Question about Acer AL1916W 19" LCD Monitor
LCD and Gaming
I just bought an Acer LCD monitor and noticed that the frame rate for my Microsoft Flight Simulator 2004 has gone down from 30 fps to 20 fps. I have the monitor connected to my pc with the 15 pin D connector cable. Would using the DVI connector make any difference? If not, what can I do to improve the frame rate?
Monitor should not have anything to do with frame rate.
If you have increased the resolution of your video card because the 19" is larger than what you had before, that could cause a frame rate issue.
Something else got installed, that is slowing down your machine...
Coincidence...
Connect the old monitor and what is the outcome? Does the frame rate improve again?
Posted on May 16, 2008
I loaded flight simulator 2004 on my new computer with windows 8.1. It loaded fine. After when I clicked on the flight simulator icon, the program will not run.
if you ck the box the game came in you will see that its only 4 win2k and maybe win-xp depending on the time you bought it , it wont run in a windows version that was created long after it was written , now that being said , win 2kpro version does have a backwards compatibility version , but then the other newer software you have loaded will not run stable and is prone to crash"s (blue screen of death)
a possible solution to your problem is something like I've done ,I've taken a old laptop with win xp running on it ,and islanded it (never connects to internet or network) so that m-soft cant ever shut it off this one I load all my great ole games to it (flight sim, trainz ,etc.) and it works just fine
Sep 28, 2015 | Microsoft Flight Simulator 2004
Loaded but wont run when activated
Check this link for more info...
Also don't know your OS ?
Flight Simulator 2004 doesn't run correctly on Windows 8. It runs on my Windows 8 laptop bought in April 2013. But, none of the aircraft, including any add-ons, show up in the preview window - it is always black. Also, If I download weather and try to save a flight, when I go back to that "saved" flight, it always reverts to the default flight with the Cessna @ the default airport. If anyone knows how to make the flights save, on the Windows 8 platform, please let me know - likewise, with the aircraft previews. Flight Simulator 2004 did quite well on the Windows XP platform for me.
Apr 18, 2014 | Microsoft Flight Simulator 2004 Update
How can i use the motion eye camera to capture picture? only video recording is the one i can use.. please help..Thanks
Frame rate is also a term used in real-time computing. In a fashion somewhat comparable to the moving-picture definition presented above, a real-time frame is the time it takes to complete a full round of the system's processing tasks. If the frame rate of a real-time system is 60 hertz, the system reevaluates all necessary inputs and updates the necessary outputs 60 times per second under all circumstances.
Owing to their flexibility, software-based video formats can specify arbitrarily high frame rates, and many (cathode ray tube) consumer PC monitors operate at hundreds of frames per second, depending on the selected video mode. LCD screens are usually 24, 25, 50, 60, or 120 FPS.
The designed frame rates of real-time systems vary depending on the equipment. For a real-time system that is steering an oil tanker, a frame rate of 1 FPS may be sufficient, while a rate of even 100 FPS may not be adequate for steering a guided missile. The designer must choose a frame rate appropriate to the application's requirements.
http://www.mercedesbenzwheel.com
May 23, 2012 | Computers & Internet
I cannot create a flight on fs2004.when ever i go to fs2004 the system will shut down or go blank.
first all have you added any type of addon's like new airplanes
or scenery if you have then something there may be cousing your problem. if its an airplane go back remove that airplane. and try again
if all this fails you can reset flight sim 2004
go to Start then program files then microsoft games there you see microsoft flight simulator 2004 click on that then another box open up you see troubleshooting you notice in there rest to defaults
do not use this unless you wont reset it all to defaults settings. if this does not cure the problem then a reinstall of flight sim is needed. if you need any more help please ask
May 12, 2010 | Saitek Pro Flight Yoke System Flight...
MCFS Joystick Problem
Make sure, that your Joystick is compatible with the version you are having problems with. If not, make sure that it's enabled in the configuration of MCFS. If none of those work, you will most likely have to purchase a more compatible Joystick.
Matt P,
Computer/Gaming Relations Team.
Sep 16, 2009 | Microsoft SideWinder Precision Pro 2.0...
No force feedback only with Flight Sim. 2004
O-the sweet feel of a Microsoft Sidewinder Force Feedback lets see if I can be of some help. there could be any number of things going on but I'm going to give this a try. have you checked the settings in Flight Simulator 2004 seems to me that I remember a check box that said disable force feedback make sure that is unchecked. also in the settings for your controller there is a box that says enable force feedback make sure that is checked. then make sure if you are using a firewall like zone alarm you are in gaming mode because this used to give me major headaches with my system to the point I had to detach from the internet and shut down my firewall to play my games. if this doesn't work you may have to reinstall the drivers for the sidewinder this is the last easy option and it should repair any broke links and reset itself into your system. Please let me know how this helped if you need more Ideas just contact me.
Jul 24, 2009 | Microsoft SideWinder Force Feedback 2...
Webcam Issues
The frame rate setting may be set to "Auto". Maybe the angle of lighting in your house or even other factors like glare, reflections etc may be factores. Try changing to setting to a frame rate that you feel is good enough.
Jul 06, 2009 | Acer Aspire One PC Notebook
Acer AL1916W 19" LCD Monitor Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
