Question about Universal Electronics Pronto TSU9200 Remote Control
Our universal remote ( phillips pronto TSU9200 ) stopped working our reciever. The IR device seems to still be attached. Worked just fine 3 days ago.
    Genius:
  • 1,622 Answers
Common faults are: some buttons not working, not working at all, corroded battery terminals. Often buttons are sticky because of some dirt accumulated over the years from the sticky little hands of your kids?
The hardest part of repair is often to open the covers. You do not need much experience in electronics repair to repair a remote. Also it is perfectly safe as there is no way to get an electric shock as they work with batteries.
step 1Test your remote with Digital Camera
Check your batteries first or buy new batteries. Once you have good batteries, you can test with a digital camera by pushing the buttons and having camera on and pointing to the infrared led. You should see red light if the remote is working. If no light comes up you obviously have a dead remote but do not despair and procede to the next step
step 2Open the remote control but there is a catch or a few catches.
Remove the screws if any. Sometimes screws may be hidden under a sticker or rubber feet. Often there are no screws at all but just plastic catches hidden so you have to be clever to open it without breaking the case. Use something blunt and flat toclick the covers open. This is often a challenge but should not be too difficult.
step 3Take a picture of every phase so you remember how to re-assemble
Since you are using a digital camera you might as well take pictures of the disassembly so re-assemly will be easier.
step 4Pull everything apart
Did you take a picture of the keyppad layout? Sometimes keypad is just one rubber membrane but sometimes the keys fall away like pieces of a Lego puzzle. And if the buttons are marked with numbers and functions you may struggle to re-assemble them in right order? Use a small plastic takeaway box or similar to store the bits so you don't lose parts.
step 5Inspect the circuit board and repair dry joints
Remotes are often dropped on the floor and may develope dry joints on the battery contacts or circuit board. Inspect the contacts and circuit board under good light with a magnifying lense or if lucky you might have a microscope or just a very good eyesight? Solder all suspicious joints. If there is a sign of water damage you can use methylated spirits and toothbrush to…
step 6Wash the covers and the buttons
Use a smal bowl or similar to wash and contain all the parts so you don't lose bits down the drain. Use old toothbrush to clean all button holes and buttons. Warm water with dishwash liquid does the job. Take particular care with those small buttons and clean them properly. If you can leave the bits to soak overnight they come clean easy. Ultrasonic cleaner would be goo…
step 7Rinse, drain and dry the parts
Rinse with warm water. Use a drainer to contain all the parts without losing small bits down the drain. As extra security use sink plug. Dry with a paper towel. Wipe the buttons dry individually as they may still have some dirt which makes them sticky when in use.
step 8Repair case and re-assemble
If there is damage to the case or buttons you need to do the required repairs. Use hot glue or super glue depending on fault. Let dry overnight if you had to glue something. Re-assemble bits in reverse order and make sure you have the buttons in right place and right way around. Small nicks and dents on plastic cover can often be repaired by heating carefully with a h…
step 9Test with Digital Camera
Test every button as before. Sometimes you have to push two remote buttons simultaneously as with recording buttons on my Panasonic VCR. Once you have completed test with your camera you can use the remote.
Hope this help in solving the problem and Take care......
Posted on Sep 13, 2010
Where can I purchase 2-3 Phillips 'Pronto' SBC RU950/00 controls michaelburd20@gmail.com Australia
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops.
Mar 31, 2014 | Philips Pronto SBC RU950 LCD Touchscreen...
Unique On and Off IR codes
ahhh.ok..what is the model number of the PRONTO, please?
May 31, 2008 | Toshiba D-VR4 DVD Recorder/VCR
Will a universal remote control work on with ANY device? In particular I am interested in operating a Technomate TM 5400 Digital Satellite receiver...
Universal remotes are never guaranteed. They must send the proper signal to the device you are trying use. This is done by changing signals via codes that are preset. There are remotes such as the " Pronto " made by philips. An expensive universal remote however it can open your garage, turn on a fire place that and anything else that is connected in your house using IR to be remotely operated.
May 07, 2010 | Sony RM-VL710 Remote Control
Finding remote codes for Sony KDS-R70XBR2 television and Panasonic DMP-BD55 Blu-Ray player? Am trying to configure a Pronto TSU-9200 Universal Remote and their database does not show these components.
www.sonystyle.com/.../SonyStyleStorefrontAssetStore/.../KDSR70XBR2.pdf
service.us.panasonic.com/OPERMANPDF/DMPBD35-MUL.PDF -
Those two manual have the codes for each
www.remotecentral.com/ - United States
www.pronto.philips.com/library/.../DataSheet_TSU9200_00.pdf -
www.remotecentral.com/.../ind-270.htm - United States - 6 hours ago -
I too have checked exhaustively apart from the info at these links above, It appears that you may have an incompatible remote.
www.remotecentral.com/cgi-bin/codes/ - United States -
www.slingcommunity.com › Forums - <<CHECK OUT
www.universalremote.com/faq.php -
Read up from that lot it will sort you out. Heaps of help and info Visit them ALL
Mar 28, 2010 | Universal Electronics Pronto TSU9200...
Is there an alternative to using the remote on the iomega media external hard drive. will a unuversal remote work?
Yes ,universal remote with learning capability will work just fine,just buy one like philips pronto and aim the iomega to the learning remote wile in learning mode,each function will have to be memorized independently.
same has any other ir remote control.
Jan 16, 2010 | Iomega ScreenPlay
Remote Control not working
you can easy check if you existing remote really work just look on the IR led with a digital cam and u will be able to see the led flashing
Feb 05, 2008 | Toshiba MD20F51 20 in. TV/DVD Combo
REMOTE DOES NOT WORK ON SYLVANIA TV
It sounds more like a problem with the TV, than the remotes. It's possible that the IR reciever or microprocessor for it have pooped out. It's something that would have to be serviced by a shop, but due to the age and size it would likely be cheaper to replace the whole TV.
Dec 04, 2007 | RCA F25432 25" TV
Universal Electronics Pronto TSU9200 Remote Control Logo
576 people viewed this question
Top Universal Electronics Televison & Video Experts
Electro Med Services...
Are you an Universal Electronics Televison and Video Expert? Answer questions, earn points and help others
