Question about Mitsubishi WD-73827 73" HDTV DLP TV
I came home to find that the tv won't turn on. I unplugged and plugged it back in. Just won't turn on and it was on a surge protector. Unplugged it from there and directly into the wall still nothing. Outlet is good
    Genius:
  • 1,622 Answers
Common problem with this TV is the power supply module.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
Hope this help in solving the problem, Take care...
Posted on Sep 13, 2010
I have a 55" Panasonic flat screen that won't turn
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 29, 2013 | Televison & Video
I had to unplug my tv today (actually the TV is plugged into a surge protector, so I unplugged the surge protector.) when I plugged the surge protector back in the TV wouldn't go on (acts as if its...
There should be a surge release button on the surge protector to bring the protector back to normal (should be red in color) Some surge protection devices have this option so just check if your s has it. If that is not the case than I think that you might have blown a fuse in your TV.Might just have to open it up and change the fuse within with the same ratings, but please be careful because do have high voltages so get an experienced technician to do this for you.
Good Luck.
G.
Jun 29, 2011 | Televison & Video
My 7760 DX was not used for 10 days; came back to home office and computer indicated I was off line; checked printer and noticed that read out box was dark; turned on and then off; unplugged and printer...
Were there any storms in the area and did you have it plugged in to a surge protector? It definitely seems to have some power. I would try plugging it in to a different surge protector. If that doesn't work you may have to work with Xerox support as their may be damage if there was a surge.
Apr 13, 2011 | Computers & Internet
My electric went off yesterday and when it went back on my tv wouldnt turn on it was working fine before the power cut we have changed the fuse but still nothing is there anyway i can reset it to make it...
you said you changed the fuse. (inside the tv)double check to see if its blown agian if not. keep it unplugged for about 20 minutes to reset the surge protector onboard . if you have done all that the fuse didnt protect your tv from the surge and it gone. IF ITS CONNECTED TO A SURGE PROTECTOR unplug it from that and plug directly into the wall TRY THAT FIRST let me know if this works.
Mar 16, 2011 | Wharfedale Televison & Video
Unplugged my 32LV67U to vacuum behind it and now it will not power up. Yellow LED keeps blinking and I waited several minutes but tv will not power up. Worked perfectly until I unplugged it. Called...
That wall outlet may have frequent surges so try another wall outlet see if it turns back on. If it turns on be sure to use a surge suppressor and never plug the TV directly into the wall outlet. The AC surges will kill the power supply of the TV in short time. See if there's a kill-switch near the ac adapter of the TV if there is turn it on.Get a surge protector/suppressor then try plugging it back in the wall. If still no power then the power board is already damaged, you can send the board too me and I'll repair it for you or seek your local repair center.
http://tvtechwork.webs.com/
Oct 18, 2010 | Toshiba Regza 32LV67U 32 in. LCD HDTV
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
42" westinghouse flat screen wont turn on
Some surge protectors fail just when most needed.
Jun 19, 2017 | Westinghouse TX-52F480S 52 in. LCD TV
TV turns itself off
Sounds like you need a new power supply board
Nov 26, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Mitsubishi WD-73827 73" HDTV DLP TV Logo
56 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
