Question about Zebra LP 2844 Thermal Printer
Missing print - Zebra LP 2844 Thermal Printer
    Scholar:
  • 119 Answers
Im not sure what you're asking?
But we can start with operating system, The lp2844 works well with vista and x but has a known problem printing items on windows 7,
For example if your trying to print postage from paypal and using windows 7 it will mess up every-time.
If you give me more info I may be able to better help you.
Posted on Sep 13, 2010
Why is print head loose or missing?
The print head houses the printer LASER if it is missing NO Printing. OR Loose normally the print head is located well inside the machine so you cant see the LASER beam when it is working.
Take the machine back to who sold it if the LASER ?PRINT HEAD is missing
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 15, 2015 | Kodak ESP Office 2150 All-in-One Inkjet...
I've been having problems with my Epson 7600 large format printer, I recently took it all apart to unblock the light black tube. I reassembled the printer and everything is back to normal apart from I now...
The most common cause of horizontal banding is generally missing, deflected or clogged nozzles. To see if this is the cause you should first print a nozzle check and examine the printout with a 10x or better eye loupe for any missing or deflected nozzles. If nozzles are missing or deflected you will need to perform cleaning cycles to recover these nozzles. Once all missing nozzles are recovered try printing your document again.
If no nozzles are missing or deflected, check that you are using the correct driver settings for the type of media you're printing on. Also try printing at a higher resolution and turning high-speed (bi-directional) printing off.
The most common cause of vertical banding is over-saturation of the media, usually created by paper "rippling". To correct this effect, decrease the saturation and lower the paper suction. If vertical banding is still apparent print the image with high speed off (uni-directional). If this corrects the issue, align the print head, as described on page 5-6 of the Users Guide.
Jan 12, 2011 | Epson Stylus Pro 7600 InkJet Printer
When photocopying, leftside print missing/text
it is only happned when you takes only photocopy ? or Printing... The same will be affect while printing and copying may be the problem related to Laser Supply unit, open the LSU and clean the LSU mirror with a cotton waste. Your issues must be solve....
before that pls. check your cartridge unit...
Apr 24, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Lines on print. There's are three lines on picture print only. Can't see the line on document. It's about 1/4 inch wide and going throught top to bottom.
Have ou gone into your menus. Into troubleshooting, then image quality.
You will want to run both the eliminate light stripes and eliminate smears procedures. that will purge the print head, blow air through the jets and hopefully resolve the problem. I do believe the 8550 has a Jet Substitutin procedure where you can do a workaround and make other jets make up for the light areas.
here are some directions, Will forward more
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Troubleshooting Print Quality Page], and then press the [OK] button.
  4. Evaluate the 'Light Stripes Test' page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. The 'Light Stripes Test' page is the last page of the Troubleshooting Print Quality Page that printed.
    WARNING: To avoid injury, do not touch the sharp metal strip attached to the clear rubber wiper blade in the Maintenance Kit.
  5. Use a clean lint-free cloth or a new paper coffee filter to gently clean the maintenance unit's clear rubber wiper blade, use only a wiping motion across the entire length of the wiper blade, and then empty the waste tray. A dirty maintenance kit wiper blade can cause white lines and weak or missing printhead jets.
  7. Repeat step 3 to reprint the Troubleshooting Print Quality Pages. If there are no missing or partially missing color bars then the print quality problem has been resolved. If there are missing or partially missing color bars then the printhead cleaning procedure will need to be performed. Continue with the next section.
To clean the printhead using the basic eliminate light stripes procedure:
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Basic], and then press the [OK] button. The printer will perform a head cleaning, which will take about five minutes. The printer will then print a cleaning page and a light stripes test page.
  5. Repeat steps 1 - 4 one more time. If there are no weak or missing jets then the print quality problem has been resolved. If there are still weak or missing jets after two basic light stripe cleanings, continue with step 6.
    NOTE: Do not try the Advanced Eliminate Light Stripes Cleaning mode without performing two basic cleanings first.
    To clean the printhead using the advanced eliminate light stripes procedure:
  6. Press the [Up] or [Down] arrow button to select [Advanced], and then press the [OK] button.
  7. Select the missing jet color and number. If necessary, check the light stripes test page to determine the color and jet number of the missing jet.
    NOTE: Only perform the advanced light stripe cleaning once. If weak or missing jets still persist, continue with step 8.
  8. Print the Troubleshooting Print Quality Page. Evaluate the Light Stripes Test page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. If necessary, perform the basic eliminate light stripes procedure one more time. If the Advanced Eliminate Light Stripes procedure does not resolve the weak or missing jets, perform the Enable Jet Substitution Mode. See the Related Items below.
Feb 05, 2010 | Xerox Phaser 8550DP Printer
When I print, the copies have lines missing. the cartridge is new.
If you first choose " Print Preview" and all lines are there try printing from there.If still missing lines I think your program, driver files are bad, reinstall them.If you print normal from print preview I would reinstall just driver files.Good Luck.
Sep 17, 2009 | HP PSC 2355 All-In-One InkJet Printer
Sending print job from pc to IR5000 prints with missing letters
I doubt it's the copier, sounds more like a application or board problem, my first suggestion would be to re-install the driver. the other would be to target the hard drive or memory/ mother board of the network of the copier
Nov 12, 2008 | Canon imageRUNNER 5000 Copier
Problem with printing labels - not aligned, some missing
This is due to print server problem, you should change the options on the driver.
Nov 04, 2008 | Datamax M-Class M-4206 Thermal Label...
Brother dcp 150c pinting out of focus / blurry
YOu need to Do Print Test First I suspect One of the Color have Missing Dot..If the Print Quality have missing dot on The 4 colour the print our will blur ....The aligment of the print head maybe swicted ......Need to Be purge Or Replace new print Head...usually print head needed to be replace...
Nov 01, 2008 | Office Equipment & Supplies
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Zebra LP 2844 Thermal Printer Logo
97 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
