Question about Dell Dimension C521 PC Desktop
Audio pc says pc does not have the right audio format to use my mike when i try to use it in yahoo messenger
  • bill champagne May 15, 2008
    its a quick shot mike reguler **** os is vista on my dell dimension c521
  • Dung Nguyen May 11, 2010
    make, model and OS of PC please to find the driver for you.
    After installing the driver, then you will have to configure the MIC.
Helpful
Posted on Nov 29, 2008
  • alexbucnguye Nov 29, 2008
    How can I down load Video card driver for W -xp \s2
    video driver c521 w-xp /s2
My yahoo messenger voice call pc-pc working but the other side can never hear me! But if I use skype no problem. It used to work but may be because I changed my wireless router to Belkin! But I also turned...
Try running through your settings again
Typical audio set up
Laptop with mic x webcam with mic x Vista x Yahoo Messenger 10
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO MESSENGER
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Video and Voice
Set webcam mic and speakers to show Default equipment
Open Video and Voice Setup to test audio equipment
Click 'Place a free test call'
Check box 'Allow USB devices to access Messenger'
Click 'Apply' click 'OK'
May 15, 2010 | Yahoo Messenger
DELL 630m audio problem
It may be that your PC is now reading the mike as a crystal mike and the signal is too strong. Try to attenute the signal by pluging the mike into a mixer box to reduce the signal strength.
Jun 13, 2009 | Dell Inspiron 630M Notebook
Webcam's color compression format is mjpeg, said to be not compatible with yahoo messenger
Normal 0 See section B. Yahoo Messenger in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://ca.messenger.yahoo.com/download/ ) set it up as follows:
  1. Click on Messenger at the top left and then go down to Preferences and then the Preference Window will come up.
  2. Next click on Calling and Devices. In the Calling & Devices on the right and set the Microphone and Speakers to the computer Audio Card or sound device installed in the computer.
  3. Just below that, go to the Test Audio section and (in blue writing) click on Open the call setup assistant” and follow the instructions on the left window.
  4. Then after completing the Audio Setup, go to down and click on Webcam.
  5. After make necessary settings, click on APPLY, then on OK and it should be ready to use.
Hope this helps. Bud
May 01, 2009 | A4tech PK-635 Webcam
The camera works fine but I keep losing the Mike. it seems that everytime I get any kind of update on my PC that my mike just quits. I like the camera and mike combo but this constant lack of mike is...
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Mar 13, 2009 | Logitech Quickcam Chat Webcam
Failed connection
Normal 0 See section B. Yahoo in the info below. Try installing Skype and it's much better for Chatting with Family and Friends.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Jan 20, 2009 | E-Machines eMachines Desktop PC
Audio format
In control panel, make sure that the mic is properly configured in audio devices (They don't always get assigned properly) so that the correct device is set for recording.
You can test the mic in sound recorder (Just type sound on the search bar, it should appear in the list)
May 15, 2008 | Dell Dimension C521 PC Desktop
Yahoo messenger
check out ur audio driver in device manager look for update.
you can update in device manager but sometimes(more often than not) get reply latest driver installed.
well the latest driver isnt always the best.
if this the case download a driver from hp site .if driver still no better or worse;you can roll back driver in device mannager to previous one.
could try update codecs (encode/decode) as different codecs have different compression ratio's.
Apr 10, 2008 | IBM ThinkPad T23 Notebook
Problem in audio for windows vista
This is a warning message due to improper sentting of your messanger and your net-protocol. Allthough even then you can make your voice-chat without any problem. So dun wrry just ignore the message.
Thanks
iqbal
Mar 09, 2008 | Microsoft Windows Vista Home Premium DVD...
Mike not working
She needs to check her Audio settings. Send her the following info.
A. Skype Setup:
B. Yahoo Setup:
Nov 26, 2007 | Logitech Webcam
Dell Dimension C521 PC Desktop Logo
26 people viewed this question
Alun Cox
