Question about E-Machines T2742 PC Desktop
Need a new DVD-ROM DVD Burner CD-ROM CD for my EMachines T2742 Tower. Are there any Parts numbers or other information available? Ex... type of connectors necessary etc.
  • 37 Answers
The way this question has been asked makes me think that you are still under warranty and you are worried about voiding the warranty. With that being said if that's the case your going to void it no matter what when you install a new drive. So just open the case and see what kind of connection that the old drive is installed with(most likely is An IDE connection) then go to www.tigerdirect.com and purchase a new DVD drive. When it comes to new disk drives they are no certain ones that have to go back in the computer as long as the connection is the same and you have your jumper configuration the same.
Posted on Sep 13, 2010
  • 734 Answers
HI there,
Your complete user guide with parts and disassembly info is here:
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T Series&model=T2742
Best Regards,
Marcus
E-Machines T2798 specs
Key FeaturesOptical Drive TypeDVD-ROM • DVD Burner • CD-ROM • CD BurnerForm Factor DesktopProcessorIntel Celeron 2.7 GHzOperating System Microsoft Windows XP Home EditionProcessorProcessor ManufacturerIntelProcessor Type Intel CeleronProcessor Speed 2.7 GHzMemoryInstalled RAM 512 MBCD / DVDOptical Drive Type CD-RW/DVD-ROM (Combo)MiscellaneousFamily LineeMachines TProduct MPNMPNT2798
Mar 06, 2012 | E-Machines eMachines Desktop PC
I am unable to connect a cd rom from an old pc to my new emachines because there is no "ribbon" to connect the cd to? How else can I connect it to the motherboard? The CD doesn't have a SATA...
Look on the mother board for a ribbon connector.. double row of pins.. Some boards will have a legacy connector. If not.. you can buy an adaptor to connect IDE CD to board,
BUT.. for about the same cost, you can buy a cheap new CD-DVD RW - burner.. probably with far better peformance than an old one. About $25 should do it.
Dec 13, 2010 | E-Machines emachines (emachinees) CD-ROM...
Hi i have towers 5 burners each. Most of the burners are failing dissc half way. It is about 5 years old. How can i fix it. Also the main rom ( i have disabled it) cuz the dvd would keep on rotating and...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall or
try using a diferent brand/type of cd-rw you may have a bad batch of cd-rw
hope this helps
Dec 10, 2010 | Tower Produplicator 7 SATA Burner DVD CD...
How do I open the tower to insert a c d
Open My Computer and then right click on the CD/DVD drive of your system that are define. For example: "E, or F, or G". Click on eject. or Press on the button CD/DVD-ROM. Mostly it's located in the right sight just below the CD/DVD-ROM "where the CD/DVD can insert". And if this two is not working than take a pin length around 2.5" and push inside the hole it's located in the right sight just below the CD/DVD-ROM. Hope it'll be helpful to you. All the Best!
Oct 07, 2010 | E-Machines eMachines Desktop PC
I need to replace the dvd/rw in my GT5026E but cant find the original. What will replace it
Any 5 1/4 DVD / CD drive will work. You may have to order drive rails depending on the setup of Gateways tower. You should have 2 - 5.25" Drive Bays available. The original model number and name for the DVD drive is 5648 DVD Burner Combo Drive .
The tower does have internal SATA so you can replace it with any internal SATA DVD rom you like, it doesnt have to be Gateway, and it can even be blu-ray.
Hope this helps
~mac
Nov 17, 2009 | Gateway GT5220 PC Desktop
GDR-8160B 16X 48X dvd-rom I need a dvd/cd-rom
Here's a place to grab a new burner:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4974039&Sku=L12-1336
Sincerely,
Ryan Deschaine
Systems Administrator
Boxen Solutions LLC
http://www.boxensolutions.com
Email address: ryan@boxensolutions.com
Office number: 262.254.0064
Mobile number: 262.834-5844
Fax: 414.918.8432
AOL: BoxenRyan
Twitter: BoxenRyan
W172 N9175 Shady Lane
Suite 418
Menomonee Falls, WI 53051
Sep 22, 2009 | NEC ND-3500A DVD±RW Dual Layer Burner
I can't burn anything with my DVD/CD-ROM but it reads dvds and cds
first reinstall the operating system and then you use either nero 6 or NTI CD? DVD maker
Jun 01, 2009 | Computers & Internet
Can't R/W onto a dvd
Your statement says you have a DVD/CD player. You need a DVD burner.
Mar 19, 2009 | E-Machines emachines (emachinees) CD-ROM...
CD Rom and DVD Rom won't work
you need to delete lower and upper filters from registry to fix the problem instructions CLICK HERE
Dec 28, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
E-Machines T2742 PC Desktop Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
