Packard Bell w3910 d - Doesn't charge or get power from AC adaptor.
My laptop has just died! Well,kind of.
The other day I plugged it in and it made a noise like an electriccal spark. When I looked at the plug that goes into the back of the computer, the plastic ring on the end was broken.
It kept working until the battery ran out so it can't be more than a power supply issue.
It refuses to charge and doesn't get power from the AC adaptor. We took the adaptor back to the shop and tried it with one that didn't have the plastic ring broken - same problem.
It seems to be a problem with the internal power management circuit; the component responsible for charging the battery and/or powering it from mains supply.
I don't know if this is something I mighht be able to replace myself? The warranty has run out and Packard Bell is saying that it would cost more than the machine is worth to fix it. Here in Spain at least they have a fixed rate pricing plan (ridiculous!).
Any ideas? It's pretty urgent.
Thanks in advance.
  • jafp May 15, 2008
    HellaNice,
    It's definitely the computer as we tried it with a different adaptor in the shop. The problem with a standalone battery charger is that I would have to use the computer until the battery ran out and then wait until it recharges again. Not very practical I'm afraid.
    Thanks anyway!
  • vitali-bochk Dec 24, 2008
    Thanks in advance.
    Champion:
  • 230 Answers
Sorry to say, power supply for laptop is harder to repair then PC (but repair able). You will need to get access to the board.
Maybe get a standalone battery charger ?
Posted on May 15, 2008
Easynote w3910...what kind of memory do I need to ugrade
  • Your Packard Bell Easy Note maximum RAM capacity: 2GB
  • The Easy Note W3910 has 2 memory slots or sockets
  • This Easy Note module upgrade PIN count is: 200-PIN
  • The memory speed is: DDR 333MHz, PC2700
  • The motherboard NON ECC DIMM type for your Easy Note W3910 is: SODIMM.
so your looking for 2x 1GB ddr 333mhz pc2700 memory chips.
Apr 01, 2011 | Computers & Internet
Im using packard bell butterfly s-fc-002ac laptop..my problem is the battery is not charging even if it is connected to an adapter. the battery status always indicate: 7% available (plugged in, not...
Hi, There is a possibility of problems in:
  1. the adapter that you are using might be defective
  2. or the port for the power is not working
  3. or the battery fault issue
What you can do is to try another outlet to see if the outlet itself is the cause. Cheers!!
Sep 01, 2010 | Packard Bell Computers & Internet
Packard Bell Easynote SJ51 Problem!!!
I have _exactly_ the same problem, my Packard Bell SJ51 notebook is also 2 years old.
Sep 25, 2009 | HP Computers & Internet
The battery died when the power adaptor was plugged in. The light to show the battery was being charged was not lit but the light on the power supply was. I am guessing its the battery. I have had some...
Just check the Battery diagnostics if you have the software installed...If it is there then it will be in Start - Help & Support - Troubleshotting Tools - Battery Check.......If it shows the battery needs to be replaced contact Packard Bell...Since you told me that the A/C Adapter is not functioning and after you wiggled the lead it started functioning then if the battery test passes you will have to ask for a new A/C Adapter...
Aug 22, 2009 | Computers & Internet
Amber light constantly flashes when trying to charge
Hi there.
The battery could be faulty, power off the laptop, take out the AC power and the battery wait 2 minutes and put the battery back in, turn the laptop an and look at the indicator LED to see if its changed, if it has plug in AC power and see if its the same.
Good luck and thanks for choosing FixYa!!
Jun 01, 2009 | Packard Bell Easy One II 3136 Notebook
My packard bell has stoped charging
If your laptop has stopped charging and you've already replaced the AC adaptor, then most likely it's either the battery itself or the power port on your laptop. If the battery was fine up to that point then it's probably not the battery. To replace the power port can sometimes involve soldering the new port onto the motherboard of your laptop so it's usually best left to a professional. The port you can usually find on ebay. I've replaced a few that is just a small power board that plugs into the mainboard but other have to be soldered. It's not really hard to do, but it involves dismantling the whole laptop to gain access to the motherboard and sometimes requires soldering. Sometimes its very obvious and you can tell by trying to move the metal pin in the center of the plug on your laptop where it plugs in. If the center prong moves then it has become detached and must be replaced. If not it could also be a connection problem due to corossion. Without pulling it apart and looking at it, it can be hard to tell. Deptending on the extent of the work, it can cost from 50.00 - 200.00. I hope this helps.
Apr 17, 2009 | Packard Bell Easy One Silver 2120 Notebook
My power adaptor wont charge my laptop. Where the adaptor goes into the laptop it is singed. does that mean it has overheated and blew the motherboard.
No, that means there is singeing where there should not be singeing. You can get your adaptor tested free, and you can also get your battery tested (they only last a year or two, depending on use.)
You filed your problem under Packard Bell PC Desktops...and it's for a laptop.  Start over!
Jul 31, 2008 | Packard Bell Computers & Internet
Notebook smells like burning plastic.
cud be your onboard voltage regulator for the battery charging. if you remove the battery and use the external power source does it smell also?
if the battery charges normal out of the unit, and the laptop works well with the AC power unit without the battery, then it's your voltage regulator for the batt charging
Mar 17, 2008 | Computers & Internet
Charging
If you can charge your battery in another notebook than borrow that notebooks power adapter & try it on your notebook with & without your battery in your notebook. Your power adapter may be devfective. Listed below is a link to your notebook. Included is all the updates for the,
Packard Bell Easynote R1935 Laptop
P/N : PB42B01001
http://support.packardbell.com/global/item/index.php?pn=PB42B01001&g=2000
please vote...
Feb 16, 2008 | Packard Bell (181379) Motherboard
Power source
Most laptop batteries die - that is, fail to hold a charge, after a few years use, and have to be replaced. That is the probably the reason for your problem.
Jan 28, 2008 | Packard Bell Easy One Silver 2101 Notebook
Computers & Internet Logo
208 people viewed this question
David Payne
David Payne
