Question about Brother XL-2600
The bobbin thread keeps getting matted up and pulling the material in the bottom... I'm using a heavier thread, and have tried several differant kinds of material to see if that was the problem...
    Genius:
  • 1,788 Answers
Be sure to use the correct thread, advised in your manual and that your bobbin and top threads are not too different or else you will have problems. If, you are using a real thin material, try putting tissue paper under your fabric so that it won't get caught. in the needle hole. Usually matting under the fabric is caused by incorrect threading but I am suspecting your thread itself. If, you don't have a manual, go brother-usa.com and download one for free.
Posted on Sep 13, 2010
Will not accept heavy duty thread. sews with bunch-up on bottom of material
the top thread tension is too loose
tighten it up a lot
Dec 12, 2015 | Sewing Machines
Fy5318 breaking thread on multiple layers of material, how to adjust?
either the thread is old, or the tension is to tight.
or there is a bind some where in the line layout.
you mite goto there website and look under FAQ section for other help
or
www.youtube.com/sewing/canvas/material/
www.youtube.com/fy5318/multiple/layers/of/material/setup/
www.ask.com/sewing/multiple/layers/of/material/and/setups/
Sep 17, 2015 | Yamata Fy5318 Mechanical Sewing Machine
My minghui is sawing just top and bottom is just mess can u help me???
Thanks for the question.
If your machine is not sewing on the bottom or making stacks of thread called (bird nesting) there are several simple fixes for this and some not so simple.
First you need to make sure that you are threading the bobbin into the holder correctly, Insure that you pull the end of the thread through the little slit on the side of the bobbin and that the thread is somewhat snug but not hard to pull.
Once you have done this replace the bobbin in the bobbin holder and thread the feed thread over the top from the spool or thread. making sure that you run it through the auto tensioner.
Set the auto thread tension to +1 to start, go ahead and thread the main feed through the bobbin feed so that you have both strings on the sewing deck.
Now with a piece of used material, pull both bobbin feed and Main thread behind the machine, insert your test material, drop the material tension foot onto material and start to sew a 1 inch spot.
After about one inch check to see if your machine is still nesting thread, if it is you need to add more tention to the main thread by moving the auto tensioner to +2. Now test sew again a short distance and recheck. If you still have a issue move the tension up until the nesting of string stops.
If you reach the stop. than it\'s likely that the bobbin holder needs to be adjusted.
The bobbin holder has two small screws in it generally that allow a very small screwdriver to adjust the bi metal pensioner on the bobbin holder. This is the area where you slide the string through the little slot in the bobbin holder.
You can tighten those screws until the string is harder to pull out of the bobbin holder. You may have to repeat this step several times until you get the tensions just right.
but make sure that you reset the main Thread tension to 0 before you start adjusting the bobbin tension.
If after all this work fails you may have to replace the bobbin holder to correct this issue.
There is one other fix that you can try before replacing the bobbin holder and that is to purchase more expensive thread. The reason behind this is that the more expensive thread is thicker and causes more friction in the bobbin holder..
I hope that this has helped you, I know what it\'s like not to have a working sewing machine.
Best of luck and thanks for using Fixya.com
Oct 16, 2013 | Sewing Machines
What is the proper tension number
here is a free manual for the machine
http://www.singerco.com/uploads/download/445_4830_4832.pdf
try using a new needle--make sure the needle is the right one for
the fabric
make sure the top thread has not come off the thread take up lever
try using a different bobbin
make sure the bobbin is not over full
make sure the bobbin is turned the right way in the bobbin case
Dec 05, 2012 | Singer 4830
Husqvarna lily bobbin tension issues
Not sure if I can help, but it may have to do with the heavy thread as well as the fabric and needle combination. If the fabric is thick or tightly woven, be sure to use a brand new sharp needle. (If the fabric is tightly woven (like Batik), a thicker thread may present a problem.) In your case, if using a heavier thread, perhaps a top-stitch needle would be beneficial since it has a bigger scarf to protect the thread. With the heavier thread in the top, the top tension will need to loosened. BUT, if you loaded the heavier thread in the bobbin, the bobbin tension will need to be adjusted to accommodate the thread thickness. However, remember that if you adjust the bobbin tension for this project, you will most likely need to readjust it for the next project using different materials.
FWIW, if the machine still works fine with regular fabric and thread, then you'll know that the issues revolve around the current project.
Understanding Thread Tension Threads
How to Achieve Ideal Sewing Machine Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Jun 11, 2017 | Husqvarna Sewing Machines
Material keeps getting pulling into bobbin, and thread in bobbin compartment jamming
Two things to check:
1. the bobbin tension. Is it too tight? It should pull out without a ton of resistance but should have just a bit.
2. Is the material sheer or thin? If you can drop the dogfeed a bit you might want to do that or you can sew through tissue paper (on the bottom side) to keep the material from being pulled down.
If those things don't help you might try lengthening the stitch just a tad and make sure the needle you're using is the right size for the fabric.
Apr 08, 2011 | Brother Sewing Machines
The bottom thread is not feeding properly. It looks matted. Is the tension not set properly.
What quality of thread are you using? If it is old thread, poor quality thread, or the tension is not correct you will have difficulty.
Try this first: If you machine has a drop in bobbin, check your user manual for tension settings which usually don't need adjusted. If it is a pull out bobbin then try this: Pull 4" inches of thread out of the bobbin and drop it. If it stays there the tension is too tight and must be loosened. If it drops quickly the tension is too tight. If it drops about 1 inch and stops it is just right.
Also wadding can happen if you have a burr on your needle so change that out and see if it makes a difference.
Poor quality thread leads to more trouble than the saving you get. Try a quality Mettlers or Gutermann thread and that will really help.
Hope I helped.
Jan 21, 2011 | Singer Sewing Machines
My kenmore sewing machine model 385.18221 is not really sewing. It seems like it is for a couple of stitches then the fabric goes down into the machine, threads r hung up in the bottom and when u get the...
Here are several solutions to try.
- Re-thread your machine. It may be threaded incorrectly (backwards).
- Raise your feed dogs if your machine has this feature.
- When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
- Reinsert your needle and make sure it goes all the way into the holder and that it’s positioned correctly – usually with the flat side away from the bobbin, but consult your machine’s manual to be sure.
- Change your needle, it may be blunt, bent, or otherwise damaged.
- Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). Make sure your needle is appropriate for the type of thread you’re using.
- Adjust the pressure of your pressure foot. It may be too light for your fabric.
- Change your thread. If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
- Adjust your thread tension, It may be too tight or too loose.
- Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: After changing your needle plate, check to make sure your needle aligns perfectly with the smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope these solutions help you.
Sep 24, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Thread getting caught in bobbin area
If you are seeing the needle thread in loops and birdnests then its the needle thread you need to check. The main reason is it is not threaded through the takeup spring(the one that moves) This action is critical as it is how the thread is pulled up tight. Also make sure the needle thread is between the discs and that it has sufficient tension that you do not see it on the bottom of the material. Try this: Use two different color threads for needle and bobbin. If you see the needle color on the bottom then the needle thread is not tight enough (or in 5% of the cases the bobbin is too tight or hung up). Let me know how it does. Jay
May 28, 2009 | Sewing Machines
Threading lower bobbin
There are some different bobbin cases for different machines but the one you have is a pretty common one with a finger sticking out on top. If you examine the bobbin case you will see a slot on the side of it and there is another piece of metal screwed onto it. This is the tension they are describing.
To thread it properly, turn the bobbincase upside down and insert the bobbin in the case so you can see it. Place your thumb on top of the bobbin and pull the thread through the slot on the side of the case and under the piece of metal(the lower tension) which I described to you earlier.. When you have done that, remove your thumb from the bobbin and pull on the thread. It should have some tension on it.
Next,placing a thumb or finger on the bobbin to keep it from falling out, turn the bobbin case over.
Keeping the finger sticking up lift the lever on the
front of the case and insert the bobbin and bobbin case onto the spindle inside the hook assembly(The part that is in the bottom of the machine that turns when the hand wheel is turned.) Don't worry about the thread that is sticking out.
Holding the upper thread under the presser foot ,turn the handwheel towards you until the top thread pulls the lower thread to the top. Pull the thread to the left of the machine, insert your fabric, lower the presser foot and begin sewing
One more thing , The finger sticking up on the bobbin case will go into a slot on the ring holding the hook inside the machine.
Hope this solves your problem.
Be sure you thread the upper part properly. It should go through the tension, then the take up lever and then the needle. Tension should be set at around 5
sewman7
Jan 17, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother XL-2600 Logo
351 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
