Question about Huffy Cycling
I have huffy sprint scooter and after putting it together the brakes just don't work correctly. I have rechecked everything and it is as though there is extra slack in the line and won't pull the brake.
  • 35 Answers
At the point that the cable attaches to the brake it runs through a bolt with a nut attached. Loosen the nut (just enough to move the cable), squeeze the brake caliper slightly (about 1/2 inch clearance to the rim on each side), pull the cable through until tight and re-tighten the nut. Make sure both ends of the cable housing are seated (in the lever and the brake adjustment) before this adjustment.
Posted on Sep 14, 2010
How do you adjust the brakes when assembling ?
if you are having a problem with the brakes,then you need to get control over your legs,there is no brake,it is a three wheeler,operated by the front wheel, Huffy Green Machine Owner Manual Page 20
May 23, 2015 | Huffy Bikes Green Machine Tri-Wheel...
How to put together the 20' huffy green machine
There should have been instructions to complete this task in the box. If you didn't get them, lost them or never had them, I suggest (a) go to Huffy.com/customer service or support or (b) take the bike to your nearest bike shop for correct and complete assembly.
Oct 15, 2014 | Cycling
I need a manual for the Huffy Newport 26" Mens bicycle, I want to read one before I try to put it together. Mine was lost before I could see it.
Huffy has manuals for all of their bikes on their site, http://www.huffy.com/Support/OwnersManuals.aspx . The Huffy Newport is a single speed bike with coaster brakes. So the direct link to the manual is http://www.huffy.com/pdf/ownersmanuals/e0664c94-726b-49d6-8322-5e053dca5b0a.pdf .
I hope this helps.
Jun 11, 2011 | Cycling
In Drive position the wheels are locked and in neutral the wheels remain locked and will not spin or free wheel. In drive with the battery in the unit just clicks but does not move, everything works such...
I would suspect that the brake is not releasing causing your problem. When you place the handle in freewheel and you can't push the scooter easily then the brake pad is stuck on the motor housing. If you are able remove the seat and back cover remove the drive wheel on the side of the scooter nearest the freewheel lever usually the right side. you should be able to see the brake attached to the end of the motor with 3 or 4 hex head screws. take the brake off the end of the motor and carefully leave the wiring attached ( don't break or remove the wires going to the brake or the scooter will not run at all) remove the brake and place or tie it up where it won't fall or drag. Put the drive wheel back on and turn the scooter on and see if it will now move. If it moves like it should you will have to replace the brake. You can drive the scooter like this but remember you do not have brakes so the scooter can roll backwards or forward when not on and especially on ramps Hope this helps
Apr 23, 2011 | Drive Medical Drive Falcon 3 Wheel Compact...
Put rear hub back together
put rear brake together on huffy 26 in cruiser bike
Mar 23, 2011 | Huffy 26 in. Cranbrook Cruiser Bike
I ordered the replacement batteries for my Remington R-950 from the Shaver Outlet.com suggested on this site. I installed them (I think) exactly like the ones I removed. The new batteries have been...
Recheck your connections and recheck that the polarity is correct. Also, make sure that everything was put back together properly and nothing has bound up
Jul 11, 2017 | Remington Titanium Microflex R-950...
I replaced the water paddle now neith ice or water work
either a wire/block is not plugged in good or the micro swicth is not being activated. possibly the cup/glass cradle not in correctly. Recheck instilation
Mar 02, 2010 | Kenmore Refrigerators
Cycling Logo
89 people viewed this question
Top Huffy Cycling Experts
 Mikey
Mikey
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
