Question about Electrolux Refrigerators
Power Failure alarm will not shut off even when pressing the button.
I had the same problem alarm beeing power failure for a week, finally a $2.95 and 10 min later replaced the circuit breaker and guess what the problem is gone
Posted on Jul 01, 2012
We had a power failure after a few power surges and now I cannot set the clock. The display keeps blinking rapidly. How can I set the clock?
Jensen Smart Talk JCR 290 User Manual Page 10
USING MANUAL SETTINGS
In radio off mode, press SET BUTTON (#5) to enter AL1/AL2/Time
setup mode.
1. The HOUR DIGITS and AL1 indicator in the LCD panel will flash.
2. Using the > (UP) (#6) or < (DOWN) (#4) BUTTONS, adjust to the
desired hour for AL1.
3. Press SET BUTTON (#5). The MINUTE DIGITS and AL1 indicator
in the LCD panel will flash (#25).
4. Using the > (UP) (#6) or < (DOWN) (#4) BUTTONS, adjust to the
desired minute for AL1.
5. Press SET BUTTON (#5). The SOUND EFFECT INDICATORS of
AL1 will flash (#25).
6. Use the > (UP) (#6) or < (DOWN) (#4) BUTTONS to choose a
Wakeup Alarm Sound - Ocean, Rain, Brook, Radio or Beep Alarm.
Jensen Smart Talk JCR 290 User Manual Page 9
Mar 02, 2016 | Jensen Interactive AM/FM Talking Dual...
High temp alarm
Good Afternoon Friend,
I see that you have the High Temp alarm going off on your Frigidaire refrigerator. First, you will want to press the Alarm Off button to turn the alarm off. Next, you will want to press and hold the Factory Default button to put the temperatures at 0 degrees for the freezer and 37 degrees for the refrigerator. Wait 24 hours for the temperatures to stabilize. If you are still having trouble with the alarm going off, reset your appliance by either unplugging it or shutting the power off at your homes circuit breaker for 2-3 minutes. When power is restored, you will need to press the alarm off button. If the High temp alarm is still going off, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Refrigerators
How do I set the alarm so it will activate on weekdays. It only works for Saturday and Sunday. Thanks
Hello
Sure Alarm battery Back-Up System
This SmartSet® Clock Radio includes a Sure Alarm battery back-up circuit that can
wake you up even if the power is 'Off'at the selected wake up time. If your power
is 'Off'at the selected wake up time the clock display will be off and the radio will
not operate, but a separate mini-buzzer will turn 'On'automatically to wake you up,
even if you had selected the "Wake to Radio"option.
The Sure Alarm will sound for 30 seconds and then shut off automatically.
To stop the Sure Alarm buzzer immediately, press the RADIO ON/OFF button.
Pressing the SNOOZE button has no effect during Sure Alarm operation.
Note: In order to maximize the life of the built in lithium battery, please be sure
to set the ALARM 1 and ALARM 2 switches to the "OFF"position if the radio
will be disconnected from the AC outlet for more than a few hours. This will
prevent the Sure Alarm from turning 'On'unnecessarily.
1.) Depress and hold either the ALARM 1 or ALARM 2 setting button.
The display will change from the correct time
to the Alarm 1 or Alarm 2 wake up time.
2.) While holding the ALARM 1 or ALARM 2 setting button, depress either the
SET + or - button to move the display ahead or back to your desired wake up
time.
3.) When the desired wake up time appears on the display, release the SET + or
- buttons.
Note: Be sure that you have set the wake up time correctly by observing
the AM indicator. If the AM indicator is 'On'the wake up time is "AM". If the
AM indicator is 'Off', the wake up time is "PM".
4.) When the desired wake up time (AM or PM) appears on the display, release
the ALARM 1 or ALARM 2 setting buttons
Apr 20, 2011 | Emerson Smartset Clock Radio
Error 0xc18a0001
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it. Press and hold print photo's and the red eye removal buttons then press red eye removal then print photos then red eye removal again. Display should say ?Support? and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says ?System Configuration Menu?. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Jan 21, 2010 | HP Photosmart C6280 Printer
Getting a 5B00 error on a MX310. We just replaced the ink absorber
error 5b00
reset waste absorber counter. here is how to reset.
1) With the printer2.gif powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button 4 times.
If this does not work you need to call canon.
Good Luck
Nov 12, 2009 | Canon PIXMA MX310 All-In-One Printer
Turning alarm on and off
I'm afraid I don't have a manual, but I could walk you through the steps...
1. Press the clock/sleep/timer button twice.
2. Press enter button.
3. Turn dial to set hour for alarm to start.
4. Press enter button.
5. Turn dial to set minute for alarm to start.
6. Press enter button.
7. Turn dial to set hour for alarm auto-shut off.
8. Press enter button.
9. Turn dial to set minute for alarm auto-shut off.
10. Press enter button.
11. Turn dial to select either Radio or CD alarm setting.
12. Press enter button.
13. Turn dial to adjust volume of alarm.
14. Press enter button.
15. Press standby button. Alarm is set.
I hope this helps! Best of luck finding a manual if you still need one. :)
Jun 03, 2009 | Sony PSYC CFD-E90 Radio/Cassette/CD...
Override alarm for color ink cartridge
Hi Redtail,
Try the following. It will not disable the alarm but will reset the in counter.
  1. Power off the printer
  2. Hold the stop/reset button then press and hold power (for 5 secs)
  3. Hold Power and release the stop/reset button
  4. Press the stop/reset button twice
  5. Release power button
  6. Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
  7. On the 3rd press the inicator should be orange.
  8. Press the power button to set data
  9. To set data remove cartridges then replace.
  10. leave for 20 or 30 secs
  11. Press the power button again to shut down
  12. Then press power button to power up.
  13. The printer will feed one piece of paper through
  14. then set language and counrty.
  15. Then ink should be reset
Dec 04, 2008 | Canon MX300 Office All-In-One Printer
Unable to clear alarm light
I have the same problem and happened after 2nd refill
the only answers I could find was that
  1. the copper strip with the dots could be dirty and need cleaning
  2. It could be overfilled and need ink drawn out
  3. It could just now be a faulty catridge
I tried the first 2 with no success but intent to keep trying to clean it and draw some more ink out even though it doesnt seem too full. If it still doesnt work I am going to just discard it and get another and keep re filling it as I have a second one that I use with no problems.
  • Also the printer has to be reset when a new re filled cartridge is used as it will still see it as the empty one. to do this if you dont know how.
To Reset the Canon Cartridges Works 100%
Relase power button
Nov 12, 2008 | Canon PIXMA MX300 All-in-One Printer
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Printer Problem
    This was not the sollution for my pinter..
    My Magneta is half full and my error led is also blinking 15 times
    I found this service manual for the IP4200 but this methode also doen not solve my error led..
    Is their someone who has the sollution for this strange error?
    1) With the printer power turned off, while pressing
    the Resume/Cancel button, press and hold the Power
    button. (DO NOT release the buttons. The Power LED
    lights in green to indicate that a function is
    selectable.)
    2) While holding the Power button, release the
    resume/Cancel button. (DO NOT release the Power
    button.)
    3) While holding the Power button, press the
    Resume/Cancel button 2 times, and then release both
    the Power and Resume/Cancel buttons. (Each time the
    Resume/Cancel button is pressed, the Alarm and
    Power
    LEDs light alternately, Alarm in orange and Power
    in
    green, starting with Alarm LED.)
    4) When the Power LED lights in green, press the
    Resume/Cancel button the specified number of
    time(s)
    setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
    Time(s) LED indication Function Remarks
    0 times Green (Power) Power off When the print head is
    not installed, the carriage returns and locks in the
    home position capped.
    1 time Orange (Alarm) Service test print .
    2 times Green (Power) EEPROM information print
    3 times Orange (Alarm) EEPROM initialization
    >>>>>>>>THIS ONE
    4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
    5 times Orange (Alarm) Destination settings After
    entering the destination settings mode, press the
    Resume/Cancel button the specified number of time(s)
    to select the destination. For detail, see
    "Destination settings procedures" below.
    6 times Green (Power) Print head deep cleaning
    (Cleaning of both black and color)
    7 times Orange (Alarm) Reserved
    8 times Green (Power) CD / DVD check pattern
    9 times Orange (Alarm) CD / DVD print position
    correction (horizontal: X direction)
    10 times Green (Power) CD / DVD print position
    correction (vertical: Y direction)
    11 to 13 times Orange, Green, Orange(Alarm,
    Power,Alarm) Return to the menu selection
    14 times Green (Power) Left margin correction Not used
    in servicing.
    15 times Orange (Alarm) Return to the menu selection
    Time(s) LED indication Destination CD / DVD print
    0 times Green (Power) No change of the destination
    1 time Orange (Alarm) Japan Supported
    2 times Green (Power) Korea Not supported
    3 times Orange (Alarm) US Not supported
    4 times Green (Power) Europe Supported
    5 times Orange (Alarm) Australia Supported
    Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
    Refrigerators Logo
    668 people viewed this question
    Top Electrolux Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
