Question about Ricoh Aficio GX5050N Printer
Have a ricoh 5050n printer that will not power on
  • 3 more comments
  • monounl Sep 13, 2010
    when press the power button the light turns green, then the data in and the alert bar flash briefly and then everything goes off. where is te battery located?
    do you have any idea if the flashing lights is a power supply issue and can you tell me where the power supply is located as well as the battery
    the power cord can not be disconnected...the other attempts did not work. please advise as to where the battery is located and where I might find the power supply
    thanks
    ricoh GX5050n
    have a ricoh gx5050n printer using sawgrass sublimation inks. Printer was working fine, sent a print and it went into it's normal warm up phase, then shut off without printing. Now, when pushing the power button, it stays on for approx. 10-15 seconds then flashes along with the data in lite, the alert lite and the on-line button..then shuts off.
  • 4,472 Answers
Being that this printer should only be about a year old you should contact ricoh directly as it should not be having this problem with a printer this new. Follow this link and scroll down to the sales and services locations section and locate the nearest service center near you and contact them directly about having the printer serviced under warranty because it should not be having this issue on this new of a printer and you can expect a certain amount of use out of a printer of this nature and it definitely isn't reaching those expectations.
http://www.ricoh-usa.com/contact/
If you need further assistance please let me know.
Thank you,
Lee
Posted on Sep 13, 2010
  • 182 Answers
As you printer is not turning on...and you have not mentioned if you are getting any flashing light..or light signal..you may following steps to solve the problem
A)Solution one: Press and quickly release the Power button
Press and quickly release the Power button (.) to start a Power On/Off cycle. Do not hold down the button
B)Solution two: Check the electrical connections and outlet
Unplug the power cord from the electrical outlet, or the power strip or surge suppressor.
Carefully inspect the power cord for visible damage.
Disconnect the power supply from the rear of the printer.
Wait at least 30 seconds, and then plug the disconnected power supply into an electrical outlet. Do not use a power strip or surge suppressor.
Reconnect the power module to the product
Press and quickly release the Power button (.) to turn the product on
If the product still does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button ( ) to turn the product on.
If the product turns on , the electrical outlet in the original room caused the issue.
If the product still does not turn on , continue with the next solution.
C)Solution three: Check the USB cable
Disconnect the USB cable from the rear of the product.
Press the Power button ( ) to turn on the product.
If the product turns on with the USB cable disconnected , replace the USB cable.
If the product still does not turn on , continue to the next solution
D)Solution four: Check the battery
Check the battery light. If the light is red, recharge the battery.
If the battery light is still red after recharge, replace the battery.
E)Solution five: Replace the power supply
Hope this would help.. :)
  • 4 more comments
  • Goldi Kunal Sep 13, 2010
    This is the contact number of Ricoh USA incase you need it...if even after performing the above steps you dont get the resolution...or you face problem performing the above mentioned steps
    1-800742-6438
    All the best
    If you get a green light..that definately is the good signal which means there is no Hardware problem...may be you printer has entered the power save..stand by mode
    Please perform the power cycle as mentioned earlier and let me know the outcome
    Can you provide me the complete and exact model no and make
    It this one is GX 5050 N ?
    you may download the user manual from the following link
    http://support.ricoh.com/bb_v1oi/html/oi..." target="_blank" rel="nofollow" http://www.ricoh-usa.com/downloads/downl...
    The mannual is for RICOH GX 5050N which is your printer...please save and view to check the exact location
    all the best
How to use printer Canon LBP 5050N if one of the colour cartridge is empty
printers need all cartridges to work properly
replace the empty cartridge with a full one and proceed with the printing
Dec 31, 2015 | Canon LaserShot LBP5050N A4 Colour Laser ,...
Why is my Ricoh Aficio SP C411 DN laser printer shutting off soon as it is powered on
Go to user tools
than select the time for power save mode,reset mode set those timer off or for long time
Nov 10, 2015 | Ricoh Aficio SP C410DN Laser Printer
Iam getting copy very light..
1. Could be low on toner or,
2. Take a Q-tip or cotton ball, dilute with alcohol and clean rollers. (works every time on printers/copiers).
Good luck.
Sep 11, 2015 | Canon ImageRunner 5050N Digital Copier
E-000732-0001
Error in scanner communication
Error in DDI-S communication Remedy 1. Check the connector connecting to the Scanner. 2. Check the power of the Scanner ->whether to perform initialization at start-up? 3. Replace the Rcon, the Scanner Board or the Main controller PCB 2.
Dec 09, 2014 | Canon ImageRunner 5050N Digital Copier
How to calibrtate canon lpb 5050n
Most people have the opposite problem with this printer it calibrates all the time!
The calibration is automatic try turning off the printer and disconnect the mains lead, wait 5 mins and switch back on and it should calibrate.
Good luck
Jul 08, 2014 | Canon LBP-5050n Laser Colour Printer USB...
How to calibrate canon 5050n printer
See this... http://smallbusiness.chron.com/calibrate-canon-printer-56604.html
Canon lbp 5050 n printer trouble shooting does not print at all
Getting AC power? Is the cable connected to PC? Is the printer enables in software? Need more info. What is your PC, OS, etc.
Nov 15, 2012 | Canon LBP-5050n Laser Colour Printer USB...
Ricoh Aficio  GX5050N Printer Logo
530 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
