Question about Toshiba Computers & Internet
I have a Toshiba satelite A665, s6054 laptop with works with internet thru a router. however, it stops connecting the internet after two week... My modem is attached to my destop PC and with D-link router Dir 601 for network. My desktop still connects to the internet but my laptop does not. It say the "media is disconnected" I tried changing ethernet cables and still not connecting. Tried also resetting router and modem, still not connecting. Please help a frustated senior citizen who is ignorant in laptops.
  • 182 Answers
Well you should not worry..i am here to assist you with the problem
And as you have explined that you are getting Media Disconnected error...this error means that there is not physical conection between the Laptop and the Router, which could be because either the Cable is faulty of Router is not powered on or the port is faulty...But if you are using it wirelessly..which means that you are connectiong the laptop to the Router wirelessly.. then it means that wireless signal is not getting transmitted between laptop and router.
Please connect the modem to the Router through an ethernet cable...then connect the Router to the Desktop and Laptop both...that should be ideal way to connect.
Also you may perform the following steps on the Laptop as it would help cuase toshiba laptop has got inbuilt sotware (toshiba config free) to disable adapter...which is why you might be getting media disconnected error.
Try this:
Check on the bottom right cornor of the screen..there would be an icon for Toshiba Config free..click on it to open it...there would be settings to enable and disable the adapter...
Pleae note only one adapter would remain enable i.e either wireless or ethernet adapter.. so enable the one which you are using...if the laptop is connecting to the router wirelessly you got to enable the wireless adapter..else enable the ethernet
If you require any further help please repy
Posted on Sep 13, 2010
Toshiba satelite laptop won't poweer up, built in battery.
Built in battery? Why? Did someone glue it in place?
Those batteries are found on the bottom of the Laptop and are easy to replace. You can get them fairly cheap (like $40)
Here's and extended life 95w battery from Amazon
Amazon com Toshiba Satellite A665 S6086 Laptop Battery 95Wh 8800mAh...
Aug 08, 2016 | Toshiba Satellite A665-S6086 Laptop
How to connect phone line to toshiba laptop A665 computer
Hi
If you have a modem builit into your laptop there will be a port on the side to connect the phone cable to, then plug the other end into your phone socket and you should have a connection to phone line
Cliff Cook
MCP
Jul 30, 2014 | Toshiba Satellite A665-S6086 Laptop
How do i boost turn on time for satelite toshiba A665 labtop?
What do you mean boost? What is the version of windows?How long does it take to boot now?
Feb 01, 2013 | Toshiba Computers & Internet
Recovery disc for toshiba A665-S6054
You must contact Toshiba customer support for this recovery disk set, there will be a charge for the discs.
Jul 12, 2012 | Toshiba Satellite PSAW0U-01K001 A665-S6054...
How do I get my Toshiba a665-s5170 to connect to my internet service?
Try a system restore bringing computer back to a earlier time before this happened, this should restore the network settings.
Apr 04, 2012 | Toshiba Satellite A665-S6056...
Toshiba satellite a665 does not recognize lg phone, it states there are missing drivers.
try having your laptop connected to the internet before connecting the phone. Most of the time the laptop will download any and all drivers to recognize the phone.
Oct 06, 2011 | Toshiba Satellite A665-S6086 Laptop
I have a Toshiba Satelite A205-5000. I have bought 2 new routers, one Linksys and Netgear. It gets a network connection but the IE exploer will not bring up sites. It acts like it does not get a good...
Hi there, Before we start, try hooking your laptop up directly to the modem - if you're not getting an internet connection there, call your Internet Service Provider. If you are, then follow the steps below.
1) Make sure that you're not using more than one router at the same time. One router should be hooked up directly to your modem in the WAN port. If you have wireless security enabled, go to step 2 2) As a test, remove the security on your wireless network and then see if you can access the internet properly. The router can be accessed by typing it its address in internet explorer, as long as you are connected to the router. Generally the address is 192.168.1.1 3) If you still can't access the internet, go to Internet Explorer Options, the Connections tab, LAN settings, and make sure "use a proxy server" is NOT checked. 4) If you DO get an internet connection now, go back to your router and enable WPA security (some older laptops have problems with WPA2 connections).
If everything doesn't work, post back with some more details! Alex
May 30, 2011 | Toshiba Computers & Internet
I am on hughes satelite internet and my connection failed yesterday when the cord from the back of the modem came out. It is back up and running but only directly from the modem to the tower NOT thru the d...
You will need to check the settings of the router .
You said that when you connect the computer to the modem it works, now connect the modem and computer to the router and open the router set up page .
Check the settings of the router.
You may need to set up the router again.
Click Here for step by step info
Dec 06, 2009 | D-Link (DI-711) Router
Cannot get internet from router to
If I understand correctly you want to use the router as a gateway for an sat. receiver.
This Netgear router can be connected to devices that has TCP/IP connections (RJ45) ports or wireless IEEE 803.11 b/g, and that can get the IP address statically or from DHCP (router). Toshiba can do that and therefore it is working fine. If sat.receiver is not device that can behave as a PC (processor etc.) it can not get IP address and router can not "see" that device, therefore router can not let "something invisible" to connect to the internet.
Sep 07, 2009 | Computers & Internet
Computers & Internet Logo
113 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
