Question about Epson 10000XLGA
Rainbow color streaks across scanned image - Epson 10000XLGA
  • felix_valle_ Sep 13, 2010
    does not fix problem, tried weight on lid prior to conracting you, negatives and photo are not bowed
    Why do I have rainbow colored streaks across my scanned image? The image is lying flat and we have put a book on the top of the scanner to make sure the image is flat. What do I do next?
  • 8,197 Answers
If you are getting the streaks when you scan that means that the scanner cartridge is misaligned. try this.
1. Shut the computer system off, then disconnect the scanner from the power source. Leave the scanner disconnected from the power source for at least one full hour.
2. Reconnect the power, then restart the computer system.
If this did not fix it then it will need to go to a service center to have it repaired.
Good Luck
Posted on Sep 13, 2010
  • 182 Answers
Hi,well this is problem which can be solved easily b you Curled, curved, or bowed pictures and photographs create this effect. When the light from the scanner crosses the curved areas of the picture, the reflected light comes off at an angle, producing a hazy blue fringe at the bottom of the scan. If the curve is severe enough, there can be rainbow colored streaks across the entire picture.
#Solution
Scanning from the scanner glass
Change the orientation of the picture or photograph from portrait to landscape or from landscape to portrait. If this does not correct the blue shading, place a book or other weighted object on the scanner lid to insure the picture lays flat against the scanner glass.
#Scanning with the Automatic Picture Feeder (APF)
Straighten the pictures as much as possible before inserting them into the APF. In order to accommodate the automatic photo feeding process, the scanner lid does not to compress fully against the scanner glass.
When pictures are not pressed flat during scanning, the blue shading or rainbow streaks can appear on the scanned image.
Bingo thats it...and you solved the issue :)
  • Goldi Kunal Sep 13, 2010
    well one more thing ...hae you tried clanning the glass ?
Images have a streak of color in the middle
The problem you describe sounds like moire.
Try scanning the image at different resolutions until the effect disappears.
Dec 12, 2013 | Kodak i1420 Pass-Through Scanner
I am using the Epson Perfection V700 photo scanner to scan dental xrays. Sometimes the xrays come out perfect, other times I get streaks across the image. Sometimes the streaks are colored, othertimes...
You have to use the "FILM AREA GUIDE" included with the scanner. This black plastic guide leaves a small area at the top of the glass open so that the scanner can calibrate itself at the start of each scan. Use the guide or leave at least 8mm between the top of your film and the top of the scanner glass.
Jan 24, 2011 | Epson Perfection V700 PHOTO Flatbed...
Red and yellow streaks appear in scans, always in the same location. The scanner was cleaned but the repair person could not find any problem with the equipment. Yet the streaks persist. How do I resolve...
execute a calibration to correct the wrong color:
  1. place your photo on the scanner, with a distance of 0.25 inch from the edge of the glass
  2. open Epson scan and select Professionnal Mode
  3. select the document source
  4. select the image type
  5. uncheck thumbnail then click Prevew
  6. crop the area of the image
  7. Click zoom to fine tune the area you see the streaks
  8. select the resolution of 72 dpi
  9. scan your photo
if the problem still not solved, you need to change the scanner unit , there are many dead pixels.
Dec 09, 2010 | Epson Expression 1640XL Pro Flatbed...
I was getting streaking across all photos that I was scanning. So bad that I researched getting a new scanner. Then one day it started working just fine. Now today I scanned some slides and when I tried to...
sounds like the scanner is skipping pixels. that is usually a sign of malfuncting. the best solution is get a new one. cost of getting new one is much cheaper to repair it.
Oct 17, 2009 | Canon CanoScan 4400f MultiFunction Color...
Color distortion with HP 2300 scanner
Hp scanner 2300c
while scanning a blue or red line appears on scanned imajes
Mar 17, 2009 | HP ScanJet 2300C Flatbed Scanner
Epson V300 Photo Scanner Streak When Scanning Negative
I also own a v300, and I have noticed that I occasionally get rainbow streaks if I bump the scanner at all while it is scanning negatives, so this might have something to do with vibrations in the machine. Is it sitting on a stable surface?
Mar 14, 2009 | Epson Perfection V700 PHOTO Flatbed...
Yellow streak through color image scan
http://www.carlmcmillan.com/CanonScanner/Canon.htm
Feb 25, 2009 | Canon CanoScan 8400F Flatbed Scanner
I620 scanner
Is the scanner scanning normally otherwise? Try scanning a printed matter with white background and if it is okay, then the streaking may be because of excess brightness chosen. Check if the paper movement is at constant speed. If it is smooth paper, it may slip and the same area may scanned again, appearing like a streak.
S. Moha, Chennai
Nov 07, 2008 | Kodak I620 SHTFEDSCAN Path-Through Scanner
Streaks on prints
Lines/streaks at the same location indicate either a speck of dust stuck on the glass or the glass may be scratched.
S. Mohan
Aug 19, 2008 | HP Photosmart s20 Film Scanner
I think your flatbed lamp is damage
if u replace or color it pure white ink
Jun 10, 2008 | Office Equipment & Supplies
Epson 10000XLGA Logo
1,394 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
