Question about LG Microwave Ovens
I got an F-1 fault code on an LG Model MS3046SQ microwave oven. I bought this oven only 2 weeks ago in Saudi Arabia. Please help... Thank you so much.
3 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: GE SPACEMAKER XL MICROWAVE OVEN JVM1440
Assuming that your internal cooling fan is working, I would suspect that your magnetron is failing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the
left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I would check the cooling fan, then suspect the magnetron.
Posted on Nov 16, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave stopped working for no reason
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find your tech sheet, you can download it here.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
You can download Whirlpool owner's manuals and installation instructions here.
Posted on Nov 23, 2008
LG Solardom MP-9483SLA bought 2 yrs ago,
Idont understand the problem pls write the main problem
Sep 15, 2014 | Microwave Ovens
1. Flexible joint at base of cleaner. 2. Fixed pipe connected to 1. above
Your question is under the Microwave Faults heading and clearly it is not a microwave fault.
You don't mention a make or model and only half a line of the fault is shown.
Please set up a fresh query.
Thank you.
Jan 11, 2011 | Microwave Ovens
My LG (model ms3446vrl) wont heat anything. Everything else works fine. It is only 2 weeks out of warranty too, not happy. Lynda
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jan 04, 2011 | LG LMV1680ST Microwave Oven
I have bought Daewoo microwave 2 yrs ago . One week back when i have started my oven , i heard a sound and then after that its not working . Actually food is not getting heated . How can i solve this...
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Spares are available from many outlets.
Hope that helps.
Dec 23, 2010 | Daewoo KOR-1B4H Microwave Oven
Microwave owen SHARP Model R9H20 Digital START button is not working. Need Workshop address in Dammam or Al-Khobar, Saudi Arabia including phone numbers to fix the problem.
R-9H20 (W) sharp microwave oven- the turn plate does not work kindly let me know what needs to be done. i need help. Kindly e-mail me .
zaffarlone@yahoo.com
Zaffar Iqbal
Dec 18, 2010 | Sharp Microwave Ovens
I had bought the electric pressure cooker 2 months ago and was working fantastic, suddenly it stopped working this week and there is no power light even coming up - PLEASE help
Probably the main wire is faulty or the fuse has blown out.open the cooker from below
{find,check the fuse with a continuity tester}do check the main wire with the help of a continuity tester too for any kind of breakage.If there is no continuity or the tester bulb does not light up there is a fault with the component.Replace the wire/Fuse with the same rating or quality and your cooker will surely work
Dec 04, 2010 | Microwave Ovens
Model 63259 bought about 2 months ago. I went to
you can check and see if there is a fuse on the microwave, if not it may have just burned out, its probably still under warranty so try to take it back for a replacement
Jan 14, 2010 | Kenmore 63252 Microwave Oven
After not using for 2 weeks , display panel
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms ("F2 on display").
Nov 23, 2009 | Kenmore 63792 Microwave Oven
Only some of my keypad will work
if your keypads dont work maybe the cushion or spring beneath is worn, so check your dealer with your warranty documents so you can get it exchanged
Jan 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Lg LMV1630st stainless steel microwave oven
I'm confused. If it's 6 weeks old, you can get it repaired free.
If it's 1-1/2 years old, the manufacturer will cover the part cost of the magnetron (assuming that's what's wrong) and you will have to pay for labor and any other needed parts.
Also, the subject line mentions a model LMV1630ST while your message body mentions model LMV1680BB.
For Goldstar / LG / customer service, help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Chances are your problem is a bad magnetron, but it may be another high voltage part.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | Microwave Ovens
Microwave Ovens Logo
90 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
