Question about Sony Televison & Video
Sony WEGA TV KD-30XS955 front panel buttons/remote do not work. Problem is intermittent and comes and goes. Manf date 2005. IF, If you press a panel button AND the corresponding remote button, it may allow, menu, volume, and channel changes but not always. It has a month left of extended warranty. Master reset and unplugging for 3min did not help. Does anyone know the root cause?
5 Suggested Answers
jomaru
  • 337 Answers
SOURCE: Cannot access menu
The tv has lost the menu,in order for the menu to come up in the screen it needs horizontal and vertical sync,the syncs come from the secondary of the flyback and from the vertical Ic.Is rare but We have seen it happen,sometimes you also have an Ic called character generator and it could be bad.You will need the assitance of a servicer for this problem because there are voltages to measure and signal to trace.
Posted on Oct 02, 2006
techman
  • 3130 Answers
SOURCE: Remote/tv buttons not working & start-up menu flashing
You can get an original replacement remote that will work all functions from Here: http://www.remotes.com/remotes/servlet/rs?o=c&a=Search&m=KV-27FS200&uid=11829594841080 Good Luck
Posted on Jun 27, 2007
  • 395 Answers
SOURCE: Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
Posted on Jan 18, 2008
  • 49 Answers
SOURCE: I have a sony wega
sony tv have lot of dry soldering is there so kindly do re sold.If bthe problem is continue pleace vertical ic
Posted on Jul 31, 2010
Sony KD-30xs955 television won't turn on.
Anthony from Infotech posted the solution at another location:
6 and 7 blink codes 90% of the time are failure of the two control chips on the DZ board IC8002 and IC6501 both are MCZ3001D available from www.mcmelectronics.com
An ability to solder well is required to do this
Alternate solutions are to send the board to www.ptscorp.com and they will replace the chips or replace the board subject to availibility
A technician would charge $350 for this depends where you are
Feb 01, 2014 | Sony FD Trinitron KD-30XS955 30" TV
My fd trintron wega (kd-0xs955) will sound as if it is starting of when POWER is pressed then the red stand by blinks a few times and nothing else when it is just plugged into the wall (no cable connected)
The flashing light is "Code" for diagnostics. Count the flashes before it pauses. Some Sony user manuals will have the answer in the troubleshooting section of the manual. If you don't have your manual,
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KD30XS955
That's the link.
Hope this helps
Jun 01, 2011 | Sony FD Trinitron KD-30XS955 30" TV
We Have A Sony Trinitron KD-30XS955 That Refuses To Turn On. Every Time We Try To Turn It On We Get 6 To 7 Light Flickers On The Front.
You need to replace the mainboard of tv
the cost is to high and it is very difficult find
one..you better replace it
Jan 16, 2011 | Sony FD Trinitron KD-30XS955 30" TV
My son stepped on a remote control for a DVR. The Sony Trinitron Wega KD 32FS130 went blank. Now it won't come on, goes into standby mode, with the red light blinking four times. Any suggestions?
It is possible that the button your son stepped on is stuck. If so, remove the batteries form the DVR remote control and see if the TV works. Unplug the TV from the wall for a few minutes to clear its memory to be sure. Some times remote controllers can have cross-talk, meaning it can affect other equipment,
Dec 27, 2009 | Sony FD Trinitron WEGA KD-32FS130 32" TV
Menu Screen pops up, try to exit and goes to video 1
This could be a stuck button on the front control panel or a bad solder connection on one of the switches on the front control panel.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony grand wega 55in kdf-55a20
Its most likely an intermittent lamp. The lamp door is located behind the front panel. The front panel can be removed after loosening the two thumb wheels located on either end of the TV in the rear. Observe the light coming from the area around the lamp door. If you see that the light is going out, its the lamp. You can also access the self-diagnosis menu by using the remote control. Start with the TV off. Push the "mute", then the number 5 button, and then the volume down button followed by the power button. When the picture appears, the menu will been visable. If there is a failure with the lamp, or a fan, or many other areas in the TV there will be a number value to the right of the parameter that indicates the number of times the error has occurred.
michtech
Feb 16, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Green symbol AV2 won't go away! Sony Trinitron KD-28DL11U
You need to have original Sony TV remote and press Display button on it, on-screen display will disappear.
Nov 25, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony Trinitron 36" TV
Try a "hard reset"===unplug AC for a long time, like overnight.Let me know if there is any change.
Mar 07, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
