Question about Microwave Ovens
Control panel not working, can we replace the panel on our own? model #LMV1630WW/BB/ST phyllis
Please let me know if you found a part # for this, I have the same exact problem. Thanks, Drew
Posted on Oct 22, 2010
LG LMV 1680 ST shows error AC-1 and will not heat. The turntable does not turn either. The exhaust fan still works and the control panel still responds. What does this code mean?
Check the fuse. Also check out the safety switch by the unit door. If not closed when door is closed, no power is applied to either the turntable or the tube.
Aug 22, 2017 | LG Microwave Ovens
How do I access the control panel so I can replace the fuse?
It depends on the type of oven. On countertop models, remove the outside cover. On over the range units, remove the control panel. You may have to remove the air deflector on the top first in order to gain access to the control panel screws.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Aug 24, 2015 | Magic Chef MCD1611ST Microwave Oven
Kenmore Model 721.66222500 just suddenly stopped working. No light, no power, no nothing.
I just had same problem happen on a Kenmore Model 721.89940490. I took off top panel and control panel. Behind control panel is a ceramic fuse. I pullud it out and checked with my mutimeter for continunity and it is blown. Since it is 20 years old I will get a new fuse and replace it. If it works good, if not I will have to go buy a new one to put under the cabinet. My contractor that built my house in 1994 directed wired it but I\'ll spend a little extra and put a plug in the cabinet, if I have to replace it. I suspect I won\'t but there is still that possibility.
Mar 17, 2011 | Kenmore 66222 Microwave Oven
Half of control panel lights/numbers are out
The control touch panel basically has partly burned out and so you would have to replace the whole panel.
Repairclinic.com should have a replacement, just use your model number to search for one.
Let me know how this works out for you.
Benjamin
Apr 30, 2010 | Frigidaire GLMB209D Microwave Oven
No display on microwave touchpad for ge Model JKP62G
The GE JKP62G Microwave / Oven combination has an internal fuse behind the control panel for the microwave. The oven will operate but the microwave will be totally dead (no light, no clock). Turn off the breaker for the oven at the fuse box (30 Amp double breaker). In order to replace the fuse you will have to open the door to the microwave, remove the two screws (Torx) from the front control panel (located on the left edge of the control panel), wiggle the panel to the left (there are two metal tabs that stick into the metal frame of the microwave on the right of the panel) and then tilt the panel down from the top. There is a metal bracket that holds the control panel to the microwave at the bottom (don't remove it). Look towards the top of the microwave inside the area behind the control panel and you will see a 15 Amp screw in fuse. Replace the fuse and that should fix your problem.
Apr 15, 2009 | Microwave Ovens
Frigidere PLMV169DCD
You most likely had a power surge and blew a fuse. First unplug the unit,then remove the top grill. There will either be one screw on top of the control pad or 2 on the left side. open the control panel and look for a fuse that has a ceramic center and replace it with a 20 amp one. You can find these at the hardware store
Jan 31, 2009 | Frigidaire PLMV169DC Microwave Oven
Microwave Ovens Logo
96 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
