Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My garrge door does not close, the alignment light is not working
    President:
  • 3,197 Answers
If by alignment light you mean one of the door sensors light is out and will not come on when the sensors are pointed at one another you need new sensors. If this is not what you mean post back with a little more info.
Posted on Sep 13, 2010
How to get my garage door to open all the way?
Three blinking lights & door won't close by Candi
(Winston-Salem, NC)
Garage door will not open and close with remotes. Three blinking lights occur when we try to close door. What does this mean? It is a Linear unit.
I will assume you mean that your garage door will open with your remote but will not close. It should close if you press and hold the wall control button until the door is fully closed.
If that is the case, the 3 blinking lights indicate that your garage door's infrared safety beams are not properly aligned.
1) Check that the operator has power. The green lights on the sender and receiver should be lit.
2) If the receiver's green light is on, but the red light is off, the receiver has power but is not detecting the infrared beam from the sender. The red light might flash when the beam is partially detected. This can be caused by
mis-alignment or something blocking the beam.
Adjust the safety beam sender and receiver while watching the receiver's red light (stay out of the beam while aligning it). When the red light stays on, the beam is aligned and your garage door should operate normally.
http://www.linearcorp.com/pdf/manuals/LCO75.pdf
NOTE: If the receiver's red light remains off, check for:
1) Dirt on the receiver's lens,
2) Sunlight shining into the receiver's lens,
3) A short in the safety beam wiring (from staples or at the operator terminals).
Jun 15, 2014 | liftmaster Garage Door 1/2 Hp
The light on the Garage door blinks but doesn't stay on.
(Winston-Salem, NC)
Dec 02, 2013 | liftmaster Garage Door 1/2 Hp
Garage door light blinks but doesn't stay on
(Winston-Salem, NC)
Chamberlain garage door will not close
If your garage door will not close from the open position and reverses immediately or part way down there is a safety beam problem, usually there is a safety light on the opener which will flash when the safety beam is activated or faulty. Clean the photo beams with a clean damp cloth, check if the door now operates, if it does not, check that the safety beams have not become misaligned, there is normally a light on one of the sensors that indicates when they are correctly aligned, if the light is on it means they are not aligned, the light off indicates they are aligned. If they are not aligned try adjusting them, if this does not work they are probably faulty.
Further reading garage door opener repair guide
Jun 16, 2012 | Chamberlain Power Drive 1/2 HP Chain Drive...
The door won't close with one click, I have to keep pushing the wall button to close the door, remote control won't work except for one inch movement down, the door will open with one click from both wall...
Sounds like a problem with the safety photocells, to confirm locate the where the safety input is on the opener and bridge out the terminals ( not the supply voltage terminals) if the door then closes the photocells are the problem.
Apr 02, 2011 | Linear Ldo50 Residential Garage Door...
Door will go down until it gets close to the sensors (transmitters) and then it hesitates and goes back up. One of the sensors has a constant green light which tells me that it works properly, but the...
The sensors have to see each other in order for the system to work. If the beam is interrupted, it will cause the door to go to the open position. It sounds like the sensors are out of alignment. When the door is closing, it moves a sensor slightly and this breaks the beam, door reverses and opens. Work the sensors so that they are both aimed perfectly at each other. I believe that the amber light will change to a different color when the sensors are aligned.
Jan 29, 2011 | liftmaster Chamberlain Garage Door Opener...
Our Chamberlain garage door will open, however when trying to close it will flash 10 times and not move. The only way to close the door is to push and hold the garage wall mounted closer until the door is...
Hi, W/D here.
Check the alignment of the photoelectric door eyes, located at ankle height on either side of the door. Usually, something is preventing the light from reaching the other side (receptor), and check to make sure that the eye lenses are clean. (You cannot actually see the light beam). Check that the lights are on and (usually) green on both sides of the door. These are the indicators that show you that the sensors are working. If one has been knocked out of alignment, it can be re-aligned using a string line, and observing the lights on the light and receptor. Somewhat more common is that one of the wires is either touching the other, or has come loose. Usually, the wires are just twisted together at the eyes. Lastly, if you have no lights lit on the eyes, and adjusting doesn't resolve the issue, one may be defective. Replacements are available at Lowe's/Home Depot, and others.
Check your lights first, and look for something blocking the path of the light.
Best Regards, --W/D--
Jan 28, 2011 | Garden
Hod do I align the sensor lights?
Your problem is not with the safety eyes. You have a stripped gear inside the opener. Take off the cover and you will have white shavings in the bottom of the cover. You can repair this with a liftmaster gear and sprocket kit.
Mar 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Liftmaster Pro. Garage door Problems closing
The sensor eye - or more likely, the other end, the sensor light - probably got knocked out of alignment. The eye should have an LED on it - possibly one that glows green when it's ready to close or red when it's obstructed or out of alignment. Try adjusting the light until the LED on the receiver glows green.
Dec 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Automatic Garage door reverses and automatically opens after closing
I can't believe it! My opener works fine a 10 degrees and above but below 10 degrees it would go down a little ways stop and go back with the light flashing. I checked the electric eye and found it would go out of alignment when the temp drop. Who knew!
I made the adjustment and it now works fine.
Jan 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
91 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
