Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
It won't freeze, fan blows but won't freeze - Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
  • 384 Answers
Dear sir /madam
please check in your freezer,s back side there is compressor please try to find it,s running or not if it,s running and it,s not getting cool and not freezing inside then it can be low refrigerant gas problem it,s up to you ,refill the gas by yourself or take help to a technician.
hope answer the question
thank you
please vote!
Posted on Sep 17, 2010
Daewoo FRN-U20IA top of freezer compartment won't freeze
It was the fan at the top of the freezer that had stopped working after 3 years, therefore the freezing air wasn't getting to the top of the freezer. From the inside, unscrew light unit and unclip, pop out two circular discs at top and unscrew one screw. Unscrew 2 more screws and prise the back panel off. (Arrows mark the clips). Pull off fan, take out motor, replace (keeping rubber bits) and push back fan with a bit of nail varnish on spindle. Put everything back together. Turn on, depress door light switch and after 30 seconds fan should rotate. You can buy a fan on eBay or from www.4daewoo.co.uk for about 40 pounds.
Feb 27, 2013 | Daewoo FRSU20IA Freezer
Freezer Will not freeze in some areas
Check the door gasket near those shelves.
Make sure the condenser fins or tubes have adequate air flow for cooling (it looks a bit like a small but fat car radiator). In most freezers, this will be in the bottom in the back. You may have to remove a vented cover to check this. Usually there is a fan blowing air through the condenser. Carefully vacuum out any dirt in the condenser (the fins are delicate and bend easily), and verify that the fan runs smoothly when the compressor is running.
Put a thermometer in the freezer right by the cold air inlet to verify that the refrigerant is doing its job. It should read 0 degrees F. or below (-18 degrees C). If it doesn't get down that far, the compressor needs to be recharged or replaced.
If the door has been hit hard (somebody falling and slamming into it) the door insulation may be damaged there. Check to see if the outside of the door feels cold there compared to the rest of the door. If it does, the door needs to be repaired or replaced.
Aug 03, 2017 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Upright freezer makes a loud rattling sound, like something is loose. Doesn't do it all the time, but does several times a day.
have a look behing your drws in the freezer it has probably started to freeze and the fan that blows the cold air around will have an ice build up. The noise you hear is the fan bashing against the ice. The fan is normally situated behind the panel in the freezer section.
Hope this helps
Mar 22, 2010 | Whirlpool Freezers
The 2 fans are not working but the freezer coils are freezing up won;t go below 20 degrees
the freezing is and temp are caused by the fans not working. One fan pulls warm air out of the box and across the evaporator coil, which in your case is frozen, and the other fan is used to pull air over the condensing coil which rejects the heat pulled out of the box. check the wiring diagram for a fan relay first, which can easily be changed out, or by some crazy chance, both fans quite working at the same time
Nov 20, 2009 | Freezers
I have a Beko frost free fridge freezer but the freezer part has stopped freezing, the fan is working although it is not on all the time and the freezer is getting cold but no cold enough to freeze, have...
have you checked the door seals, if it has split it won`t freeze 100% as warm air will get in and keep the temperature up, bit like leaving the door slowly open hth
Oct 12, 2009 | Freezers
Aquired 3 door victory in existing bldg. Service
First check for bunrt wires that can be grounded, then you can disconnect the compressor and plug the freezer and if doesn't blow the breaker , the compressor is bad ,if still blows them ,put the compressor back and try the fan , then try the other fan(inside one) or also could be the light switch, or the defrost heaters.
Oct 06, 2009 | Victory Freezer Refrigeration ''Value''...
I have a Subzero 501F that stopped freezing. The compressor is running(replaced about 2 years ago.) and all of the fans are working. Any ideas?
Either the unit is low or out of freon or the fan that cools the condenser has stopped working. If you can improvise a fan to blow on the condenser, yould should be able to tell if that is the problem within a few hours. If you can locate the fan and it is not working then you have found the problem.
Sep 21, 2009 | Freezers
Freezer not getting cold enough to freeze.
First culprit could be a refrigerant leak and needs to be charged. If the evaporator is frozen solid it won't push enough sub zero air to freeze. Call a trusted ac&or repair man
Sep 23, 2017 | Frigidaire Freezers
Not freezing equally
Look for frost build up on back wall at bottom the auto defrost may be out. Check if the evaporator fan is blowing. If not it's stuck by something or needs replaced. If not The sealed system may have a leak or restiction causing it to only work closest to the evaporator i.e. the lower shelf.
Apr 22, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
572 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
