # 24. That stands for 24,000 btu's. This is a two (2) ton unit. Has this two ton unit cooled ok in the past? if so replace with the same size. But make sure yo change the indoor coil to match the size "and" efficiancy of the ew unit.
Apr 14, 2009 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
380 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
