I have a Servis 1400 AA 6Kg.When I press the on button the Yellow light flash above the start symbol.I wait a few miniutes but the machaine dosn't start.It just sits and keeps flashing
3 Suggested Answers
SOURCE: ive just moved into a
Hi. Set the dial to reset (12 o-clock position) then push button second from right. Now set to program required and press button again. Should work now. Needs resetting every time, this is normal. Hope it works for you.
Posted on Oct 09, 2010
  • 74 Answers
SOURCE: Servis 7kg 1500 AA - bush's and motor, ok and
relay is stacked so you start the machine off position power on the wash butten you will check this method
Posted on Sep 13, 2011
Timex number t235 clock radio, how do I set the time
easiest way to set clock time. Remove AA battery's if installed.
Unplug Clock from AC. Wait a few seconds. Then replug clock into AC power. Clock will now flash 12:00. Press hours button until correct time is set PM has led on AM has Led off. Set minutes to correct minutes. Then press alarm reset / power/mode button. Wait a few seconds and display will show correct time. Now you can put the AA batteries back in.
Apr 30, 2014 | Timex T065s Solar Powered- Radio...
Sep 13, 2011 | Washing Machines
Hp deskjet 948c. What Do The Button's Do
buttons and lights The HP Deskjet printer buttons let you turn the printer on and off, cancel a print job, or resume printing. The lights give you visual cues about the state of the printer
sayurisan20_33.jpgcancel button
print cartridge status symbol and light **The light above the Print Cartridge Status symbol flashes when a print cartridge is low on ink or incorrectly installed.
sayurisan20_35.jpg resume button and light
**The light above the Resume button flashes when an action is required such as loading paper or clearing a paper jam. When the problem is fixed, press the Resume button to continue printing.
sayurisan20_36.jpg power button and light **
The Power button turns the printer on and off. It takes approximately five seconds for the printer to turn on after you press the Power button. The green light above the Power button flashes when printing is in progress. Caution! Always use the Power button on the front of the printer to turn the printer on and off. Using a power strip, surge protector, or a wallmounted switch to turn the printer on and off may cause premature printer failure
Jun 17, 2011 | HP Office Equipment & Supplies
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
Ive just moved into a flat with a servis 7kg 1500AA washing machine and i have no instructions for it. when i press the on button the yellow light above another symbol flashes and nothing happens. ive...
Sep 10, 2010 | Washing Machines
I need instruction manual for servis m6723w
if theres 4 buttons on facia they are from left to right pre wash extra rinse spin cancel and start depending on which button is flashing you may have a problem if the dial is at 12 oclock and the start button is flashing set the dial to any program and the light should stop flashing if it does not you will need a new board for it and it will need resetting with a servis hand set as servis are now no longer you may have a problem... hope this helps
Jun 26, 2009 | Washing Machines
Used some washing up liquid instead of dishwasher tablets, after i got rid of all the bubbles and drained it, it no longer starts. If i switch the power off and leave it for a few minutes i can select a...
dear sir vif you have used liquid soap in your dishwasher it will make mountains of bubles to kill all bubles outin a hurry take a sos pad put it in your machine and run the dishwaser this will remove all of the soao instantly try it it really works i am in the dishwasher bussiness and it does work thanks from gilles
Mar 15, 2009 | Ariston Technologies Dishwashers
Power LED Flashing Yellow on Qosmio laptop F15
This flashing LED means only one thing, and it is quite harmless:
Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
Look for a symbol on keyboard for "sleeping" (like a half moon with zzzz) and press that key WITH whatever color coded key matches the symbol color (usually "FN" key). If there is no suchkey, press the space bar and hold it down a few seconds.
Then wait. Can take 60 seconds to "wake up" on slower processors.
If this does not work, press AND hold the POWER button for 10 seconds. Then wait 60 seconds and press power key again, briefly, to start laptop normally.
Pressing and holding the power button 6-10 seconds forces a complete system shutdown.
If this happens often, something may be wrong with APM or ACPI settings/driver. You can go to start menu/settings/control panels/power management and adjust settings (or disable sleep/suspend and hibernation if all else fails to resolve situation)
good luck.
May 29, 2008 | Toshiba QOSMIO F15-AV201 Notebook
Toshiba power led flashing yellow
This flashing LED usually means only two things, both are quite harmless:
1. Some laptops will flash the power LED when battery is charging. If this is the case, it should stop when battery is fully charged. This can be presumed if the laptop starts normally while LED flashes. If not, suspect step 2 below:
2. Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
good luck.
Washing Machines Logo
234 people viewed this question
Top Washing Machines Experts
