Question about SimpleTech SimpleDrive 250 GB External USB 2.0 Hard Drive
Computer wont recognize hard drive and drive keeps clicking
  • SimpleTech Master
  • 27,725 Answers
The clicking noise is the reader arm jumping across platters on your hard drive you have a dirty hard drive first clean all the dust from your computer specifically from around your hard drive using a high powered sucksion vacuum cleaner or a fine air blower from a air compressor making sure there is no moisture in the air lines then give the hard drive a firm tap on the side to free it up
hope this helps good luck
the beeping sound is the post system searching for your hard drive and other connected devices
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Posted on Sep 13, 2010
External hard drives
The clicking noise means that the HDD is stuck from the inside. You could take it apart and just move the pointer, if you want.
After fixing the HDD, try to connect it again tot he computer, if it doesn't recognize it, try another USB port. Once connect it, you can try and check in device manager, if there is an exclamation point, it means that you probably need a driver. Also check that your USB cable is in good condition. Hope everything works out OK.
Jan 19, 2015 | Hard Computers & Internet
Dvd recorder hard drive not recognized when used as an external
Open Start menu
Click the right mouse button on Computer
On the pop out menu click on Manage
In the left hand menu click on Disk Manage
Your drive should show here if it is plugged in.
Delete all partitions
Now create a partition, format it how you want.
Mar 21, 2014 | Hitachi Computers & Internet
Wont recognize hard drive
If you recently bought it from a store or online it might just be a bad hard drive which happens. If your bios wont recognize it then it might just be an error with the bios firmware which can be updated from the manufaturers site.
Jun 11, 2013 | Computers & Internet
My hard drive wont connect, and the computer doesnt recognize it.
hi have you used hard drive password to protect then remove the password if not then if your HDD is making lot sound and not able detect that might be your HDD is gone (HDD=hard disk).
Jun 25, 2010 | Buffalo Technology 250GB USB SATA 2.0 HD...
Computer wont recognize external hard drive
try to format the external HDD using command prompt..... type "cmd" in start & search box and hit enter... command prompt will be opened... Now type "format X:" where X=your external hdd drive letter.... if it does not format then right click on my computer icon> goto manage >select Disk management> select the external drive> right click and delete partition > again right click and select create partition > again right click and select Format drive.....
this will fix the issue....
Apr 20, 2010 | Western Digital My Book Essential Edition...
External Hard Drive will not show up. Tells me to format it.
I have a Western External Hard Drive 320 and when I plug it in the computer will recognize it and allow me to access my files but after a short while if I go to click on a file t open it the WD 320 will click off for a minute and then reappear in the auto run mode.
Jun 20, 2009 | Western Digital Passport 320GB External...
Re-format
If you started a format, but it didn't complete, you pretty much cleaned out the hard drive.  go to start>right click my computer and click manage.  On the left hand side under storage, you will see disk management.  Click on that.  Now before we continue, I will tell you that if there is anything important on your hard drive....DO NOT CONTINUE!!!  As what I am about to tell you will completely erasse everything with NO chance of recovery...at least not without spending hundreds of dollars.  Find your external hard drive on that list on the bottom.  Right click...delete partition.  Then right click and create partition.  Then right click and select format.  That should be it in a nutshell.  Hope it helps.  Please rate!
Feb 27, 2009 | Western Digital My Book Essential Edition...
Hissing and Clicking
Go into the control panel.
Select administrative tools.
Select computer management.
Select disk management.
See if the drive is detected in there as well as the partition.
If it doesn't appear Iomega can replace it.
Jul 17, 2008 | Iomega (33600) 160 GB USB 2.0 Hard Drive
Zen MIcro Stuck and wont work or be recognized by computer
Doesthe hard drive still spin? After powering it on, put it up to your earto listen. If there is no noise at all, or a smooth and steady spinningsound, that indicates your hard drive is fine and your motherboard hasfailed. If you hear clicking noises that keep repeating, this indicateshard drive failure.
When you try Format, does it say "Harddisk Problem?"
For more detailed instructions on how to troubleshoot your Zen, click here
Jul 02, 2008 | Creative Labs Zen MicroPhoto MP3 Player
My sandisk micro wont work
Your computer will recognize it as a "removable drive". Click on it and save into or remove from. Let me know what happens.
Jan 22, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SimpleTech SimpleDrive 250 GB External USB 2.0 Hard Drive Logo
339 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
