Question about Ricoh Aficio 2022 Black and White Copier
When we have to change the drum of ricoh 2022 machine.
  • Ricoh Master
  • 525 Answers
Change the drum after 60 000 copies
Posted on Jan 22, 2011
Ricoh aficio 2022SP prints black line across middle of page
Remove the OPC unit,clean the charge corona,charge corona grid,clean or change the OPC drum cleaning blade.
Jan 26, 2013 | Ricoh Aficio 2022 Black and White Copier
Ricoh aficio 2022 replace photoconductor unit
Photo conductor unit is the drum unit inside the copier . It contains developer and toner which are the ink as some people refer to it. It is a consumable part and needs to be replaced every 60k copies but can and dies last longer. You can ignore it and once copy quality is ok I wouldnt bother changing it but you will eventually need to replace it.
Oct 02, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
Looking for an owners manual for a Ricoh Aficio SP 2022
I do not have a manual for the Aficio 2022SP. However, there is a manual for the Ricoh Aficio 2022 available as a PDF here: http://www.ricoh-usa.com/downloads/local/manuals/multifunction_bw/aficio2022-27.pdf . If the direct link doesn't work, start here: http://www.ricoh-usa.com/downloads/downloads.aspx?d=pm and search for the 2022.
I hope this helps.
Feb 11, 2011 | Office Equipment & Supplies
Change ip address at ricoh aficio 2022
Hi, to change the IP address of a Ricoh Aficio 2022, follow these steps:
- Press the User Tools/Counter button.
- Choose System Settings.
- Choose Interface Settings.
- Choose Network.
- Choose IP Address.
- To specify an IP address, choose Specify, and then enter the address you want to use. To have DHCP automatically assign an IP address, choose Auto-Obtain (DHCP).
- Exit out of the User Tools screen.
Dec 15, 2010 | Ricoh Aficio 2022 Black and White Copier
Ricoh aficio firmare
You must have a Ricoh tech ID in order to download machine firmware. You can get the firmware from Ricoh's tech website, TSCWeb.net if you have a valid Ricoh ID.
Jan 29, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
I have a problem with my Ricoh Aficio 2022sp. It leaves a black line when I copy or print anything.
Something around the drum need to be replaced. There are two ways to be done. Because Ricoh do not offer a replacement by parts around the drum unit for this machine by Ricoh you can only replace the hole drum unit. But as you say you have a problem with the drum cleaning blade, or in worse case the drum and the cleaning blade for the drum need to be replaced. So Katun offers a replacement by parts and by Katun is more cheap to be replaced. This is what is the problem, so on your hand is what are you gonna decide.
Dec 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
RICOH AFICIO 2027 SC392 CODE,IM AN ENGINEER AND RESET SC CODES BUT STILL DOESNT WORK. HAVENT COME ACROSS THIS BEFORE.I KNOW ITS TD SENSOR FAULT, CHANGED WITH ANOTHER 2ND HAND UNIT I KNOW WAS WORKING FINE...
• Someone forgot to remove the toner
seal of the PCU
• ID sensor defective
• TD sensor abnormal
• Drum does not turn
• Development roller does not turn
• Poor connection of the PCU drum unit
Clean connector of TD sensor and
Try Change the development unit, adjust TD sensor.
Clean and you verify the connector of PCU.
Good luck...
Oct 12, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
SC 548 on ricoh aficio 2022
Hi Andreas: The fusing unit has not been reinstalled properly. There is a receptical on the back of the Fuser that mates with a plug in the machine when you install the part. the machine is telling you it did not detect the fuser. Undo the screws and remove it and reinset it again, makin sure that it seats properly. then you will need to reset the code. Go into SP Mode: Push in sequence; Clear-107-red stop button(hold this down until display changes and shows "copy etc"), turn machine off(using red power switch, wait 10seconds and turn back on. If you still get the error code the fuser still is not inserted correctly. Hope this helps.
PS: Black spots can also indicate a new drum is needed. It may have a small chip in the surface.
Regards
Munybuny
Jan 22, 2009 | Ricoh Aficio 2022 Black and White Copier
Ricoh Aficio 2022 Black and White Copier Logo
88 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
