Honeywell HT-800 Table Fan
Problem for Honeywell HT-800 Table Fan
Honeywell fans
By bettyrowland on May 15, 2008
how do you open the fans?
Best Solution
posted on Aug 13, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
If you look on the back of the fan, there are a series of small holes going round the perimeter of the case, just outside where the grill finishes. Using a philips-head screwdriver, unscrew the screws located here. Pull off the front of the fan and clean. Reverse the process to put the case back on, making sure that all the spacers are in the correct place.
Solution #2
posted on Jun 21, 2009
Very Helpful)
James Elric
Rank: Apprentice
Rating: 100%, 2 votes
There are actually *NOT* 6 phillips screws. There are 4 in an "X" fashion (at 2, 4, 6, and 12 o clock). The last two at 12 and 6 are HEX heads.
The space is *VERY* tight, so you may want to choose a small screwdriver of the correct type, lest you strip the screw completely (like I've just done) and find yourself with a fan-sized hole in your wall.
Also, it may have just been my fan, but if the phillips screws don't come out all the way (like just a little), take a flathead and push *up* from the bottom while you unscrew it. Or you could get lucky and knock them out with a few, well-placed palm strikes.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Honeywell HT-800 Table Fan
Questions and Unsolved Problems for Honeywell HT-800 Table Fan
Do you recommend Honeywell HT-800 Table Fan?
Answer
Answer
I cannot remove the grill to clean... i removed the screws from the back but it still will not... (More)
Answer
Honeywell 810 fan begins to turn with a jolt, then spins very slowly, with labored sounds from... (More)
Answer
i need ball bearings for the fan and cheap to , i do need two pears
Answer
There is so much dust inside the fan. How can I clean it? Is there a way to open the rim of the fan?
Answer
how do you clean the dus out of the inside of the fan
Describe your Electric Fans problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Electric Fan Experts
Top Small Appliance Repairmen
in Newport, KY
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
