Question about Citizen Watches
I just acquired a Noblia Professional Diver watch but I need help with setting instructions. I can barely made out the movement number on the back, I think it says: 5862-F80154 TA.... NOBLIA "12" METER. On the dial, in addition to the hour / minute /second hands, I have 2 extra orange hands (1 large and 1 small). Can you tell me what these are for and, how do I use / set it; or where can I find setting instructions... Much appreciated
  • 831 Answers
Thank you for contacting FixYa.
You can download most Citizen instructions here:
http://www.citizenwatch.com/COA/English/settings.asp
Best regards. Jewel
Posted on Sep 14, 2010
How to set?& manual required invicta.15343 pro dive
Invicta Pro Diver - View model
invictawatch.com/collections/view-model/15342-pro-diver
INVICTA COLLECTIONS click to view models · AKULA ... Instruction Manual Print. More models of the same style. 15343. Invicta Pro Diver · share watch. 15341.
Sep 25, 2015 | Watches
Battery on m Invict Pro Diver watch replaced , now the second hand stays swinging back and forth in the same place
Do the minute and hour hands keep proper time? I've seen your problem before when the hand has come loose from the center post that turns it. You probably need someone who knows what they are doing to pull the crystal and reseat the second hand. Do this when the watch is off!
Sep 08, 2014 | Invicta Pro Diver 9309 Watch for Men
Need correct replacement battery
the watch movement deters which battery the watch needs it is very important you do not put a battery in that doesn't suit the watch as it can short out the circuit however you can get the correct size in a gold seal quality which should not leak, also the older the watch, the more demanding the watch becomes on the battery as the movement components start to experience wear and tear
Apr 16, 2014 | Wenger Swiss Military Alpine Diver...
How do I change the time on my Citizen Alarm Chronograph WR 50 watch?
First we need to determine what movement is in the watch.
Look on the back of the watch. You will see some numbers there will be a 4 digit number followed by a dash and 6 or 7 digit number.
The 4 digit number is the movement number. example e760 or b210. Ctizen has hundreds of them.
Next click on this link:
enter the movement number and click on get setting instructions.
Nov 07, 2010 | Citizen Watches
Noblia 12 meter watch setting time? I have no
Noblia are made by Citizen watches and you should go to their web site for instructions.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on "get setting instructions"
Feb 23, 2010 | Watches
On a Invicta Men's Off-Shore Russian Diver Quartz Chronograph Silver-tone Watch, the big min hand does not stop at the 12 clock position but instead stops 2 mins before the 12. It stops on the 62 instead...
It isn't a fault and can be adjusted. Follow this link and find out how to.... http://www.invictawatch.com/ Point at COLLECTIONS and click on INSTRUCTION MANUAL. If you don't know which one of movement makes you have, try both (RONDA first, then MIYOTA). When sorted with type of movement, check how to reset chronograph to 0 (zero).
Rate me, please.
Jan 12, 2010 | Invicta Off Shore Russian Diver Stainless...
Need a manual for an Invicta Minute Repeater Perp. Calendar #2731
The only site for Invicta watches is here:
www.invictawatches.com
You have to submit all the details of your watch and then you may find out manual.
You can download manuals for different movements used by Invicta.
You can contact them to get the needed info.
Do not forget to rate, please.
Jan 22, 2009 | Bulova Watch
DIFERENT DISPLAY FOR THE SAME WATCH MODEL.
A watch is considered Swiss, when it is made in Switzerland (hope I spelled that right), by a Swiss Comapny, using 50% or more parts that are also Swiss. Watches made this way will have "Swiss Made" Swiss" or a similar print on the back.
If it has the lables of "Swiss movement" "Swiss Case" then it means that it is only partly swiss made, and will not have a lable listed in the first part of this solution branded on the back.
Hope I helped, have a great day.
Jan 13, 2009 | Invicta Swiss Pro Diver 9309 Wrist Watch
How to set a invicta 3443 watch up
To set the time pull the crown out to the first position and set the time by turning the crown. Pull the crown out to the second position to set the date. Since this is a diver model you will need to unscrew the crown before it will pull out. Make sure you replace the crown and screw it back down for a good protective seal.
The alarm sets the same way. Unscrew the button to set.
Nov 24, 2008 | Invicta Pro Diver Collection Grand Diver...
Watches Logo
210 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
