Question about Hotpoint WMM75 Front Load Washer
Hi our hotpoint wmm75 has stopped turning/spinning. yet goes throu the programme of letting water in and pumping it out, the belt is intaked and the drum turns without excess fault, it has just stopped, there were no undue noises etc, any help would be much appreciated.
I had to buy a new spring for my hotpoint wmm75a then noticed the plastic support underneath had broken where can i get one from?
Posted on Nov 09, 2010
Hotpoint wma76 stops and displays ON
Could be rinse water valve ..Faulty Solonoid coil
Nov 10, 2009 | Hotpoint WMA76 Front Load Washer
The washer has stopped emptying and spinning. The pump does not appear top be making any sounds either.It is a hotpoint aquarius
OK... Pessure switch is proberbly stopping the machine from spinning due to the water level in the machine... The pump could have just stopped working, or, the control board could be broken and therefore the pump not getting a supply current, or, the propeller in the pump could be jammed by debris.
1. Turn the machine off, and unplug...
2. Take the drain pipe and lower it to an outside door or other place to safely drain the water away that is still in the drum.
3. Follow the drain pipe till it reaches the pump. Check the lead to the pump to make sure it is properly engaged into its recess on the pump motor.
4. Take the hose off the pump in order to clear any debris and then replace the hose
5. Having done all that, plug the machine in and turn it on
6. Put it onto a spin programme ... The machine should now lock the door, then both pump and spin actions should start... If not, your control board or cabling is at fault
Aug 20, 2009 | Hotpoint Washing Machines
Hotpoint WMA30 Front Loader Not Pumping Out but still fills if put on rinses, on spin tries but gives up
no easy way to get water out but try putting drain hose down at floor level into a bucket and that may work
fault is probably filter blocked.
to access filter, take rear back panel off. you will see a large diameter hose going from bottom of tub to pump. disconnect this hose at tub end - carefull, water will come out. filter is inside this hose. take it out, clean and reassemble
Oct 02, 2008 | Hotpoint WMA30 Front Load Washer
Water pump turns on and runs for a short time than stops for a short time then starts and then stops. And the machine can not spin because the water is not out enough.
Check the pulley, the belt(s) that turns the pulley and water pump, and check the water pump itself. Also, check for debris in the hose from the tub to the water pump,
Jun 18, 2008 | Hotpoint Washing Machines
Hotpoint wf250 drum wont spin
Well if you see the drum move in the wash cycle than the belt is still attached.Your door latch is the first thing to check.And the control board is the next and most likely problem.
May 24, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Programme not moving on
This is not something like a belt or a motor then...It's probably the Logic in the control system.
Your best bet is have a hotpoint engineer diagnose it - and fit a new control module. To buy from hotpoint they range from 70 to 90 Sterling.
In england the call out is £90 and they actually don't charge for parts if the machine less than 5 years old.
Feb 25, 2008 | Hotpoint Aquarius WF210 Front Load Washer
"Test" displays no washing done!
Your test mode is on, maybe accidently. Press "start", "cancel", "on" & "off" together for 10 secs, you will see d/off come on the display. Do the same & the test mode comes on again.
Rate pl.
Dec 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WMM75 Front Load Washer Logo
126 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
