Question about Sanyo DP32648 32 in. LCD TV
My 32ca-87 lcd is not working.there is no power indication
    Genius:
  • 1,622 Answers
You can fix this yourself , having a basic knowldege on electronics will be of advantage but not withstanding you have to open the back cover of the TV to check for blown fuses, replace if found, but if otherwise check for dry soldering and bulged capacitor, then if otherwise your power supply board is bad , try shopjimmy.com, ebay.com for replacement of power board to make your TV working again.
Take care , hope this solve the problem
Posted on Sep 13, 2010
Hi I have a Chrysler Grand Voyager LE 98 (S plate) there is an indicator fault and the relay has no diagram on it would you be able to explain how it supposed to work please. It appears that there is no...
No the ECU is the ground for the relays. There should be two positives and to grounds At the relay port. One positive is constant, the other comes on with the ignition. On the bottom of the relay there are numbers. 30, 85, 86, 87. 30 should be hot at all times, it supplies voltage to 85. 86 is hot when you turn on the ignition, 87 goes to the ECU. The ECU grounds out the relay to energise it, thus sending power to 85. This works the same for all the relays.
Feb 06, 2011 | Chrysler Voyager Cars & Trucks
Sudden failure - working fine then next time switched on no apparent power (no indicator light on), no display
You could have a power supply problem in the LCD monitor.
First check the power lead, make sure it is firmly inserted into the mains socket and into the monitor.
Try inserting it into a different main socket that is operating, to see if the power indicator LED lights up.
If you have determined it is the LCD monitor is faulty, then it requires repairing.
Jan 25, 2011 | Acer AL1717 17" LCD Monitor
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
My Sharp LC-42-D62U won't power up. The power light blinks twice, then the power light and the OPC light blink together once. any fix to this problem?
Ur Tuner signal board have problems or dead.Ur power LED light indicator stable for a few mins before the power LED light,and the OPC LED light indicators flashes?After the POWER light and OPC light indicators flashes,just push the power button again for the power recycles again.Probally have to pushes the power button 3 or 4 for power light and opc light indicators flashes,the LCD backlght will lght up and work.Sharp tv have this problems alot,very common in Sharp LCD tvs.
Apr 17, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a 86/87 Nissan king cab SD 25 diesel truck. The right side rear turn indicator light doesn't work . Its not the fuse and it's not the bulb. I need a wiling diagram.
its probly a stripped wire in the back wher the wires split 2 go 2 each side. check the red wire with wire tester 2 locate wher you have power up 2
Feb 13, 2010 | 1986 Nissan King Cab
No indication of power to the unit. I opened the unit and removed the cable connecting the main board to the LCD controller board. I disconnected it from the LCD controller board side. When power is...
If you hear a flickering sound the power board is bad .However since you have found the lcd board to be faulty you might as well replace it.Look for it on line by part number.Or to save yourself some headache use a good board from a working monitor.
Good luck
Sep 16, 2009 | Acer AL1923 19" Monitor
Sharp LC-37SB24U will not turn on
I can tell you 100% that the problem that you are having will be a service issue. I can also tell you that your limited warranty covers in home service from sharp. Give them a call 1-87-SEE AQUOS(the advantage line that will get you through much quicker). or the 1-800-BE-SHARP and let them set you up for service, sharp will take care of that as long as the purchase date of your tv was within 1 year. If you dont want to go through that, I suggest taking the tv back to where you got it from if they will accept it because unfortunately, this problem can ONLY be resolved through service. good luck & keep me posted
Feb 17, 2009 | Sharp LC-32SB24U 32 in. LCD TV
No power indication
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Dec 04, 2008 | Akai LCT2715 27 in. LCD Television
Flashing green power light with no picture
9-if the tv is still under the manufactuer warranty i would definitly give them a call. If it is a Sharp tv I would call the 1-87-BESHARP. I would also try unplugging the tv for at least 2-3 minutes and seeing if the tv will reset itself. Usually what happens with these tv's when the light blinks it locks the tv as a security issue. If the unplug does not help it will more than likely need service to get this fixed for you. The call line hours are M-F 7am-7pm S-S 9-5 and they will be glad to help you from there.
Nov 08, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sanyo DP32648 32 in. LCD TV Logo
69 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
