Question about Samsung SP-S4243 Television
Can I replace a broken Samsung 42" plasma PN42B450B1D screen with a Samsung 42" plasma SP-S4243 screen? Are the screens interchangeable?
  • 70 Answers
No, you cant. I have 2 tvs just like yours but the LN model is newer than the SP model tv. I have the same problem, my LN tv has a cracked screen and the other SP model is good
Posted on Oct 14, 2010
    New Friend:
Did you attempt the swap?
Posted on Feb 15, 2016
I have a Samsung sp-s4243 plasma tv from 2006 - works great but cannot connect any newer hdmi devices like bluray or the chromecast I got today - only get a black screen but do get audio
signal on tv settings for hdmi need to be set to 1080i or auto, but
  • 42" EDTV panel (displays all signals at 480p)
  • Usb on back is not turned on, service engineer turns this on when its being repaired at a shop etc. if it is powered on don't use it as it will interfere with the device using it.
  • Firmware downloads were never introduced, only flash in service mode.
Jan 03, 2018 | Samsung Televison & Video
Power seems to work but screen won't turn on . It makes a clicking noise and it seems to turn power off and on. Samsung plasma 50" Model: SP-S4243
What your looking at is a power Supply unit go to vancebaldwin.com get the Replacement unit and you will be fine.
Oct 13, 2012 | Televison & Video
Red specks all over screen
abnormal picture is usually going to be Y or X or Logic board for samsungs but in depth troubleshooting will be required for assistance you can send a email to customerservice@tvrepairworld.com they can help you properly diagnose what might be happening with the set.
Aug 08, 2012 | Samsung SP-S4243 Television
I have a 42 inch philips plasma tv with a broken screen, could i replace it with a screen from a panasonic 42 inch tv
No--this is called a PDP or plasma display panel and no two (even same brand) can be interchanged.
The cost of a Panel exceeds the cost of a new set--broken screen=fatal issue.
Mar 31, 2012 | Philips 42PF5521D 42 in. HD-Ready Plasma...
I need owners manual for my Samsung Plasma TV model SP -S4223
You can download a pdf copy of the manual at the link below. Click on or copy and paste the link into your browser and save the document on your computer. The document opens with Adobe Reader.
http://downloadcenter.samsung.com/content/UM/201105/20110502125808069/BN68-00991J-00Eng_110502.pdf
Nov 12, 2011 | Samsung SP-S4243 Television
Just hooked my Samsung SP-S4243 up do hdmi cable but it won't display full screen.
Sounds like the cable box is outputting in 4:3 rather than 16:9, it should also output in either 720p or 1080i/1080p. Check the settings on your cable box and set them to 16:9 and 1080i/180p. If that does not rectify the problem then you need to look at the settings on your Samsung
Jan 03, 2011 | Samsung SP-S4243 Television
Samsung plasma tv shows no picture after cleaning
u may have a bad y-sub board , it is normal on plasmas
Mar 29, 2009 | Samsung SP-S4243 Television
How to set pc to samsung 42' sp-s4243
You need to set the TV to input from the source that the computer is connected to.
You also need to make sure the computer is set to output a signal to it's S-video or video out port (usually Fn F5 or something like that, or there may be an software switch in your desk tray where it is to be tripped.)
Jan 27, 2009 | Samsung SP-S4243 Television
Samsung SP-S4243 has a constant buzzing noise
This is most probably you inverter board making the sound, most probably a bad solder joint, It would be hard for me to help you any further, but if it is a bad solder joint it could be repaired. Most shops no longer repair boards they just replace them.
If you have the knowledge you could do this, but I would recommend it other wise, there is High Voltage to deal with. I hope this helps. Merry Christmas!
Dec 23, 2008 | Samsung SP-S4243 Television
White Dots (Plazma)
The symptom sounds like a common problem we have found with the plasma panels called diffusion. The cure in Samsung usually is a VSCAN alignment. Since its an SPS-4243 the unit should be under warranty and is covered. Call 1-800-SAMSUNG and they will direct you to the nearest service center.
Mar 04, 2007 | Samsung SP-S4243 Television
Samsung SP-S4243 Television Logo
592 people viewed this question
Jerry Greenberg
Jerry Greenberg
