Question about RCA DRC8320 DVD Recorder/VCR
RCA DRC8320 hello error on display-found multiple caps in power supply that have bad esr on Sencor cap checker. Any ideas
  • RCA Master
  • 1,516 Answers
Replace them, and don't use the same brand series. For the one I presently have in the shop, I plan to use low impedance high temperature capacitors such as the Nichicon UHV1E102MPD (replacement for the 1000
Posted on Sep 22, 2010
Power source out
You will need to inspect the power supply. The chances are real good you have bad capacitors in the power supply. I would estimate there will be 5 capacitors that will be replaced. You may change them all, which is best. Some capacitors will check good when they are not. The power supply will be the smaller of the two boards inside this TV. It is also the easiest to pull out. You may use a capacitor checker to locate the bad caps. This is know as an ESR meter. Once again, it may show a good cap when it may in fact be a bad one. This is rare of course, but I have been there. Please replace all caps in the power supply board. If there is a good capacitor it will be the 400 volt 100Mf (Largest capacitor in the power supply) that is fine! Thanks for asking and show all hands of support.
May 21, 2011 | Protron PLTV-32 Television
The reset light is blinking continuously. Unplug the TV for 10 minutes, didn't fix problem. Power button at front of TV cannot turn TV on/off - it's frozen. At this point, the remote control doesn't...
My first move would be to inspect the power supply board for bad capacitors. look for a bulged or skinned capacitor. Even if these capacitors look good, they may be failing. You will need an ESR meter to check for current. You will need an ESR meter for this. Then you will need to check the Mfs with another type of capacitor checker. These two types of capacitor checkers will be a necessity to find these failing caps. If the caps and voltages check out fine in the power supply, you will of course need to inspect and check the capacitors in the signal board. Definitely, there are bad capacitors in one or both boards. I have not repaired this particular model, but the symptoms you describe, tell where to look. Thanks for asking and show all hand of support!
May 02, 2011 | Mitsubishi Televison & Video
My monitor worked great for the period of 5 years or so...then one day it doesn't want to come on, the power light would flicker...anyway I removed the panel and looked for popped capacitors and I can't...
Bad caps can look normal but it they can have high ESR, but you should take some voltage readings first, it should have 5vdc and 12~16vdc when the monitor is plugged in but not turn on.
Post pictures of the caps also, many people told me the caps look OK until I see the pictures and they turn out to be bad. You need cap meter taht can read capacitance and ESR.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 07, 2011 | KDS K717s 17" LCD Monitor
I own a XG-91D monitor that the screen goes black after about 5 seconds. I found 2-470uF 25V capacitors on the power supply board that were leaky - replaced them but the problem still persists. There were...
Most cap meter does not have the ESR measurement function, the cap can look OK but it can have high ESR. Did you replace the bad one with LOW ESR, 105c type such as PANASONIC FM or FC series from DIGIKEY?
When the filter caps went out it may have taken out the components in the inverter circuits with it also. Check the transistors/Ic, inverter transformers.
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
May 10, 2010 | Xerox XG-91D 19" LCD Monitor
I own a XG-91D monitor that the screen goes black after about 5 seconds. I found 2-470uF 25V capacitors on the power supply board that were leaky - replaced them but the problem still persists. There...
Replace thee 1000uf caps too. A capacitor meter will not test the ESR ( equivalent series resistance ) of the caps the cap meter will show them to be good but an ESR meter will show then to be bad. Also be sure to use low ESR caps. If you use general purpose aps like from Radio Shack it can damage the board board because of the ESR rating. The temp rating needs to be 105c or the new caps will blow out within a month because of the heat in the monitor case ( No fans ).
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 17, 2010 | Xerox XG-91D 19" LCD Monitor
Squiggly lines all over untill it warms up then they are just up at the top
Sounds like bad capacitors in the power supply. check for bulging caps or replace the power supply
Mar 13, 2010 | Toshiba 57H82 57" Rear Projection...
Model vg2021m. it fall and now it doesn't come
Look for bad caps as hsown here:
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VG2021/
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
Sep 05, 2009 | ViewSonic Graphic VG2021m LCD Monitor
Westinghouse TX-47f430S Will not power on. LED power indicator flashes blue then to red. Found some fluctuating voltage in the PS and replaced a ceramic cap and it cleared up part of that issue, but it...
There are some bigger electrolitic caps in the power supply that can cause this problem also. Testing with a ESR meter while they are in circiut doesn't always work, they need to be taken out and tested with a cap checker.
Sep 01, 2009 | Westinghouse TX-47F430S 47 in. LCD TV
RCA DVD/VCR model DRC8320
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Jul 15, 2008 | RCA DRC8320 DVD Recorder/VCR
Hour glass screen
Your problem is a bad main B+ capacitor. The right way to find this would be with a good ESR type capacitor meter. If you do not have an ESR cap. checker or do not know how to use a cap. checker. a local repair shop should be able to assist you in this repair at a decent price. Let us know what you did to get this set fixed?
Oct 05, 2006 | RCA F32665 32" TV
RCA DRC8320 DVD Recorder/VCR Logo
114 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
